One screenshot of SW part for something larger than large
Started Jun 5, 2014 | Discussions
Luisifer
Luisifer Contributing Member • Posts: 631
my gradual development
Hope that it is understandable
 Luisifer's gear list:Luisifer's gear list
Canon EOS 5D Mark IV Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM Canon MP-E 65mm f/2.5 1-5x Macro +13 more
l_d_allan
l_d_allan Veteran Member • Posts: 5,093
Re: One screenshot of SW part for something larger than large
Guess I'm being slow here.
Stool manager?
 l_d_allan's gear list:l_d_allan's gear list
Panasonic Lumix DMC-TZ3 Panasonic Lumix DMC-FZ47 Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 600D +27 more
Luisifer
OP Luisifer Contributing Member • Posts: 631
It is software part of device automatically digitizing large format sheet film via DSLR with macro lens (MP-E) piecewise (on screenshot in matrix of rectangles one rectangle = one shot / digitized part)
Luisifer
and one draft of "stool bones"
- free space from bottom is for strobe light
- top construction will hold the camera with macro lens
- "gold board" will hold the sheet film movements (stepper motors, linear guideways, gear racks, etc.)
wackybit Senior Member • Posts: 1,058
I'm in the process to build the same thing!
but instead of sheet film, my set up is going to have a 35mm or medium format film holder where the camera can 'scan' several frames in one go.
I'm excited to see how yours turn out
Luisifer
I'm also curious.
And with some light modification (and glass holder) there will be possible to digitize smaller formats too.
To the draft i added the most expensive parts. It is necessary to save a bundle to them but hope some months later they will be sent to me from the store
l_d_allan
Soooo ... this project is intended to be a replacement for a "drum scanner" for medium and large format film?
Interesting, and hope it works out.
Luisifer
At the beginning there were idea to digitize (only) sheet film with available equipment (ff dslr + flash + macro lens + computer) with relatively minimal additional budget.
When i tested it "on my knee" i found out that i can not move the sheet by hand and it is necessary to automatize it.
And with automation it is possible to do it in "extreme mode" with making of thousands shoot parts from one sheet with the 5:1 magnification.
The unnecessarily large resolution from this digitization will be used for "transfer" to high bit depth via downsampling.
test "on my knee":
Luisifer
Some news:
now i know the maximal size of possible digitized sheet film. This size is 12x20" given by length of linear guideways which i just ordered.
Luisifer
one grouping for an example
Luisifer
hands test...
I found that there is necessary to exchange one trolley from ZA version to ZF version without passive resist
and get couple of better cables...
Luisifer
two parallel rails are already fastened to the base plate:
Luisifer
Some week later
Luisifer
Two more photos on the end of the week
Luisifer
And one more screenshot of updated webapp.
changes for some parameters to enumerated (like magnification), changes of way back from time parameter to speed parameter, etc.
On this screenshot is setting for 12x20" sheet film digitized on 5:1 magnification with number of frames and expected duration of digitizing.
Luisifer
First test via mobile:
http://youtu.be/dgYHI-oEI34
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
A scan order suggestion...
Most people scan in a simple raster, but that can cause issues....
When I do automated scanning (e.g., using a camera on a computer-controlled telescope mount), I always use a space-filling curve with higher spatio-temporal locality rather than a raster. Think Hilbert/Peano or Z curves.  Just a suggestion....  I think Gigapan still uses a simple raster, so if you don't wnat to deal with the fancy scan orders, you're still in good company.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Luisifer
Re: A scan order suggestion...
I expect to use the raster (x1, y1; ...; xn, y1; x1, y2; ...; xn, y2; ..... ; xn, yn). But there is no problem to add some other orders if these orders will be better.
Which issues do you mean?
I expect to use autopano giga and files will be with applicated flat frame.
ProfHankD
It's more critical with a potentially changing scene, but even with a fixed scene and lighting you can accumulate small positioning errors and lighting can slowly change (due to bulb life, heating, etc.). Using the kinds of orders I suggested minimizes the impact of such variability.
Luisifer
Vacuum tube has about 100k flashes life period.
I expect flash light (but studio flash is still only on budget queue) with power controlled over application where will be one flat frame for each row => new flat frame after about 100 frames max. (after 50 frames on average)
And flash unit about 500Ws with enough distance from hole with part of digitized film => minimal (or without) temperature impact (power of the flash set close to minimal and active cooled flash unit).
