Canon 6D. Battery Life Horrible.
Started Jun 12, 2014 | Discussions
Tom Boucher Senior Member • Posts: 1,518
Hi -
I have a Canon 6D that if I let it 'sit' on battery for more than a day even in the off position the thing is dead when I pick it up again.
For example:
fully charged the batteries.   installed in grip (or, without grip before).  Shoot maybe 100 shots total, all photographs with no flash/wifi off/gps off.
I've tried both leaving it in 'standby' or flipping to the 'off' switch.
return camera to case.   Retrieve it 24 hours later, batteries are dead.
I used to do this with my previous bodies, no problem.  This was Canon 5D, Canon 20D, Canon D60.  All of them with medium to light non-flash usage would take a month before the battery would need a charge, or more when I had a grip and two batteries in it.
What am I missing?   what is doing this?   The main lens I use with the 24-105 F/4L IS lens.
 Tom Boucher's gear list:Tom Boucher's gear list
Canon EOS 6D Canon EF 16-35mm F2.8L USM Canon EF 50mm f/1.8 II Canon EF 24-105mm f/4L IS USM +4 more
Canon EOS 6D
aramgrg Contributing Member • Posts: 886
Re: Canon 6D. Battery Life Horrible.
Turn off gps and wi-fi.
They consume energy even if camera is off.
Update the firmware to the newest one, it seems to have better energy consumption.
 aramgrg's gear list:aramgrg's gear list
Fujifilm X-T2 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 18-55mm F2.8-4 R LM OIS Rokinon 8mm F2.8 UMC Aspherical Fisheye Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
DtEW Senior Member • Posts: 2,550
This is not a problem common to the 6D, as I can leave mine sitting around for a couple of weeks and keep the same state of charge.  I can also shoot hundreds of normal shots without causing a significant dent in the charge state.  Even with GPS on, the power draw is surprisingly low.
Therefore, the problem is either specific to your 6D, or your (mis)utilization.
I have noticed there are two instances which do guzzle juice on the 6D:
1. WiFi - with Wifi enabled and active in a tethered state, whether that be between your smartphone/tablet (or presumably, through a router), I can burn through a battery in a few hours of night photography.
2. GPS logging - this is different from merely having your GPS on.  When your GPS is on, it reads and writes a geotag each time you take a shot.  With GPS logging, your camera keeps track of its location and writes it to a log file at a user-defined interval.  This is a juice hog.
Have you checked if you have activated these juice-hog features?
 DtEW's gear list:DtEW's gear list
Canon EOS 5DS Canon EOS 6D Samyang 24mm f/1.4 ED AS UMC Canon EF 24-70mm f/2.8L II USM Tamron SP 45mm F1.8 Di VC USD +16 more
RandyB2
RandyB2 Senior Member • Posts: 1,051
All things to check. Especially the GPS. If you still have a problem you probably have a bad battery. My 6D will last all day shooting a couple of hundred pictures and still have battery left. It is NOT a overall 6D problem.
Randy
 RandyB2's gear list:RandyB2's gear list
Canon EOS 10D Canon EOS 60D Canon EOS 6D Canon EF 70-200mm f/4L IS USM Canon EF 24-105mm f/4L IS USM +1 more
Mr Jam Regular Member • Posts: 331
Check your settings too
I get 1200+ shots with 6D and battery life is great.  But, once I was playing with the WiFi and I set the camera to "Never go to sleep" in the settings menu and then forgot about it.  The next day the battery was completely depleted and dead.
So one more thing to check is, check your settings and check your time to sleep.
Freneticburn Regular Member • Posts: 200
I've taken 1000+ photos on a single battery and still have plenty of battery left.  That's using a 6d with the latest firmware, wi-fi and gps off, and a canon 70-200mm f2.8 IS II with the IS turned off 95% of the time.  I've let it sit for days without losing any charge.  Something is wrong with your camera or the battery if you have the gps and wifi turned off.
 Freneticburn's gear list:Freneticburn's gear list
Canon PowerShot SX260 HS Canon EOS 550D Canon EOS 6D Canon EF-S 18-55mm f/3.5-5.6 IS II Canon EF 50mm f/1.4 USM +3 more
qianp2k Forum Pro • Posts: 10,350
If you turn off all unnecessary features such as WIFI and GPS (in Airplane mode), LP-E6 battery could take 1000-2000 photos.  I took close to 2000 photos with the same fully charged battery in 5D3 by just shooting no viewing at LCD.
lightform
lightform Regular Member • Posts: 133
Not to pile on, but I too have taken nearly 1000 shots over a months time on a single battery pack charge. Check your settings or send your camera in for repair, something is not right.
 lightform's gear list:lightform's gear list
Canon EOS 6D Canon EOS 80D Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm f/4L IS USM Canon EF 17-40mm f/4.0L USM +2 more
Abu Mahendra Veteran Member • Posts: 4,738
Same here.
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 16-35mm F4L IS USM Canon EF 24-70mm f/2.8L II USM Canon EF 35mm F2 IS USM Canon EF 70-200mm f/4L IS USM Canon EF 100mm f/2.8L Macro IS USM +3 more
ASR45
ASR45 Forum Pro • Posts: 36,726
I was about to say that, the GPS & WIFI does indeed drain the battery.
Alan.
Great photography is about depth of feeling, not depth of field.
- Peter Adams
 ASR45's gear list:ASR45's gear list
Canon EF 100-400mm F4.5-5.6L IS II Nikon D750 Pentax KP Canon 6D Mark II Sigma 300-800mm F5.6 EX DG HSM +10 more
brightcolours Forum Pro • Posts: 14,920
Only sometimes
I have had 4 times that the battery was empty the next day, without GPS and WiFi enabled. Twice the camera was off, so I leave it in standby. Once it was tethered to USB (after downloading images). And one time it was in standby.
Usually it keeps power for days and days.
OP Tom Boucher Senior Member • Posts: 1,518
I was unaware of the 'logging' option.  That was the only thing still on.   I've turned it off and we'll see if it behaves better for me.
I knew it couldn't be 'normal'.  Seemed ridiculous.   I never use WiFi so I turned it off completely when I got it.  Didn't know it logged anything.
Will it still geotag?  or is that disabled with the logging thing?
lucidmedias
lucidmedias Forum Member • Posts: 97
even if it's not the cause of the problem, you should always take the batteries out of the camera when not in use. evens says in the manual.
