24mm wider on 24-105 than 24-70
Started Jun 5, 2014 | Discussions
Colinbrowne New Member • Posts: 4
I just got myself a second hand 24-70 f/2.8L, I already own a 24-105 f/4L. On doing some tests and comparisons I found that 24mm on the 24-70 isn't quite as wide as the 24mm on the 24-105, even though the metadata is showing 24mm on both lenses. They are about 3 or 4mm off from each other.
Has anyone else noticed this or could shed some light on how this is possible?
 Colinbrowne's gear list:Colinbrowne's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EF 35mm F1.4L USM Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM +3 more
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
Re: 24mm wider on 24-105 than 24-70
All zoom lens are longer than their stated focal length at the wide end and shorter than their stated focal length at the tele end. 5% off is considered acceptable. Everyone cheats on this.
I think the 24-105 has more barrel distortion that pulls in the corners, making its diagonal field of view wilder.
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
Abu Mahendra Veteran Member • Posts: 5,312
Nominal is very frequently different than real. Simple as that.
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
BozillaNZ Regular Member • Posts: 346
Besides above explanations, you also have to take the length of the lenses into consideration. 24-70 is at it's longest when in 24mm but 24-105 is at its shortest. This has the effect of stepping back a bit when using the latter, which also expands it's view
 BozillaNZ's gear list:BozillaNZ's gear list
Leica D-Lux (Typ 109) Canon EOS-1Ds Mark II Canon EOS-1Ds Mark III Canon EOS 7D Canon EF 24mm f/1.4L II USM +7 more
Just another Canon shooter
Just another Canon shooter Veteran Member • Posts: 4,691
Make sure that you focus near infinity in your tests. Why don't you post some examples?
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +4 more
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,870
Compare useable to useable
You might find the 24-70 wider.
Rick Knepper, photographer, shooting for pleasure. It is better to have It and not need It than need It and not have It. Various RAW comparisons at Link below. Includes 5D3 vs D800E (new uploads), 5D3 vs. 6D, Zeiss lenses etc. https://app.box.com/s/71w40ita6hrcfghojaie
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Sony a7R IV Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +11 more
