A second body? Same or different?
Started Jun 15, 2014 | Discussions
Airmel
Airmel Senior Member • Posts: 1,303
Same model - Only way to go for me
AirMel
http://www.mel-photo.com
There are 10 types of people in this world.
Those that know binary and those that don't.
 Airmel's gear list:Airmel's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro +18 more
Airmel
Huh?
It's also good to have a different UI - the Panasonic UI is very good, easier than the Olympus
Not on my planet...
AirMel
HamsterKing Forum Member • Posts: 55
Re: A second body? Same or different?
Ontario Gone wrote:
Im in a similar boat. Im going on vacation in a month or two, reservations are made, and this will be my first trip with MFT. Problem is, i know there will be times when i want better tracking than what my GX7 will offer. It reminds me of a response i gave recently about whether "Panasonic should be kicked from MFT". As i said there, i think it's great we have so many differing cameras and brands, regardless of the direction any of them take. It gives us more choices for a wider range of uses.
We have multiple "sports" cams now, we have our choice of Pro video, we have other worldly IBIS for using any legacy lens we want, and we still don't know what Kodak will bring in the next few years. This is good, even if it means having more than one body. Im still shopping around for what i want as a second body, even outside of MFT, but the EM1 is looking more and more like a good idea.
There are times i want the things my GX7 does better, video, silent mode, and there are things an EM1 would do better were i to buy it, like low light/low SS shots which help keep ISO down. Action is another. I see nothing wrong with buying both. Yes the haters will insist it should all be in one body, but how many cameras offer that? Sony E mount doesn't have IBIS like Olympus, not video like a GH4. Neither does Nikon or Canon. None offer it all in one camera, let alone one that is under $2k, so i see no reason we should expect it here.
My mind isn't made up, but the EM1 looks like a good idea. Im taking family to the FL beaches, and we will be chasing eachother all over the place, other times basking in the sun. Small cameras, they can use the same lenses (and flashes) rather than carrying two system's of gear. I see it as an advantage to buy different bodies to always have each's advantage when needed. In fact, im kind of talking myself out of a D7000 i think...
i am too in the same boat!! deciding between the GX -7 and the OMD EM 1 !!
 HamsterKing's gear list:HamsterKing's gear list
Panasonic Lumix DMC-LX3 Nikon D800E Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Nikon AF Nikkor 50mm f/1.4D +6 more
pocketpygmy Contributing Member • Posts: 829
It looks like I'll be fortunate enough to take a long tourist trip in a few months' time.  This has made me look closely at my camera gear!
On my last big trip, my E-5, 12-60 and 50-200 produced great photos, but I soon tired of carrying the 50-200 and left it in my room.  I bought a compact zoom (Panasonic travel zoom) to replace that focal range and just lived with the loss of quality in the photos.  Even the E-5 + 12-60 started to get me down and frequently my hands would ache from holding it.  But that's old stuff...
I now have an E-M1 + 12-40 + Panasonic 100-300.  This combination produces lovely images and if I use the HLD-7 grip it's juuuust big enough to hold.  Sorted?  Not quite.
The remaining down side is changing lenses.  I've long been sick of changing lenses and missing shots because of how long it takes, risking lenses and camera by fumbling, and often turning around and finding the group has moved on and I'm left behind.
I suppose I could buy a 14-150 and ignore the image quality but if I bought a 2nd body, I think my lens changing problems would be solved.  But which body?
A 2nd E-M1 would seem ideal.  I would automatically get a 2nd charger and compatible battery.  It would have identical feel, behaviour and settings to my primary camera.  And in my part of the world, for the rest of this month, Olympus is offering a sweet cash back deal.
But I recall that back when I was buying the E-M1, both the Panasonic GH3 and G6 felt better in my hand than the E-M1.  The G6 is cheaper than the E-M1 even with the cash back, and I could get it with some bundled (low end) lenses if I felt like it.
The GH4 seems like it's an upgrade over the E-M1, so perhaps the answer is to get one and consider the E-M1 the backup body.
Finally, the Panasonic GM1 is so small it has a trick that is almost magic: it can fit in my bag attached to the 100-300 as if it's a fat rear cap!  Apparently it can take good pictures, so why not get one?
So there's my array of choices laid out:
- save money and buy nothing (I would hate this as I would miss plenty of shots changing lenses)
- buy a 2nd E-M1 during the "cheap" time, i.e. now
- buy a G6 and score some cheap additional lenses
- buy a GH4 and consider my E-M1 the backup
- buy a GM1 "enhanced rear lens cap"
What do you think?  Can I go wrong with any of these options?
i'm not convinced you need a second body. you're planning to lug around two high-end cameras for a tourist trip? you really feel compelled to take pictures so often that the group routinely leaves you behind? and you think that loading up on more gear is going to solve your problems? is that really the way you want to spend your holiday? shackled to machines?
if i were you, i'd stick with what you have and consider the following:
- maybe you need a better bag. if it's well designed and just the right size, it could go a long way in terms of your whole photographic / travel experience. travel light! i've bungled lens-changing in the past not because i didn't have enough bodies but because the bag i was using was unwieldy and inefficient.
- maybe you need to take fewer photos. be more judicious. practice mindful seeing. snapping photos indiscriminately at nearly all focal lengths between 12-300mm is one of the least artful ways of being i can imagine. enjoy your trip and don't let all this ridiculous materialistic machine worship dictate your subjective experience of what ought to be a great gift: seeing a different part of the world (however near or far)!
Wellington100 Forum Pro • Posts: 11,807
Indeed, the idea is to spend money and have some fun
I would say look for a different camera that complements the M-1 in some way
A great choice for the 100-300 size wise. It will give you a well balanced combo that handles well and is not too big or too small at a good price and the SLR styling is ideal for use with long lenses.
Another great option because its a newer generation camera but if you don't need its video capability it may be overkill as its quite pricey.
No not for the 100-300. I suspect it will be an exercise in frustration. All the benefits of the tiny camera are lost by putting a huge tele zoo on it. Its the wrong camera for the job for sure. If you wanted a second backup camera for other reasons, it may be the best choice out there, bar none but for this particular application (100-300), its the worst choice, bar none.
Doctors are bad for your lifestyle.
 Wellington100's gear list:Wellington100's gear list
Ricoh GR Panasonic Lumix DMC-GM1 Fujifilm X-T1 Panasonic Lumix DMC-GX85 Fujifilm FinePix S100fs +12 more
ThePalindrome Regular Member • Posts: 477
The pygmy git it I think!
 ThePalindrome's gear list:ThePalindrome's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus XZ-1 Olympus M.Zuiko Digital 45mm F1.8 +1 more
SidSnot
SidSnot Senior Member • Posts: 1,045
agreed, nailed it in one, it's ridiculous how carried away we get with snapping everything in sight these days, just because we can.
in my early photographic days we got 36 frames per film and each one was used with care and consideration.
i went through a 10 yr period of videotaping every holiday we went on then I realised that I had only seen the best bits of all those holidays squinting through a teeny viewfinder taking video that I never bother looking at more than once!
its all so futile. Enjoy your holiday, take one camera for you, one for your partner perhaps, take a 'memory' of the occasion'  once in a while.
it's so easy to become obsessed with this shutterbug hobby....
 SidSnot's gear list:SidSnot's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GM5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +4 more
AG
AG Regular Member • Posts: 291
This is so right! with respect to vacation.
And how often main / the only camera failed ? Just have spare battery and do not look for excuse to buy another toy. And by the way, modern smart phones like nokia have decent day time resolution and low light image stabilisation to be a backup for unlikely events of main camera broke.
14-150 in perfect light travel companion. Have camera build in flash and you set - for travel light.  Do not let hardware control your vacation, just enjoy it - life is short. Unless you are making living out of your photography.
 AG's gear list:AG's gear list
Olympus PEN E-P5 Panasonic Lumix DMC-GM1 Nokia Lumia 920 Nokia Lumia 1520
OP anomalous Regular Member • Posts: 131
Change myself instead?
I think the answers, in order, are: yes, yes, maybe, it's inevitable, reluctantly yes.
As a tourist, I'm wide-eyed with excitement and want to capture the (an?) essential part of what I'm seeing, stuff that I never see in my day to day life. A camera (or two) gives me that possibility, if I can use it.
So, if I were in, say, Paris, in front of Notre Dame, I'd have to take a standard "get the whole thing in" shot, because you're there and that's what you do. 12mm works well. Then I'd notice a detail (maybe a particularly interesting gargoyle high up) and the 12-40 wouldn't be the right lens. So, fiddle, fiddle, fiddle, fumble, fiddle, fiddle, 100-300 is on, line up the shot, take it, fiddle, fiddle, fumble, fiddle, 12-40 back on, and where did everyone go?
I predict that if it's a matter of slinging the E-M1 + 12-40 to one side and pulling out the ??? + 100-300 for a shot or two and putting it away, then I'll get what I want and won't spend so much time looking at the ground where a lens without rear cap is balanced badly while I fiddle with a body with no cap etc. I'll have better situational awareness (i.e. "everyone is leaving" or "that guy looks like a pickpocket") and I'll get the shots I want.
I may be deluding myself, but I'm willing to try.
  • maybe you need a better bag. if it's well designed and just the right size, it could go a long way in terms of your whole photographic / travel experience. travel light! i've bungled lens-changing in the past not because i didn't have enough bodies but because the bag i was using was unwieldy and inefficient.
If you can solve the "no bag is right" problem, you will definitely join my Christmas list!
I have experimented with bags (because it's cheaper than buying other things) and nothing quite works. The stuff that looks like it would actually work is those daft things where you strap several cameras to your chest. Would anyone wear one of those in public?
I suppose I'll take some combination of small backpack, maybe a snoot bag, possibly a belt with a pouch or two. I'm open to camera carrying suggestions, even crazy ones.
  • maybe you need to take fewer photos. be more judicious. practice mindful seeing. snapping photos indiscriminately at nearly all focal lengths between 12-300mm is one of the least artful ways of being i can imagine.
You are right in all respects. But taking fewer photos doesn't solve the problem that some shots need 12mm and some need 300mm. (OK, hardly any need 300mm, but lots need more than 40mm). I'll still need to change lenses. That's a slow tedious thing that reduces my mindfulness. I'm willing to buy another body to see if that helps.
enjoy your trip
Thank you!
While I agree with the sentiment, I don't think it accurately characterises what I do. Using cameras adds to my enjoyment of the experience. Having to put up with their annoying physical foibles subtracts from it. I'm attempting to reduce the annoyances without reducing the enjoyment. At all times (I hope) I remain in the moment and aware of the mind-expanding value of travel.
Re: Change myself instead?
enjoy your trip
Thank you!
fair enough -- you seem to have convinced yourself pretty thoroughly and i respect that you've thought it through and articulated it without getting mad (which happens here sometimes).
(i still think that two m4/3 cams for a non-professional trip is overkill though, and that you'd be fine with a 14-150mm or an FZ1000.)
if anything, may i suggest some reading for your travels (or elsewhere)? a little book called 'on photography', by susan sontag. food for thought.
Erick L Senior Member • Posts: 1,288
I use an E-PM2 with a 9-18 because I prefer using the LCD with wide angles and an E-M5 with a 14-150 or 100-300 because i prefer a EVF with longer lenses. I'd rather have an E-M10, partly because it uses the same battery as the E-PM2. I could use two E-PM2s or E-PL5s with a single VF-4.
Erick - www.borealphoto.com
krugman Contributing Member • Posts: 957
Here's an approach consistent with what you have posted. On a trip to Europe I am taking only the EM10, the Pany 20 and the Oly 45. Instead of changing the 20 for the 45 when needed, or carrying a long zoom when the 45 is too short, I plan to use the Digital Tele Converter.
Krugman
jeffharris
jeffharris Forum Pro • Posts: 11,409
Agreed. I just got back from Belgium carrying, in my mind, a reasonable and flexible kit… GX7, 7-14mm, SLR Magic 12mm, Voigtländer 17.5mm, 42.5mm and 75mm f2.5 Color Heliar. My girlfriend carried our GX1, 14-42mm II, 20mm and 45-150mm.
I started out swapping lenses quite a bit, but gradually boiled it down to using the 7-14mm and 17.5mm the majority of the time. I didn't use the 12mm once and the 42.5mm and 75mm were used sparingly. The 17.5mm was fantastic on the street using zone focusing at f5.6 and f8! Of course, it was perfect in dark buildings, museums and at night.
My girlfriend started with the 14-42mm but found it wasn't zoomy enough, so she stuck with the 45-150mm and used the 20mm at night a bit, all in iAuto mode. She tried the 17.5mm and really loved it. Night shots with the 45-150mm actually ended up looking quite good and not as noisy as I'd feared. So, ultimately, about half the lenses we carried weren't used.
The nice thing about having two cameras was that when I saw a long shot, I either swapped lenses with her or just grabbed the GX1. There were times when I just carried both. It was a really great solution. Ideally, we'd have two GX7s, but that ain't happening any time soon.
We discussed the whole thing and decided on a simpler solution. Sell the kit zooms and get her a 14-140mm II and just leave it on the GX1. I'm debating whether to get a 12-40mm for general purpose daytime shooting.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
I haven't worked out why people get so steamed up around here. If there's one thing I've learned it is that being angry is a waste of life. If I thought you were entirely wrong I'd just say so. I hope you'd be OK with that.
Perhaps. I won't have to give up food to get a 2nd camera. I'm not stealing from a child's education fund. It's a hobby I have a passion for, but I'm not without reason. And maybe I'll just get a 14-150. But probably not.
The FZ1000 is a new confounder. It is likely to be good enough for almost all travel photos. It may even be available before I go. Then the E-M1 stays at home? Weird thought.
Ah, a polemic! Perhaps I'll find a copy. I'll consult my local library.
Zensu11
Zensu11 Senior Member • Posts: 1,542
I'd stick with getting the same camera if you want to save time and confusion. Readjusting to a different body might only take a few seconds but the most valuable thing in traveling is your time. You only have a limited amount of time and those camera body adjustments (just like changing lenses) can add up to loosing a shot.
Bobby
LMNCT Veteran Member • Posts: 4,908
If not the same camera, than at least the same manufacturer.  There is nothing so irritating as going back an forth between two dissimilar menu systems even if you know how to navigate both.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
I took the same route, a GM1 to back up the GX7.  I have an EPL5 to back up the EM5.  I keep to the same barn when carrying a backup.
Godfrey Forum Pro • Posts: 29,636
Generally speaking, when I want a second body as backup (that is, for the situation of a failure on a paid job), I want an identical body, configured the same. When I want a second body for the notion of a different lens, a different functional need, etc, then having the same is not so important.
For stills work, to me the E-M1 does the number best and works with my SLR lenses best (for several reasons, including the IBIS and PDAF). But for movie work, at the same level of competence, I'd want the GH4. If that split fits my need for a 'one lens per body' shooting methodology, I'd buy a GH4 instantly to complement the E-M1.
But out generally speaking,where my split happens is that I want the dynamics of the smaller format for telephoto work and the dynamics of a larger format for wide work, so my two body setup is E-M1 and Sony A7.
sigala1 Veteran Member • Posts: 3,911
You need a Sony RX10
The Sony RX10 was created excactly for people like you, who feel that they need to have a really huge zoom range, but don't want to deal with the hassle of changing lenses, and the heavy weight of telephoto lenses designed for larger sensors.
Although I don't really understand the need for long zooms for general travel photography.
Aberaeron Forum Pro • Posts: 10,184
I love the variety. It keeps me on my toes and I like to think it keeps the little grey cells active.
I don't find jumping from one camera brand to another much more taxing than going from one of my G6's to the other, once I have messed around with their settings. I try to reset them both identically and to my default favorite menu scheme at the start of the day though.
