Cropping in CS6
Started Jun 15, 2014 | Questions
JD807 Regular Member • Posts: 409
Cropping in CS6
okay, I know it's probably something simple, but here's the problem-
When I use square marquee to make a selection, I can choose Edit- Crop and it's fine. (It crops the selection)
When I use square marquee and then right-click inside it- Transform selection- then Rotate that selection, NOW when I select Edit-Crop, it doesn't crop that rotated selection.  It crops a rectangle larger than the selection, and just big enough to contain the selection. I'm pretty sure CS5 didn't do this, it always cropped the selection no matter if it was rotated.
Thoughts?
JD
Give me something to shoot
rondhamalam
rondhamalam Senior Member • Posts: 2,582
Re: Cropping in CS6
Maybe first crop it and then before the selection gone do layer via cut or layer via copy. You'll get a layer with rotated crop. If that's what you want.
OP JD807 Regular Member • Posts: 409
Re: Cropping in CS6
I may have to just learn to use Ruler tool- straighten layer- then Crop from there...
rondhamalam
Re: Cropping in CS6
From your description I thought you wanted a rotated crop. Apparently you wanted a straighten image.
MisterBG Veteran Member • Posts: 6,436
Re: Cropping in CS6
Thoughts?
Crop first and then rotate the crop?
 MisterBG's gear list:MisterBG's gear list
Sony RX100 Canon EOS 6D Sony a6000 Canon EOS 80D Canon EOS 5D Mark IV +11 more
Re: Cropping in CS6
I think I need to start using the crop tool in 'unconstrained' mode rather than the marquee tool.  It just seems odd to me to have a selection drawn out, and Edit- Crop won't crop that selection automatically.
