Arca Swiss Clamp for OMD-EM10
Started Jun 3, 2014 | Discussions
Virtual Photon Contributing Member • Posts: 848
Any suggestions for an Arca Swiss compatible clamp for the OMD-EM10?
 Virtual Photon's gear list:Virtual Photon's gear list
Olympus E-M1 Nikon D500 Olympus PEN-F Olympus E-M1 II Nikon Z7 +9 more
Elix Regular Member • Posts: 298
Re: Arca Swiss Clamp for OMD-EM10
http://www.reallyrightstuff.com/OM-D-E-M10/BOEM5-Plate-for-OM-D-E-M10.html
 Elix's gear list:Elix's gear list
Sony RX100 Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 +3 more
OP Virtual Photon Contributing Member • Posts: 848
Thanks!
Brian D. Schneider
Brian D. Schneider Forum Pro • Posts: 18,225
Thanks!
I have the one for the EM1, it feels & looks like a part of the camera. I never take it off.
You can also get an end plate to allow vertical pics.
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,428
Someone else answered you, but it is worth mentioning that you mean "plate" or "bracket" ... the clamp is the part that sits on top of the ball head (or rails or whatever you mount the camera to) and "clamps" the plate securely.
I own several aftermarket clamps so I can mount cameras to all sorts of apparatus ... in fact, as the result of looking for an image of a clamp, I just bought a new one from eBay for 12 bucks ... I'll be curious to see whether it is any good ...
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F770EXR Nikon D600 Nikon D7200 Panasonic Lumix DMC-GX85 +17 more
dv312
dv312 Veteran Member • Posts: 8,076
L clamp
 dv312's gear list:dv312's gear list
Fujifilm X-T2 Fujifilm X-T3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 Fujifilm XF 35mm F2 R WR +1 more
I am corrected   I meant plate, not clamp.
Brian D. Schneider
Re: L clamp
dv312 wrote:
I got one of these from China, strong and safe , much cheaper than RRS
http://www.ebay.com/itm/L-grip-Quick-Release-Plate-Bracket-for-Arca-Swiss-E-P3-E-M5-GH4-E-M10-GX7-X-E2-/201094691952?pt=LH_DefaultDomain_0&hash=item2ed22d7c70
But not nearly as nice
dv312
Re: L clamp + optional grip
I have the optional grip on the EM10
Not sure it 'd work with the RRS grip
it works fine with the L grip from China, granted it's not as good looking , but functional
RSS says it does't, although it's referenced as 'battery grip'.
Gerry Siegel
Gerry Siegel Senior Member • Posts: 1,913
Thanks!
I agree.  RRS plates are not super duper ineexpensive but are designed with care in mind for the camera.  Not too much superfluous metal and strong Arca Swiss dovetails. Also don't ingnore that the plates which fit snugly under the basic camera have spaces for getting at the battery chamber and have a threaded screw in the lens center which is not so on my E-1 itself....thoughtfulof them.  Also has a spare 1/4 thread for a sling strap for these small cameras.  As to the L portion adapter.....I may not buy it.  I like the little sitting stability the base plate adds to the camera without adding just a smidgin of weight.....AND if you don't like it, send it back within 30days///   made in the USA if that is of some import to you.....enjoy!  Costly camera deserves solid accessories IMO....gs
 Gerry Siegel's gear list:Gerry Siegel's gear list
Fujifilm FinePix Real 3D W3 Panasonic ZS100 Olympus E-3 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GX7 +3 more
