EPM2 or EPL5?
Started May 30, 2014 | Questions
Bas Hamstra Senior Member • Posts: 2,071
EPM2 or EPL5?
My EPL1 died (LCD cracked after drop). So I am looking for replacement, with the better 16MP sensor. I a in doubt between EPL5 and EPM2 (price nor far apart).
The EPM2 is a bit lighter, but I am worried about "handling", would not like to dive in menu for setting exposure comp and aperture. EPL1 was not ideal in that area either, but I got used to it.
Bas
 Bas Hamstra's gear list:Bas Hamstra's gear list
Canon EOS 5D Canon EOS 6D Olympus OM-D E-M10 Olympus E-M1 II Canon EF 35mm F1.4L USM +11 more
Olympus PEN E-PL1 Olympus PEN E-PL5 Olympus PEN E-PM2
Olydude Regular Member • Posts: 259
Re: EPM2 or EPL5?
The EPM2 and EPL5 have the same drawbacks, one control wheel, 2 point IBIS, but the EPL5 has an extra programmable button, is better constructed out of a hard polycarbonate casing rather than plastic and has a better LCD screen from a viewing standpoint.
The EPM2 is quite cheap at the moment, but I would either buy the EPL5 or wait for the EPL7.
 Olydude's gear list:Olydude's gear list
Olympus PEN E-PL5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 12mm 1:2
(unknown member) Regular Member • Posts: 221
Re: EPM2 or EPL5?
If price is similar I would say definitely get the E-PL5, especially for the tilty/flippy screen.
Benefits of EPM2
- Slightly small and lighter (but not by much!)
Benefits of EPL5
- Tilting and articulating LCD - it even does a 180 for a selfie!
- Mode dial
- one addtional Fn button than EPM2 (not 100% sure about this - One next to the magnify button ?)
Edwaste Senior Member • Posts: 1,036
Re: EPM2 or EPL5?
The EPL-5 body is mostly metal. It also has a tilting touch screen similar to the OMD-EM5. Great for working on a tripod. Just lightly touch where you want the camera to focus on and the EPL5 will focus there and activate the shutter.
 Edwaste's gear list:Edwaste's gear list
Sony Alpha DSLR-A850 Olympus OM-D E-M5 Olympus PEN E-PL5 Olympus E-M1 Sony a7 II +2 more
sigala1 Veteran Member • Posts: 3,911
$199 for E-PM2, can't beat that
Bas
The E-PM2 has been selling for $199 with kit lens, and the extra price of the E-PL5 can't be justified given that it's an identical camera except for a mode dial and a tilting LCD. (And some minor differnences that are ENTIRELY COSMETIC and have nothing to do with image quality of functionality.)
Given the current price of the E-PL5, it's better to step up to an E-M10 if you want the best Olympus camera. Or consider the E-P5 which you may find at deep discount at some lower-tier sellers.
.Sam.
.Sam. Veteran Member • Posts: 3,199
Re: EPM2 or EPL5?
I would go for the e-PL5 for up to $100 extra.
The screen on these (16x9) are practically useless. The actual image is smaller than my 5-year old GF1, and very hard to see in sunlight. Hence, the e-PL5's tilting screen would be very useful.
As someone said, the em10 maybe a better buy these days, since it has a "working" in-body-IS. The one's in the e-pm2/e-pl5 should be turned off to get good pictures.
.Sam.
GF1+20+45 Sigma DP2 & Pentax K20D - ist* DS - ZX-5 - LX
Photos: http://www.flickr.com/shadzee/
 .Sam.'s gear list:.Sam.'s gear list
Sigma DP2 Pentax *ist DS Panasonic Lumix DMC-GF1 Olympus PEN E-P5 Panasonic Lumix G 20mm F1.7 ASPH +7 more
GeoJManning New Member • Posts: 2
Re: EPM2 or EPL5?
I actually had both in my hands earlier this week. They're similar, but the EPL5 is easier to use because you don't need to go through the menu. I've found that I use the tilt screen all the time to help me compose, and I immediately missed it.
Having said this, the sharp increase in ease of use from the EPM2 to the EPL5 makes me think that an OMD will be even better. Maybe next year I'll make the leap.
 GeoJManning's gear list:GeoJManning's gear list
Olympus PEN E-PL5 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 Panasonic 20mm F1.7 II
QuakeO Regular Member • Posts: 166
Re: EPM2 or EPL5?
I have the e-pl5.
Today I would buy the e-pm2 at $199 and plan to keep it as backup, then keep a lookout for a deal on the e-pl5 -- or better -- and buy when the price is right.
 QuakeO's gear list:QuakeO's gear list
Panasonic Lumix DMC-GF3 Olympus PEN E-PL5 Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +5 more
pocketpygmy Contributing Member • Posts: 829
Re: EPM2 or EPL5?
neither. wait for the E-PL7. check out the leaked manual:
http://www.43rumors.com/ft5-olympus-e-pl7-manual-leaked/
as someone else mentioned, both the epm2 and epl5 have 16:9 screens -- one of the most bone-headed design decisions possible. makes for a very small viewing area if you're using a proper aspect ratio like 4:3 or 3:2 or 1:1.
if we're to believe this illustration, it looks like olympus noticed their errant ways. they've also added a control ring around the shutter -- far better than the fiddly ring on the backs of the epm2 and epl5.
since you mentioned useability rather than price as the (implied) higher priority, i wouldn't bother with 'good deals'. i've gone down that road before and regretted it, wishing i'd just had a little more patience for the better (if higher priced) product.
Bas
Helen
Helen Veteran Member • Posts: 7,606
Re: EPM2 or EPL5?
I have both models and I wouldn't say you have to go through the menu on the E-PM2, either.  Both have the Super Control Panel and though the E-PM2 lacks a mode dial, it's very easy to change mode as you just touch the mode indication in the corner of the screen to change it.  However, the lack of a mode dial does mean it cannot offer the useful feature of being able to place custom Mysets onto the positions of the mode dial, if required.  And as you mentioned, it's lacking the E-PL5's tilt screen.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: EPM2 or EPL5?
Bulkier camera, would not work for me at all. My little bag fits two E-PL5 with lenses, no way it could fit the bigger E-PL7.
16:9 screen is fine, just shoot RAW+jpeg and the 16:9 jpeg shows you good detail on the LCD, then retrieve whatever you want from the RAW, usually 16:9 anyway as that is the shape of all TV and monitor screens now.Regards... Guy
Re: EPM2 or EPL5?
not sure this is about you. your very particular situation of (a) two m4/3 cameras in one bag (??) precluding you from considering a camera that hasn't even been officially announced and whose overall physical differences from the epl5 will in all likelihood will be negligible anyway, and (b) excusing an obviously bad design decision with an equally unintuitive workaround -- just isn't in the least bit universal or applicable to the general user. really a puzzling response, not sure what the OP is expected to glean from it. sorry.
Guy Parsons
Re: EPM2 or EPL5?
I'm sorry that I spoke.
Anyway, the E-PL5 is recommended over the E-PM2 mainly due to the tilt screen.
Regards..... Guy
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,444
piece of cake ...
I leave my EPM2 in A prio mode, so when I switch it on I can touch the top or bottom of the ring to set aperture and left or right (or spin) to set compensation. It does not get easier than that.
While I loathe the Oly menu system, the super menu takes most of the pain away. I must prefer seeing the settings and clicking them over remember what functions are mapped to what buttons.
Considering the price right now, you would really have to want the minor extras on the EPL5 to go that way. But obviously some on the forum do ...
Note: I shoot the EPM2 with primes and the GM1 with its kit lens. It's a toss up as to which I would go with were I carrying only one, but the GM1 would probably have the edge.
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F770EXR Nikon D600 Nikon D7200 Panasonic Lumix DMC-G7 +27 more
Guy Parsons
Re: piece of cake ...
Two big things make life better with the E-PL5, first being the tilt screen. That makes awkward down low shots easy and also removes 90% of screen reflections.
Next is operational, mapping the MySets to the Mode dial makes for a very easy way to drive, lessens menu diving and SCP diving dramatically = ease of use and less mistakes.
Regards..... Guy
Kim Letkeman
I am fully aware of the differences as you go upward in a family of cameras. And yet I recommend the EPM2 anyway. Imagine that.
OP Bas Hamstra Senior Member • Posts: 2,071
Thanks all
I see that in the USA the EMP2 goes for 199$ via some weird ebay construction, and I admit that's a no brainer. But no such luck in Holland, where EPM2 and EPL5 go both for around 400EUR. Calculated in dollars, that's 544$!
I think I will wait a bit for a better deal for the moment, as 400EUR doesn't seem right...
Bas
Kim Letkeman
Re: Thanks all
If you aren't freaked out by buying used, you might try a body from KEH.com ... EPM2 is $325usd shipped to a suburb in Amsterdam (just used as an example.) That's a whole lot less Euros ...
traveler_101 Senior Member • Posts: 2,203
Re: $199 for E-PM2, can't beat that
Bas
Exactly my logic when I went for the E-PM2 recently. It is in part a question of relative value. I wanted the E-PL5 but couldn't justify paying so much more for it considering what you ge for the money.
It is also a question of what you are looking for. I seriously considered buying a E-P5, but chose not to because it is a much heavier and quite a bit larger camera; it is the same size and 25% heavier than my old E-P1. I wanted to buy a really small camera, but one that also has/takes an electronic finder.
If your size / weight proportion are more flexible, you should definitly consider the E-P5. But then the question of value kicks in again, i.e. if you're going to spend that kind of money for a E-P5, perhaps it makes sense to get a E-M10 with the built-in electronic finder?
I like my E-PM2. It is incredibly light and customisable enough for my use. It lacks the solidity of a metal camera, but it is not "cheap" in the hand either.
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Re: Thanks all
Hi Kim,
In fact I buy a lot of cams used, just got an S90 for 80 EUR, with extra battery and belt-pouch (easy to wear while skating). Right now I have an option on a used EPL5 for 300EUR, I think I go with that one.
When bying used, I always pick it up in person from the seller, that works brilliant, I have never been disappointed so far.
Bas
