E-PM2 + 14mm f2.5
Started Jun 11, 2014 | Photos
(unknown member) Regular Member • Posts: 221
E-PM2 + 14mm f2.5
These are straight out of camera just re-sized to reduce file size.  Just wanted to test how this tiny combo works.  There is quite a bit purple fringing but I guess it can be removed in post processing.  I think the total weight of this combo is only around 320g which is perfect, most of these were shot with the camera in single hand while walking about.
Comment & critique:
Olympus PEN E-PM2
sigala1 Veteran Member • Posts: 3,911
MASSIVE purple fringing
There's some pretty MASSIVE purple fringing in those photos.
I daresay that my iPhone 5 does much better OOC JPEGs.
Bassam Guy Veteran Member • Posts: 4,890
Re: Are my eyes that bad?
I've looked at these zoomed 100% but just don't see the purple. I have slight blue-green color blindness. Can you please identify somewhere in one of the OP's photo where the purple looks so obvious?
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
eyeswideshut Regular Member • Posts: 338
Similar condition, although my deficiency is mostly green/red. Normally I see purple w/o problems, but MASSIVE fringing? Cannot see it. Hopefully sigala1 will point it out for us.
Cheers
eyeswideshut
baxters Veteran Member • Posts: 5,319
Re: E-PM2 + 14mm f2.5
The EPM2 and 14mm is a nice combo. The 14mm is known for its PF in the edges, but it can be removed.
For CC, I would turn down the exposure a bit. Skies are getting blown out,
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
Can you seriously not see purple EVERYWHERE in these photos, are are you just pretending to be blind because your favorite brand is being impugned.
One of the most important aspects of image quality of a color photo is that the colors are correct, is that not true? I don't see how you can claim anything other than, from a technical perspective, these are really crappy photo because there's so much purple where there was no purple in real life, and this can even be seen in tiny web-sized photos, we are not talking about pixel peeping at 400% magnification.
I think what you are referring to is a generally cool tone / white balance related. Where is the purple fringing?
And why are you all huffy?
Cheers
eyeswideshut
Ron Evers
Ron Evers Senior Member • Posts: 1,751
I think the PF shows best around the tree in the second last pic.  Please click View Original Size.
The wood is clear between the knots.
 Ron Evers's gear list:Ron Evers's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GF1 Olympus PEN E-PM1 Olympus OM-D E-M5 Olympus E-M5 II +15 more
6th image has shutter shock?
I think the 6th image is unsharp because of shutter shock. It was taken at 1/80 sec, a problem shutter speed.
You need to use 1/8 sec anti-shock and keep the IS turned off to help avoid this problem.
The first picture has the worst purple fringing, the tree in the upper left is all purple:
http://4.static.img-dpreview.com/files/p/E~forums/53834232/6f9ba2f8be5c471ab20ebece9f9db132
Jeff4500
Jeff4500 Senior Member • Posts: 1,921
Re: 6th image has shutter shock?
Its a Pany Lens, and the Pany cameras do the fringing removal in camera (so do some current Oly I think) but I use either LR or CCPS to fix it very easily. If you want Jpeg you will see fringing in high contrast scenes. RAW files from these 16 mpx cameras are sooo much better than a phone's. On my EP5 the fringing is there against high contrast backgrounds but cleans up with a single click.
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
QuakeO Regular Member • Posts: 166
My CC is the inclusion of some unnecessary elements in the frame: cars, half a pedestrian, and a garbage can.
 QuakeO's gear list:QuakeO's gear list
Panasonic Lumix DMC-GF3 Olympus PEN E-PL5 Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +5 more
Jere Landis Senior Member • Posts: 1,933
Mt question is, if you put these up for inspection and critique, why in the world would you shoot one handed?
 Jere Landis's gear list:Jere Landis's gear list
Canon EOS 550D Panasonic Lumix DMC-G10 Olympus PEN E-PL3 Panasonic Lumix DMC-G5 Olympus PEN E-PM2 +11 more
You always are very critical and controversy follows you everywhere. Why don't you just pass on some of these threads?
Thanks Ron, for your courteous reply.
I see the fringing now - probably not as clearly as you but I see it. I also noticed the color cast problem earlier but didn't mention it in respect to the OP. Perhaps the color cast is what sigala1 meant by his oxymoron of fringing "EVERYWHERE".
c_henry Regular Member • Posts: 240
It's a great little combo (I've the E-PM1 that I use with the Panny 14mm). Getting rid of the purple fringing is a 1-click fix in LR.
Thanks for posting.
Colin
 c_henry's gear list:c_henry's gear list
Fujifilm X100S Leica Q Canon EOS-1D X Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 +8 more
There’s no doubt that the E-PM2 has better RAW files than an iPhone 5. The latter doesn’t do RAW!
But, if you put the iPhone 5 into HDR mode (where it automagically merges three photos), the JPEGs it puts out are quite beautiful and on par with high end cameras. And much better than the JPEGs posted to this thread.
People should know how bad those photos look. So they don't make the same mistake.
I hope the OP doesn't take it personally. It's not like he's an engineer for Olympus and it's his fault. He just got duped into the idea that an E-PM2 and an expensive 14mm prime lens would somehow magically create better JPEGs than in iPhone.
Only by complaining will Olympus fix the problems in their cameras. And in fact, Olympus is getting the message because they added zero-second anti-shock, and the E-M10 seems to be doing something different because I have not seen any PF problems from photos that were posted and taken with an E-M10.
There isn't anything wrong with using a 10-ounce camera one-handed.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Sigala, doesn't realize, of course, that this is Victoria market…
…named for a Queen and Empress, in that queen of cities, Melbourne, in the state of Victoria, named for said Queen and Empress.
Of course there is fringing of the royal color -- what do you expect with so much queen and empress stuff going on?
To suggest there is purple fringing everywhere is hyperbole, but you will always get it in such areas as the bare tree branches against the blue sky with this little Panny lens (or even big Panny lenses) and the Oly body. You can fix this in PP or minimize it by using an excellent Panny body which will fix it in camera or you can do what I have done -- switch to the Panny body (G6 in my case) and flee to a place where there are no autumn/winter trees, e.g. the wet tropics! (Okay, okay, you still get purple fringing around coconut fronds against the sky. But at least you aren't cold!)
Did I see that Oly is now correcting purple fringing in its latest cameras?
I used the Panny 14 on my E-PM1 and E-PL3 as my standard walk around lens (with the Oly 40-150 in my pocket) for a year and a half with excellent results. I corrected the purple fringing in Photoline and/or PTLens in those photos where it was obvious and ignored it in most cases. Correcting it look a moment.
Very lightweight, compact kit.
In fact, though, the standard 14-42 II R is not much heavier, the IQ at 14 is as good as the Pamny 14, and it is more versatile. It is a little bulkier, of course, and if you have the sun in the frame, it delivers a splodge while the Panny delivers a nice image that actually looks like the sun.
The other thing I noticed, Sylon, is foreground. It needs to be filled! it needs to have interest! In a couple of the pix here, the foreground is simply empty. Crop! Or better -- become more conscious of it and compose to fill it like you did with your first shot.
Cheers, geoff
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://pngtimetraveller.blogspot.com/2011/10/return-to-karai-komana_31.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
