Hand-strap PLUS shoulder-strap? 1000D
Started May 21, 2014 | Discussions
3dreal Senior Member • Posts: 2,271
Just go this hand-strap with base since my 1000D has only two connections.
But as you can see on upper right side its really not the right connection. It is not tight, will losen.
AND 1st: look at the screw on cam-base/tripod-mount. It is thin, no problem but rounded below. it has bad grip. But its working. maybe filing a bit to have grip...
2nd: look at the notch below the recycle bin-know. i had to file away a bit-did it too much-but it works). If not the notch is laying on the tiny ring around the knob, base not in touch with cam-base. I was very upset why the chinese are not interested to do it right.
Canon EOS 1000D (EOS Rebel XS / Kiss F Digital)
tr573 Senior Member • Posts: 1,329
Re: Hand-strap PLUS shoulder-strap? 1000D
Get a blackrapid mate - they make a wrist strap as well, so you can just swap on the connector for what you want.
OP 3dreal Senior Member • Posts: 2,271
You mean swapping from neck-strap to hand-strap? I have a good handstrap on an SLR but no neckstrap attached yet.
Wrist rather than hand (although serves the same purpose mostly) , but yes.   Blackrapid is a strap company - the straps attach to a little mount you screw into the tripod socket (it's basically just a little latch) and then attach to the strap with a carabiner.   They make shoulder and wrist straps, so you can swap back and forth easily depending on what you want at that time, whereas with that hand strap, you have to unbuckle all the pieces to put your neckstrap back on.
Thanks was watching videos.
I must get rid of that hand-strap. the rubberisch material is smelling-terribly stinking. skin contaminated! The one on 10s(slr) is of textile.  Any hint who can deliver one made of textile not rubber.
