now they are going to give the d800s a new battery
Started Jun 6, 2014 | Discussions
azotor Forum Member • Posts: 57
I wish they could stick with EN-EL15.
It's a powerful little battery. Maybe not to weak for EXPEED 4?
 azotor's gear list:azotor's gear list
Fujifilm FinePix X100 Nikon D700 Nikon D4 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF +10 more
Nikon D800
stevo23 Forum Pro • Posts: 19,771
Re: now they are going to give the d800s a new battery
Link?
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
PatrickP Contributing Member • Posts: 716
Geeze. That's a small thing. But enough of a dent for some D6x0/800 users to re-consider an upgrade, especially those who have a ton of EN-EL15s. (I have 3 myself) Nikon rarely change battery type from a original model to a 'S' model.
Unless they call it D810 instead, which is likely. My gut feeling is this would be a big enough upgrade to deserve a different model number.
D800E, 16-35/4 VR, 24-70/2.8, 70-200 VR2, AF-S 80-400VR, 50/1.8G, 85/1.8G.
 PatrickP's gear list:PatrickP's gear list
Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon 85mm F1.8G Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR +8 more
Canadianguy Senior Member • Posts: 1,845
Source please?
Murray Bowles
Murray Bowles Senior Member • Posts: 2,122
Remember, their stated goal is higher margins.
Simon Garrett Veteran Member • Posts: 6,025
Are you making that up?
Are you making this up, do you have a source (in which case what is it), or is this an inspired guess?
Simon
 Simon Garrett's gear list:Simon Garrett's gear list
Nikon D800
ImageAmateur Senior Member • Posts: 4,741
IF True, whatever your source, likely it is just what you say, the specs of the camera re data shifting is so much more and with 6 fps, it may need the additional power amps.
Wishing You Good Light.
 ImageAmateur's gear list:ImageAmateur's gear list
Nikon D4 Nikon AF-S Nikkor 24-70mm f/2.8G ED Phase One Capture One Pro
ScottRH
ScottRH Senior Member • Posts: 1,745
D750 ?
michaeladawson Forum Pro • Posts: 12,532
I highly doubt it.  The most likely scenario if the really do use a new battery would be EN-EL15a.  This would be compatible with the current battery.  Similar to the EN-EL18a that was shipped with the D4S.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D810 Nikon D7200 Nikon D5 Fujifilm X-T2 Fujifilm X-H1 +28 more
larrywilson
larrywilson Veteran Member • Posts: 6,400
Where is this information coming from?  This is the first time I have seen that the d800s will have a different battery than the d800.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 85mm f/1.4G +7 more
diverroy
diverroy Contributing Member • Posts: 728
He is obviously making it up as he cannot be bothered to reply
Diverroy
I guess so.  He's posted elsewhere since, so it's not as though he's been away from his computer and unable to reply.
Simon
Nikon D800
M Lammerse
M Lammerse Forum Pro • Posts: 11,429
Only one answer possible of course on such kind of question,
It depends on which version of the EXPEED 4 processor you mean.
Michel
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 15,937
Re: So what?
The D4s has a new higher capacity batter which works with a D4 and users the same charger.
If Nikon get more capacity in a same size D800 battery using the same charger is there a problem?
Leonard Shepherd
Producing good quality photographs, or being good at sport or art, involves a little more than buying appropriate equipment. Practice, some learning and perhaps natural talent often play a bigger role than the equipment in your hands.
Nikon D810 Nikon D7200 Nikon D500 Nikon D850 Nikon Z7 +24 more
larrywilson
Re: So what?
There is a problem if they change chargers or worst yet if a person can't use the same Nikon battery grip with d4 battery.  The price Nikon is charging for the d4 battery charger and battery grip is insane.  Actually I have heard nothing about what battery the new d800s is going to have so may not be a problem at all.  For the OP to say that they are going to be using another battery without references to where he got the information, sounds a little premature to even mention it.
Larry
Nikonparrothead Veteran Member • Posts: 5,512
Re: So what?
Larry
D4 battery grip? Last I checked the "grip" in the D4 was built in.
'Nice pen, bet you write good stories with it.'
 Nikonparrothead's gear list:Nikonparrothead's gear list
Panasonic Lumix DMC-TZ1 Canon PowerShot S95 Fujifilm FinePix X100 Nikon Coolpix A Panasonic LX100 +14 more
Rich Rosen Senior Member • Posts: 2,505
Re: So what?
Nikonparrothead wrote:
Larry
i think he meant the MB-D 12 for the D800 which takes the battery for the D4 .
 Rich Rosen's gear list:Rich Rosen's gear list
Nikon D1X Nikon D500 Nikon Z6 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Teleconverter TC-14E II +20 more
Leonard Shepherd
Re: So what?
While as yet there is not even an announcement of a body upgrade the D4s and D4 use the same charger.
Leonard Shepherd
Re: So what?
Ah, thanks.
OP azotor Forum Member • Posts: 57
thank you all for your opinions.
I don't have any source. It's just a wild guess.
