Canon f/2.8 300mm IS USM II - Mode 1 vs. 2 vs. 3 w/1DX
Started Jun 6, 2014 | Discussions
tvstaff
tvstaff Veteran Member • Posts: 3,264
I'm hoping that there are sports photographers out there who can give me some concise insight into their experience and efficacy with the Canon f/2.8 300mm IS USM II utilizing Modes 1, 2 and 3 shooting action sports.
Here is an example of what I shoot and what I'm trying to perfect. Thank you.
NOTE: All of the below were shot with the 1DX and f/2.8 70-200 IS USM II - This will be the first year I'm shooting a professional event with the 300mm.
Feel Always Humble - "FAH" - You'll Learn More
http://tony6454.wix.com/aruba-kitesurfing
 tvstaff's gear list:tvstaff's gear list
Canon EOS-1D X Canon EOS-1D X Mark II Canon EOS-1D X Mark III Fujifilm GFX 100S Canon EF 35mm F1.4L USM +28 more
Canon EF 300mm f/2.8L IS II USM Canon EOS-1D Canon EOS-1D X
Blake Cook
Blake Cook Veteran Member • Posts: 3,129
Re: Canon f/2.8 300mm IS USM II - Mode 1 vs. 2 vs. 3 w/1DX
I'm not sure what's going on with these photos, but none are close to being sharp or is that an effect you intend.  Most are shot at shutter speeds that Mode doesn't even matter. Just turn off IS.
Blake in Vancouver
Canon and Zeiss Stuff. Mac Stuff & annoying PC & Windows stuff.
 Blake Cook's gear list:Blake Cook's gear list
Canon EOS 5D Canon EOS 7D Mark II Canon EOS-1D X Mark II Canon EOS 5D Mark IV Canon EOS-1D X Mark III +14 more
TGM123
TGM123 Regular Member • Posts: 329
I have shot a lot (but not a whole lot ~15,000 snaps) of sports with the 300mm f/2.8 II and have really only used IS in two modes: OFF and 3. 1 doesn't make sense for the sports I shoot and I have only used 2 for panning occasionally and have had limited success but this is likely my inability to nail the panning technique.
At the shutter speeds I try and shoot at (>1,000) I can't tell the difference between 1 and OFF. Seems many recommend mode 3 with sports. As I was getting great shots with it OFF there is no reason to turn it on and add risk (e.g. why introduce another variable if you don't have to).
YMMV
Best,
Tom
www.tommarronphotography.com
 TGM123's gear list:TGM123's gear list
Canon EOS 5D Mark III Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sony RX100 III +15 more
Peter Galbavy Senior Member • Posts: 1,057
Like said by others the shutter speeds are only going to render the IS redundant. However if you are using AF Servo and following with AF then the IS may help steady the panning for AF to work better - but that's just conjecture as I've never shot surf/water based sports.
Peter Galbavy
rebel99 Veteran Member • Posts: 4,025
these shots have quite a bit of noise when you view them at 100%
cheerz.
tvstaff
OP tvstaff Veteran Member • Posts: 3,264
cheerz.
Yes!!!  That's why I'm using the 300mm vs 200mm this year and asking if ANYONE has exp with settings 1,2 and 3. I'm now of the school that I should turn IS off.
There were heavy crops.  My thoughts are a from the jump 30-50% improvement just based on the lens....
This is what the lenses can do. Which do YOU think reflects the focus and clarity I'm seeking???  For me, I'd be happy to transfer this efficacy to shooting sports.   Can I achieve it with subjects moving 50mph over the water???
THIS is why I'm seeking others who have shot with the 1DX and f/2.8 300mm IS USM II to get a sense of modality.
b/r
bronxbombers4 Veteran Member • Posts: 3,387
I don't see why you even need it for that. It's gotta be low ISO, high shutter speed with that kinda light. Mode 1 or 2 will just get in the way and make a mess. Maybe the new Mode 3 could work OK, but why do you even need it? (i've never used a Mark II super-tele so I can't comment on whether Mode 3 actually works as they claim or not)
tvstaf, i am not sure if setting 1,2,3 will help in reducing noise in this case. i usually take static pictures of birds and some times i see noise in some shots and sometimes not. i still don't know what setting causes this noise. this has always been a puzzle to me. you can't relate this to focusing. please let me know when you find out you may want to use noise ninja if that can help any but using noise ninja can present its own issues! i am totally frustrated myself.
cheerz.
BigBen08 Veteran Member • Posts: 7,473
I have the 300 II and I'll echo what others have said...at high shutter speeds you can leave IS off.
Not using IS will give you longer battery life. But with the large battery of the 1DX the power saved may be insignificant.
You may want to consider the 1.4xIII extender. It will provide 420mm and still give excellent IQ.
tvstaff
YMMV
Best,
Tom
Thank you Tom!
tvstaff
cheerz.
Than you rebel99 I appreciate you writing. All the best to you!!
tvstaff
Thank you BigBen08, I've tried the 1.4 III and appreciate you writing.  All the best to you!!!!
tvstaff
cheerz.
Hi Rebel,
Noise is an issue when I crop too much and needless to say shadows and black in heavy back-lit objects can have real banding issue.
Fo me it's just trying stay in focus with people going over the water at 50MPH then they jump and excelerate to 60 or 70 twisting and turning with heavy water splash thet fools the camera's focus system.
This is why CASE 2 on the 1DX seems good as it stays on the subject even when an object gets into view but NOTHING is perfect.
I posted this shot before but it's a classic example of Focus, then editing to get blemishies on a model's face, using lum, clarity and spot removal while trying not ruin the continuity.  I think I'll try noise Ninja.   Thanks for the suggestion!
Perhaps noise Ninja will help on some of the noise here.  This was shot using IS on setting one but sports is a different game.  I WISH my sports shots all came out close to this....  ONLY in a perfect world!
TV
