LCD live (no)view and noisy lens problem with E-M10 + 20mm/1.7 II
Started Jun 9, 2014 | Questions
Wojtek Bialy Junior Member • Posts: 45
Hey,
I have a new Oly E-M10 with 20mm/1.7 but I encountered two problems, I hope it's something easy to fix and maybe someone here would help me figure out what's going on
1) 20mm/1.7's noisy aperture: I guess it's aperture. When the camera is in "standby" mode, so it's on, ready for some action, but the shutter speed isn't pressed, the aperture closes and opens up as the light changes (if I'm on auto or half-auto modes). So when I aim at something dark, aperture will open up and when I move the camera to aim at something bright, it closes down. But here's the problem: this lens is very noisy while doing this. I can hear very clear clicks, like 3-8 of them each time I move the camera noticeably (from dark to bright etc). How noisy? Hard to describe, but you could easily hear it standing 2 meters away. In silence you could easily hear it standing at the other end of practically ANY room. Salesperson told me it's normal with this lens. But really? Btw the IS is also noisy (louder than my previous lenses) but I believe it can really be that way
2) E-M10's LCD Live view: It doesn't work. It could have something to do with the lens if it comes out it's flawed. From what I understand by pressing "info" I change the display mode. There are three: 1) EVF only 2) LCD with some add-ons and 3) LCD without fluff. The EVF works well. But the second option only displays the add-ons (in my case the spirit level) and the center of the screen is black (the screen is on, and it displays black). The third option only shows the black screen. Again, it's ON but displaying black. Just as -I guess- if I had the lens cap on (btw I don't).
I can turn the "LCD live view" mode, see NOTHING, take a picture, press preview and the picture will be perfectly okay. Yet the life view displays pure blackness. Maybe, somehow I have some strange option turned on/off? Maybe I do something wrong? But I don't think so. Reseting settings didn't work as well
I'd really, really appreciate your help
Thanks!
Olympus OM-D E-M10 Panasonic 20mm F1.7 II
baxters Veteran Member • Posts: 5,319
Re: LCD live (no)view and noisy lens problem with E-M10 + 20mm/1.7 II
I don't own an EM10, but have the Em5 for almost two years. Last winter, I was playing with MYSET's, did a full camera reset  and I got into a similar situation. No live view on the LCD and I couldn't get it back, I had been using this camera for 20 months!
Finally, I remembered  the button on the right side of the EVF with this mark |O| , pressed it and and I got my live view back on the LCD. The EM10 has the same button. Have you tried it?
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
FrankS009
FrankS009 Veteran Member • Posts: 6,557
I have never heard clicks with my 20mm 1.7 I.
F.
"We shoot the things that move us in ways that will move others." David duChemin
 FrankS009's gear list:FrankS009's gear list
Panasonic Lumix DMC-GF1
honeyiscool
honeyiscool Senior Member • Posts: 1,376
2) Button on the side of the EVF. Press it.
1) Yes, it's normal. also, the IS isn't on the lens, it's on the body, and if you find the sound distracting, you can disable IS when the shutter is half pressed. I prefer to do that because I hate the sound the IS makes.
 honeyiscool's gear list:honeyiscool's gear list
Panasonic Lumix DMC-GX85 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +2 more
Fredrik Glckner Veteran Member • Posts: 3,894
1) This lens is noisy, both in terms of focus noise and aperture change noise.
I've found that the focus noise of the new version of the lens is somewhat less audible, but the aperture noise is about the same:
http://m43photo.blogspot.fi/2014/04/new-20mm-f17-lens-is-less-noisy.html
OP Wojtek Bialy Junior Member • Posts: 45
Thanks a lot guys! I didn't even noticed the "|O|" button, it works great now
And I'm a little bit less sad about the noise of 20/1.7
