FZ-10000 400 equivalent means what on this camera
Started Jun 16, 2014 | Discussions
Don Richardson Senior Member • Posts: 1,454
I usually shoot Canon DSLR with a 1.6 X multiple or a 400 mm lens is 640 mm. and my 150-600mm = 240mm-960mm.
I'm interested in the FZ1000 to lessen my load since I'm getting older and weaker. I used to own and love the FZ50 but changed to the DSLR when it became apparent Panasonic wasn't going to up-grade the 1.7" sensor.
My Sensor chart states that the multiple on a 1" sensor is 2.71. The add for the FZ1000 says 25-400mm equivalent. Is that 35mm equivalent 400 mm = 400 mm or 400 mm X 2.71 X = 1084mm? I can't remember how that worked on the P&S cameras
It looks like Panasonis finally up-graded the FZ50.
 Don Richardson's gear list:Don Richardson's gear list
Canon EOS 7D Tamron SP 150-600mm F/5-6.3 Di VC USD Epson Artisan 835 +1 more
Panasonic FZ1000 Panasonic Lumix DMC-FZ50
cainn24 Veteran Member • Posts: 4,892
Re: FZ-10000 400 equivalent means what on this camera
The real focal length is 9.1-146mm. So, 25-400mm in 35mm equivalent terms. IOW, already converted
morepix
morepix Veteran Member • Posts: 9,487
It means the max telephoto capability of the lens has same angle of view that a 400mm lens would have on a full-frame camera.
David
www.pbase.com/morepix
 morepix's gear list:morepix's gear list
Ricoh GR Olympus Stylus 1 Panasonic LX100 Panasonic Lumix DMC-FZ300 Fujifilm X100F +2 more
Isola Verde
Isola Verde Veteran Member • Posts: 9,019
Don, equated to your 1.6x camera, the lens on the new Panasonic is about the same as a zoom whose range runs from 16-256mm.... much like the new one from Tamron - although that extends slightly further at the long end, viz:
http://www.bhphotovideo.com/c/product/1029404-REG/tamron_16_300mm_f_3_5_6_3_di_ii.html
Peter
 Isola Verde's gear list:Isola Verde's gear list
Panasonic Lumix DMC-ZS50 Samsung NX3000 Samsung 16-50mm F3.5-5.6 power zoom Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 +20 more
OP Don Richardson Senior Member • Posts: 1,454
Thanks everybody for the reply. I guess that settles it for me now. I was willing to give some on IQ from DSLR to the FZ1000 but being a birder I can't go from my 960mm down to 400mm. I'm always looking for reach and this just wouldn't do it for me.
It sure looks to be a nice camera on paper and from all the samples I've seen so far though. Panasonic came reall seems to have come through for you'll this time.
Peter
It would be about the same but with the Canon DSLR we have the 1.6 X crop factor which equates fron 16-300 to 25.6-480 mm.
kkardster
kkardster Veteran Member • Posts: 9,215
Don - your math is correct - it's just the focal lengths that are off. You need to feed the formula the actual focal lengths as engraved on the front of the lens
FZ1000 actual focal length range: 9.1-146mm
35mm EFL = 9.1x2.71-146x2.71 = 25-396mm EFL
Of course, there's rounding involved for all numbers so the 25-400mm are the nice, round marketing values.
Bruce
You learn something new every time you press the shutter
 kkardster's gear list:kkardster's gear list
Panasonic Lumix DMC-LZ7 Panasonic Lumix DMC-FZ200 Panasonic ZS100 +5 more
