2.8/20 prime - slim polariser required?
Started Jun 15, 2014 | Questions
Petak
Petak Regular Member • Posts: 203
Hello Everyone,
A simple question really - do I need a slim polariser for the 2.8/20mm NX prime?
Thank you,
Peter
monkeybrain Regular Member • Posts: 424
Re: 2.8/20 prime - slim polariser required?
Petak wrote:
Hello Everyone,
Thank you,
Peter
I'm not sure if you need a slim polariser if you only use the filter; what I do is use a step up ring and then mount 52mm filters, and I've had no issues. NB: I don't have the 20mm, but do this on the 16mm and 30mm.
 monkeybrain's gear list:monkeybrain's gear list
Samsung NX10 Samsung NX100
Petak
OP Petak Regular Member • Posts: 203
monkeybrain wrote: ... what I do is use a step up ring and then mount 52mm filters ...
I've done that to on DSLR but it defeats the purpose of going mirrorless - reducing size and weight.
vatazhka
vatazhka Regular Member • Posts: 355
It's certainly possible, but I believe that the question was whether there would be significant vignetting when using non-slim filters.
I'm also interested in an answer, as it would be quite handy to use a single filter with 16-50, 16 (unlikely), 20, 30 and 45 (Though I would not carry all of them at once...)!
 vatazhka's gear list:vatazhka's gear list
Samsung NX1000 Samsung NX mini Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +3 more
tufir Regular Member • Posts: 277
No.
Never had any problems with the 20mm and any non-slim filters. It will even fit the lens hood from the 45mm lens without vignetting.
arbuz Senior Member • Posts: 2,247
tufir wrote:
No.
Not from what I see. Hood from 45mm fits 30mm but causes vigneting on 20mm. I shot raw and reviewed in faststone to confirm this findings.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Yeah cause 52mm filters are huge. 52 is a much more common filter size, you can get them cheaper and more easily. Also easier to handle (put on with gloves etc). 52mm filters will also fit the NX60mm as well of course.
