Which Oly Macro: 50mm or 60mm?
Started Jun 13, 2014 | Questions
wpbarr
wpbarr Junior Member • Posts: 27
I would appreciate opinions and advice regarding which lens to choose. Weather-sealing is important, so I think I'm mostly limited to the 4/3 50mm f2.0 and m4/3 60mm f2.8 lenses. The lens will be mounted on an E-M1. Here is how I plan to use the lens:
  • organic still life (macro) - documentary & abstracts
  • inorganic still life (macro) - abstracts
  • I focus macro shots by rail at maximum distance
  • medium length telephoto for shallow DoF
  • primarily monopod/tripod, not hand-held
  • images will primarily be displayed electronically
  • only RAW mode will be used for macro shots
  • images will be cropped aggressively
Weight and bokeh quality are not important. I don't know if 1:1 is that important, so I would enjoy learning experiences and perspectives about magnification.
Thanks in advance.
Bill
 wpbarr's gear list:wpbarr's gear list
Olympus E-M1 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital 35mm 1:3.5 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
Olympus E-M1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus Zuiko Digital ED 50mm 1:2.0 Macro
Levan Regular Member • Posts: 265
Re: Which Oly Macro: 50mm or 60mm?
Thanks in advance.
Bill
Both lenses are quite good, but good old 50 is better for any purpose, except AF. amd, you can get EX-25 extension tube. 50mm with the extension tube is a powerful combo (giving AF speed is not priority).
I own both. When I want serious macro shots, I do use 50 (or combo depending on the magnification needed).
A photographer, who observes the world only TTL, can be a good craftsman, but not an artist.
ambercool
ambercool Contributing Member • Posts: 911
I have both too, but I find myself using the 50mm more.  The 60mm 1:1 is an advantage out of the box, but I just find the 50mm richer.  Maybe I just haven't used the 60mm enough.  My 50mm has been used for almost 6 years.
-Viet
http://www.ambercool.com
"Luck comes to those who do"
 ambercool's gear list:ambercool's gear list
Canon EOS 5D Nikon D70 Sony a7 Olympus PEN-F Leica Summilux-M 50mm f/1.4 ASPH +29 more
Zensu11
Zensu11 Senior Member • Posts: 1,542
Here is a link to Robin Wong's review of the 60mm Macro in which he does some comparisons with the 50mm Macro. The review is divided into three parts. 1)First Impressions, 2)Close up shooting, and 3)General photography.
http://robinwong.blogspot.com/2012/09/olympus-mzuiko-60mm-f28-macro-lens.html
I chose the 60mm for myself but you may decide differently. Robin's review should help you with some of your questions about which to choose. Good luck in whichever lens you decide on.
Bobby
John Kubler
John Kubler Regular Member • Posts: 322
I used to have the 50 which I used with my E3, but since moving to the m4/3, I prefer the 60. It focuses much faster, has a limiting switch (I use manual only for 1:1). In terms of IQ I can't see much of a difference, but I get a lot more keepers.
JMK
 John Kubler's gear list:John Kubler's gear list
Olympus PEN E-PL1 Olympus OM-D E-M5 Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +16 more
Godfrey Forum Pro • Posts: 29,636
When I was shooting exclusively with the SLRs, I had both 35 and 50 Macros. I sold the 50 when I sold the E-5. Now I have the 35 Macro and Macro-Elmarit 45, both of which are brilliant if not weather sealed.
I've debated picking up another ZD 50 or the M.Z 60, but for the moment when I want something longer than 45mm, I use my ancient Micro-Nikkor 55mm f/3.5 Pre-AI or a Micro-Nikkor 105mm f/2.8 AI-S adapted to the E-M1. Both do an astonishingly good job.
I've never needed the weather sealing, but if you're shooting bugs in damp country it's a nice added feature.
jalywol
jalywol Forum Pro • Posts: 12,301
I do a lot of macro work, so I have tried the 50mm, 60mm and the PL 45mm. My particular feeling about these lenses may be a little different than some others, but I ended up with the PL 45mm, which I think has beautiful IQ.
When I tried the 50mm on the EM1, I was surprised at how slow and noisy the AF was, and I just did not see much of a difference between it and either the 60mm or my old adapted Nikon 55mm f3.5 macro (which is a heck of a good lens). In addition, since the AF is so slow and so noisy, you have to use manual focus on the lens, which would be fine, except since it is focus-by-wire, it does not have that lovely snappy precision of a fully manual lens (like my Nikon). Needless to say, it did not stay.
The 60mm is a nice lens, but when I got it, after comparing it with the adapted legacy Nikon, I simply could not see any IQ difference; if anything I like the Nikon output better. I even tried two copies of it, just in case I had a bad one, and the results were the same.
This year I ended up springing for the PL 45mm f2.8 macro, and was actually delighted with it. It has beautiful IQ, and it's the first macro lens I've use on M43 that trumps the adapted Nikon in image quality. It's not weather sealed though.
So, given all of this, what I would recommend (based on my own experiences and what you want), is the Oly 60mm. IF you can live without weather sealing, I would strongly consider the PL45mm, and IF you plan to use MF a fair bit of the time (and can live without AF or weather sealing), I would look into one of the Nikon macros.
-J
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
Don't forget the 35 3.5 macro lens.  It is going to be way cheaper than both if you are looking for a dedicated macro lens that can still shoot portraits.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +13 more
jalywol
True, and it is a 1:1, but I have never actually tried that one, so I can't give any opinion on its performance
-J
Bassam Guy Veteran Member • Posts: 4,885
Thanks in advance.
Bill
I have the 60mm and love it but, if all I wanted a lens for was exactly what you've listed above, then the cheaper of the two would be the deciding factor.
If I might possibly ever want to use the lens for any other purpose I'd get the 60.
The 60 will probably hold its resale value more than the 50.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
-J
It's a terrific performer and very inexpensive. It's probably my most used FourThirds SLR lens.
wpbarr
OP wpbarr Junior Member • Posts: 27
Thank-you everyone for taking the time to comment. The weather-sealing is important as is working distance, so a shorter lens is moving in the wrong direction. I am favoring the 60mm and will probably rent both for a weekend before I make a decision.
I hope this thread is useful to others in the future.
Bill
Franka T.L.
Franka T.L. Veteran Member • Posts: 8,161
Consider the environment
I too do a load of macro and with such field application, most of the time its the environment demand that's really more a dictating factor than the actual usage demand .. You did say organic subject but that can be flora and well plants do not object to us getting up close ( usually at least ) but if your organic subject involve something like say a venomous snake, then for your own sake ( and that of the subject ) it might be better to seek out options beyond just the 50 or 60mm.
Personally with your said goal I see no real difference with the 50 and 60mm bar the fact that the 50mm only goes to half life size while the 60mm goto life size and that might or might not be the factor for you. Otherwise I think they are both good. But considering I would instead like to go for a good old Nikon 200mm /4.0 Micro-Nikkor ( the current version would do fine ) or similar from Tamron, Sigma or Canon's .. the longer focal length in this case is not for anything specific to imaging. its for the capturing the longer working distance allowed allow much more liberty in lightning and composition as well as allowing that safe margin ( for you and your subject ). One other way we used to do it in film days and still valid is to use a fine quality Tele ( like 300mm or more ) with extension tube. Do remember no matter what lens, at these macro setting ( close to or even exceed life size repro ) the Bellow Factors kicks in , so your f/2.8 aperture really is turning in light intensity more like f/5.6 or even lesss ( You can google for the complex math required for that )
Which goes back to the lens, and why I am saying a real Quality ( optically ) mid range speed ( fast would be nice but not absolutely needed ) Tele Macro would be my no.1 desirable lens right now for M4/3 ; preferably with a tripod bush that allowed the lens to be tripod locked to its nodal point. Something like a 180 or 200mm Macro that can do 1:1 and speed like f/3.4 or 4.0 .. that can easily double as the mid range " general " purpose Tele
- Franka -
If you rent both then you're buying the 60
Don't overlook the dial on the 60 that controls focus ranges and limits hunting.
sinkas Senior Member • Posts: 1,609
-J
I had the 35mm. The working distance can be an issue. The 60mm is obviously much better in this regard. I can't fault the 60mm - brilliant.
Regards Daryl
http://dsinclair.zenfolio.com/
Hobbes: You're ignorant, but at least you act on it.”
 sinkas's gear list:sinkas's gear list
Nikon D7200 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Teleconverter TC-14E II +5 more
