Copying photographic prints
Started May 27, 2014 | Discussions
gregbartgis
gregbartgis Regular Member • Posts: 262
I want to copy B/W prints made from film negatives taken years ago. I have both prints and the negs, Does anyone do photo reproduction with their MFT kits? I'll be using an Oly E-PL1 with 60mm f/2.8 macro. I own several tripods with reversible center posts. This seems my best option for the time being. Any suggestions? The prints are either 11"x14" or 8"x10". My printing technique was rather dense. I may have lost too much shadow detail, but  how do I extend tonal scale to its absolute limit? Part two of this question is about copying negs. First of all - how do I get reversals using LR5 or Aperture? Can this be done with these - or should I consider yet another editor? Once converted to positive images, what is best for obtaining long tonal scale prints and anything else I've forgotten toask about? All suggestions will be greatly appreciated. THANKS!!!!
The elimination of the mirror has introduced a new concept into the interchangeable lens digital camera market - compactness (kind of like what happened when Oscar Barnack created the Leica).
 gregbartgis's gear list:gregbartgis's gear list
Voigtlander Nokton 17.5mm F0.95 Aspherical Olympus PEN E-PL1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +44 more
Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus PEN E-PL1
Klarno
Klarno Veteran Member • Posts: 4,239
Re: Copying photographic prints
I think getting the camera level enough to have optimum edge-to-edge resolution for copying negatives will be near to impossible in this case, unless you've got a really nice geared head. You'll want a cable release or to use the timer on your camera to make sure you're not shocking the camera from pressing the shutter button. You also need a backlight source for copying film. Your best bet would be a copy stand paired with a daylight balanced lightbox (for this purpose I've used my GH2 with an OM 50mm f/3.5 macro and gotten printable results off silver negative and slide film, though I wouldn't recommend anything but a dedicated scanner for color negatives).
OM-1, 50mm f/1.8, Tri-X 400 downrated to 200, negative copied using the above method.
OM-1, 28mm f/3.5, Velvia 50, slide copied using the above method.
To reproduce prints, you need even, soft, color balanced lighting across the frame. I use two strobes with umbrellas at 45° angles to the subject. The first copy stands you'll find in an internet search actually include the light sources, but the setup I use also works for reproducing larger format artwork.
Make use of the histogram or shadow/highlight blinkies. The white of the paper needs to be the brightest thing there, perhaps backed off just slightly from being blown out.
Inside Lightroom, there's an area to adjust the tone curve. Start with a neutral tone curve, click the button for point curve, drag the top left corner all the way down, and the bottom right corner all the way up. From there, season to taste.
Of course, with negatives, the thinnest part of the image with the least information will be the shadows, so be careful not to overexpose your capture. And you'll need to find a way to control flare- I actually use a large cardboard tube as well as a negative carrier from an enlarger to accomplish this.
Here's a basic look at what my setup looks like for slide copying (from when I had it set up on my E-520):
Hot shoe bubble level for level, the cardboard tube in the background would go between the lens and the negative carrier and would keep light from the rest of the light box from causing flare. Giottos rocket blower 'cause dust will happen.
I never photographed the setup as used on my GH2, but instead of the ball head I used a macro focusing rail (modern copy stands have macro rail functionality built in).
If you use a fluorescent lightbox, be mindful of the power grid you live in. You'll want to make your shutter speed multiply evenly into your power frequency or else you'll get uneven brightness across the frame. so if you're on a 60Hz grid, you'll want to shoot for shutter speed of 1/60, 1/30, 1/15, 1/8, 1/4 and so on--not the steps in between--if you're on a 50Hz grid, you want 1/50, 1/25, 1/13, 1/6, etc.
 Klarno's gear list:Klarno's gear list
Sony Alpha NEX-6 Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +9 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Film to camera
First fact, the 12MP E-PL1 is a bit of not quite good enough for film copy, I gave up with mine long time ago, but when the 16MP E-PL5 camera along then the results are a world apart. Cheap E-PM2 a good idea?
Second fact, reversing B&W negs is straight forward, but colour negs are a total nightmare, best to use a real film scanner for them.
My current film to file setup is this.....
E-PL5 with 60mm macro, FL-LM1 in RC mode, FL-36R in RC TTL mode. Jpeg Natural with Saturation, Contrast and Sharpness all at -1 and Gradation Auto gives me a good idea of how the RAW file will work. Blinkies on review reveal any weirdness and use flash comp to adjust, mostly left at plus 1.3 in my case, sometimes a bit less.
No need for delays or remote releases as (with a little bit of ambient light on the slide) the AF is fast and accurate and the flash pop so quick that shake issues don't figure at all.
Touch screen shooting on a part of the slide/film that has good contrasty edges, never misses even with quite low ambient light on the film.
I am truly getting all that is worthwhile off the film when using the 16MP sensor, can make old dense and murky slides come to life and see detail that I could not see when projected.
The camera sits on a screw thread macro slider, some old Velbon thing, still made but more plasticky now, don't know how old and new compare.
To download I use the USB cable. Of course if the battery goes flat then I have to upset everything to change it.
The thick aluminium channel holds everything in steady alignment, the (keeps varying in style and purpose) centre jig now is holding slide and strip carriers from my Microtek film scanner, but the jig also holds an old slide projector 2 slide push-pull holder for both 35mm and medium format sizes.
A piece of milky white acrylic sheet diffuses the flash a bit, it is sprayed black on camera side except for a 36x24mm window for the light.
I've also used the Nikon ES-1 on the front of the 35mm macro lens for good slide copies but prefer my rig shown above as it can do everything and holds the TTL flash nicely in place.
As for prints, I usually scan them on a flatbed, even a cheapy Brother A3 size one does OK for bigger ones but when critical the Epson V700 does OK for up to A4 size. Silky grain prints are a nightmare and then careful diffused lighting and the camera are the only way to avoid shiny bits.
http://scantips.com/es-1.html  is helpful for slides/film to camera info.
Regards....... Guy
BillJolly Forum Member • Posts: 67
Klarno and Guy Parsons have both suggested that you not try to copy color negs with your camera.  I copied my old slides, color negs and bw negs with my GH2 and 50mm lens.  The process for color negatives is a little different, but simple.  In short, I did a custom white balance on a blank negative first.  Then just copy the neg as usual, use the 'negative' operator in any graphics program and adjust the levels ( because the results are usually quite thin ).  My results look fine to me.  Hope you have good results.
pocketpygmy Contributing Member • Posts: 829
the classic text in this area of study is of course walter benjamin's 'the work of art in the age of mechanical reproduction', or, better yet, 'the work of art in the age of its technological reproducibility' (not an insignificant distinction for anyone who gives a sheyt).
watch out for that aura!
Klarno
Perhaps I should clarify the reasons why photographing color negatives is less than ideal-- with dedicated flatbed scanners you're getting 16 bit output (65,536 levels per channel), as opposed to 12 bit RAW on your camera (4096 levels per channel is the best the vast majority of cameras can bring to bear). This means that you have that much more leeway to work with things like the orange mask on color negative film-- you'll notice the 12 bit image getting pulled apart at the seams a lot faster than you'll notice the same thing happening to the 16 bit image. Some cameras offer 14 bit (16,384 levels per channel), but such things haven't worked their way into MFT yet.
The orange mask isn't a constant density filter; it actually forms in the development process in proportion to the other color dyes (it's there to correct for the inherent blue sensitivity of all color emulsions in color process papers). So I've actually found it to be nearly impossible to get accurate colors out of using a blank negative or film leader as a calibration step. You can get close, but I've found not close enough.
Your best bet to copy negatives with a camera is to use a dichroic enlarger head as your light source; a dichroic head is a special kind of enlarger that's used for optically printing color negative film. With that kind of head you can actually adjust the color balance of the light source quite precisely, which would make a great difference in getting more information in your images, leading to less noise and finer tonal gradations. You still need to boost contrast a lot though, because dye-based C41 films lead to very, very thin images.
TheEye
TheEye Veteran Member • Posts: 4,883
Dichroic enlarger head
I built my copying rig with an old LPL 35 mm /6x7xm dichroic enlarger head and a cross slide. Works like a charm. Filtering out the orange mask is no problem.
I copy B&W, color negs and chromes with this contraption.
http://www.dpreview.com/forums/post/36784654
gregbartgis
OP gregbartgis Regular Member • Posts: 262
Many thanks to all for your suggestions. The only color work I'll be copying will be chromes - bot E-6 and Kodachrome. I have a Phillips head for color enlargements that I can somehow adapt to use here. The light source has a dial control for balancing color. Most of my earlier work was done in B/W. Thanks for the book suggestion. I'd like to get it! Sounds like a really good read!
Thanks again everybody!
Guy Parsons
Colour negs
Mucho fiddling with colour neg copies via camera and not lots of success.
Using RAW and curves to set each RGB channel appropriately to make the neg to positive seems to be a good approach, but I think I'll revive my film scanner to make life easier, now where did I put that SCSI card?
Googling about found this page that tells the story and why I have problems.....
http://www.marginalsoftware.com/HowtoScan/DiscussionsTone/scanning_color_negative_film.htm
Trying to make a curves set to extract the channels properly is a real problem, and did get quite close on a few, but oh so painful to get something I liked.
I had forgotten what rubbish film is. All that grain, we'd be really angry muppets if our m4/3 cameras were that bad at base ISO.
Regards........ Guy
