What is "Foveon Blue"?
Started May 26, 2014 | Discussions
PicOne
PicOne Veteran Member • Posts: 6,932
I used this color mode on the below photo, and see what it does to colors, but where did this term originate and what does it reference?   Did the old sigma cameras used to show this color as the default rendition.?
'Everything in photography boils down to what's sharp and what's fuzzy.'
-Gaylord Herron
Lin Evans
Lin Evans Forum Pro • Posts: 17,702
Re: What is "Foveon Blue"?
The term actually references the blues from the original SD9 which tended to produce some very deep blues. In some cases they were spot on the color as seen by the human eye and in other cases the blues were pretty but not natural.
Below is an actual sample from my SD9 which is very close to the actual appearance of the sky on that day...
Original color from SD9 - close to reality in this case....
Best regards,
Lin
SandyF Forum Pro • Posts: 15,093
For PicOne, the SD10 can do the "Foveon Blue" too, for example http://www.pbase.com/sandyfleischman/image/34322272
I had many 'intense' blue skies with the SD10, even in Washington, DC light. Out west, skies could be spectacularly blue... without a polarizer! First, I recall many people complained that those skies weren't 'real' then when the SD14 came out and the skies toned down, people complained that the skies weren't blue enough LOL. The "Foveon Blue" setting is something recent in SPP which may (or may not) emulate that intense blue.
One of the classic "Foveon Blue" shots for me is this early SD9 photo
http://www.pbase.com/sphomphanh/image/14167857/large
Best regards, Sandy
http://www.pbase.com/sandyfleischman (archival)
http://www.flickr.com/photos/sandyfleischmann (current)
 SandyF's gear list:SandyF's gear list
Sigma DP2 Sigma DP1 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill +9 more
JohnLindroth Senior Member • Posts: 2,907
I bought an SD9 with the original 1.0 firmware, and the skies were very similar to your photo, where skies were more magenta. I don't have a Merrill camera, so I don't know what the Foveon Blue does in practice, but it should be more like this:
It still has some magenta in the skies in this photo
http://gallery.johnlindroth.com/
john@johnlindroth.com
My future starts when I wake up every morning ...
Every day I find something creative to do with my life.
--Miles Davis
 JohnLindroth's gear list:JohnLindroth's gear list
FinePix XP70 Sigma SD9 Fujifilm X-E1 Sigma sd Quattro Panasonic Lumix DC-S5
dmaclau Veteran Member • Posts: 3,053
John.
In my experience with the DP3M  FOV Blue really snaps-up the blue sky, but it also throws a lot of yellow around.  I haven't had the time to figure out if there's a way around the yellow.  This might work for some images but not all.  It's a bit confusing though as it treats clouds OK but turns snow yellow...not a good look.
FOVBlue
FOVBlue
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Fujifilm X70 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
PicOne
OP PicOne Veteran Member • Posts: 6,932
Coincidentally, one of the other very few pictures I think I used the FOV Blue setting on, was also in SF area:
So if I got it right, Foveon Blue was what you used to get when using what was probably called the "standard" setting on the SD9 and SD10?   Did those cameras have a neutral setting?
Also curious, did the old SD9 and SD10 usually throw off the yellows in the same manner the Merrill's emulated Fov Blue mode does?
Best regards, Sandy
-Gaylord Herron
PicOne
Best regards,
Lin
Wow.. talk about "Pop Art"..  looks like a chunk out of a Warhol piece
-Gaylord Herron
Lin Evans
Best regards,
Lin
This was actually the second image I took with the SD9. It was one of those crisp, extremely cold fall Colorado mornings with the sky as deep blue as I've ever seen. I received the first SD9 availale in Colorado and eventually sold it to Laurence - I think he still has it...  I hope this answers the question about yellows. My SD9 did not mute the yellows in any way as can be seen by these yellow and gold Aspen leaves.
Best regards,
Lin
-Gaylord Herron
There are no 'standard' or 'neutral' settings on the SD9 & SD10, ie no colormodes; just pick your white balance. I usually used the SD10 in sunlight/daylight wb, very nice, without tending to yellow up as much as I find the SD14 and even DP2Merrill do in sunlight wb. As a generality, the only color occasionally a bit off could be intense reds, with the SD10 they can end up pink. I have some early pink ishcaboose shots on pbase (archival) in my SD10 gallery.
Another btw, the SD9 and SD10 only produced RAW, which is why we early or relatively early Sigma/Foveon users use RAW primarily and SPP generally. I learned everything about processing through SPP, starting 2004. Others here 2002; I recall the earliest commercial SD9 was available December 2002 I met Dick Merrill using one in October 2002 I have an 8x10 he took of me and printed at the conference. It seemed almost magic to produce and print such a photo in moments. At our conference in November 2001 at San Francisco, Foveon was still showing their prism (not CMOS sensor) based camera. I met Dick Merrill and Carver Mead then.
Best regards, Sandy
Best regards, Sandy
No, see above.
PS: My SD10 and SD9 work fine. The main reason I seldom shoot with them is their WEIGHT and heavy shutter, which causes me to 'wobble' as I put it, move causing motion blur. The screen is also historically small compared with any later camera.
I agree - it does affect yellows too
It's completely reproducible by converting to Lab mode, and make the b layer more of an S curve. My example didn't have any yellows in it, and it was from an Sd9, not a Merrill conversion to Foveon Blue.
--Miles Davis
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Hi john:
Yes I associate the Foveon Blue with the SD10 as the SD9 often had what you mentioned - the magenta cast.  I also think that the SD15 came close to that blue.  The bottom line, IMHO, is that through the years, the color has become more accurate but often requires work, and often a lot of work, to recreate the pop of the SD9 and SD10.  I can't think of how to define "POP".  It is not just saturation and it is not just contrast.  Or else it would be easy to recreate.  Perhaps tones?
Rick
http://www.rickdecker.photography
http://www.silveroaksranch.com
http://www.pbase.com/rickdecker
Never argue with an idiot. He will drag you down to his level and beat you with experience.
rick decker
My Apologies to Pic One
I inadvertently deleted his post when writing a response to John Lindroth.
Rick
Priscilla Turner
Priscilla Turner Senior Member • Posts: 1,957
'Blue' skies vary tremendously, not just from horizon to zenith, but according to temperature, altitude, latitude, time of year, atmospheric conditions etc. I've found my DP1 to be pretty good at all of the variations with which I've presented it!
'To see, not with, but through the eye.' [William Blake]
http://www.flickr.com/photos/22905474@N06/
 Priscilla Turner's gear list:Priscilla Turner's gear list
Pentax K-3 II Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 12-24mm F4.0 ED AL (IF) Tamron SP AF 90mm F/2.8 Di Macro +5 more
PicOne
Re: My Apologies to Pic One
Rick
Thanks Rick.   Appreciate the follow through.  No worries.
Best
-Gaylord Herron
PicOne
So, as a final follow-up.  Are the Neutral, Standard, and even Fov Blue settings that now exist in SPP, not available for these older cameras (grayed out)?
Best regards, Sandy
-Gaylord Herron
PicOne, no colormodes are available with the older cameras. Definitely not the SD9 and SD10. I just checked some old DP1 and DP2 X3F RAWs. No colormodes on the original DP1, but yes for the original DP2. So that seems to be the camera for which they were introduced. The DP1 and DP2 came after the SD14, so I assume no colormodes for SD14, but I have no RAWs to check on this computer. Yes for SD15 and all the Merrill cameras. For my cameras, the order of release is
SD9
SD10
SD14
DP1
DP2
SD15
DP2Merrill
One can fill in the s, x, SD1, other Merrill releases (those cameras I don't have). So again, colormodes seem to begin with the original DP2. FWIW I tend to use standard and landscape primarily, neutral sometimes and vivid occasionally. I haven't tried Foveon Blue often.
Best regards, Sandy
added: I found a SD14 X3F on this computer.... colormodes are not supported.
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
While Sandy was typing, I found this recent SD9 shot and opened it in SPP 5.5.3
Working space is ProPhoto, so ignore the color-picker numbers as to color accuracy vs. Macbeth
Color Mode is grayed out
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
xpatUSA
Just took this SD9 LO-res shot of my sky at about 8am local solar time:
Sunlight WB, no adjustments at all.
I do find that messing with various WB settings and the exposure comp. gives you almost any 'Foveon Blue' you want and, if you like a little purple tinge, open it in FastStone Viewer instead!
Which leads me to ask if 'Foveon Blue' has ever been defined in device-independent terms such as XYZ, Lab, Luv, etc?
And what is the correct WB for a blue sky?
Ted
xpatUSA
JohnLindroth wrote:
I bought an SD9 with the original 1.0 firmware, and the skies were very similar to your photo, where skies were more magenta . . . <>
Indeed, John, as we know, the processing makes quite a difference. See below for SPP 3.5 versus FastStone Viewer (which uses dcraw):
Won't insult our intelligence by saying which is which . . .
Ted
