Playmemories Home starting automatically
Started May 20, 2014 | Discussions
Renard DellaFave
Renard DellaFave Contributing Member • Posts: 796
Is there any way (Mac OS) to keep Playmemories from starting up every time I connect the camera?
Canon's software did that too, but you could disable it with a setting in Image Capture.
I see there is a com.sony.SonyAutoLauncher.agent.plist file in /Library/LaunchAgents and I'm guessing deleting that might do it, but just checking here first in case there's a more orthodox way to do it. There's also a folder in "/Library/Application Support/Sony Application Launcher" that I'm tempted to delete.
Sony's support chat says there is no way to disable it.
 Renard DellaFave's gear list:Renard DellaFave's gear list
Sony Cyber-shot DSC-F828 Sony Cyber-shot DSC-S85 Sony RX100 Sony Wx350 +2 more
FramerDave Contributing Member • Posts: 663
Re: Playmemories Home starting automatically
I don't see why the Mac version would be different from PC where you can just go into Tools and setting and uncheck the first import box and apply.
Renard DellaFave
OP Renard DellaFave Contributing Member • Posts: 796
The closest the Mac verison gets is a "Import with PMH when a device connected" checkbox under Preferences->Import.
Not sure what that does, as I have never left it checked.  I assume it stops auto importing, but it doesn't stop auto-launching of the main PMH app.
FolkLive New Member • Posts: 1
Hi FramerDave,
I wondered if you ever found a resolution to your Autolaunch issue? I have the same issue and would love to find a resolution.
FolkLive
droot New Member • Posts: 1
What worked for me is removing the file com.sony.SonyAutoLauncher.agent.plist from (HD)/Library/LaunchAgents. On connecting the camera Playmemories Home does not automatically launch, but can be started manually.
Bill Borne
Bill Borne Forum Pro • Posts: 36,827
I would think you can look in startup programs and disable anything related to sony??
 Bill Borne's gear list:Bill Borne's gear list
Sony Cyber-shot DSC-R1 Sony Cyber-shot DSC-HX400V Sony Cyber-shot DSC-H5 Sony Cyber-shot DSC-F828 Sony RX100 III +4 more
Bruce Dunkle Regular Member • Posts: 311
Hi Bill - I think Apple can solve your problem with their Support service.  I've got
a MacBook Pro, and every issue I've had has been solved using the chat function
available through Support.  They're very friendly and helpful.
Bruce
Bruce Dunkle
Bill Borne
Bruce
Buce I was just suggesting to ? I don't even have playmemories app.
Sorry, my post should have been to the original poster.
Bruce Dunkle
SciBob New Member • Posts: 1
This worked for me (Mac High Sierra). Don't forget you need to restart after deleting the Launch Agents. I found the agents were still active until I restarted.
texdpl Contributing Member • Posts: 770
On a Mac you find it under Playmemories Home Preferences .
Don L.
 texdpl's gear list:texdpl's gear list
Sony RX10 IV Sony a7 III Sony FE 28mm F2 Sony FE 85mm F1.8 Sony FE 55mm F1.8
Stephen McDonald
Stephen McDonald Forum Pro • Posts: 13,742
Why are you connecting your camera? Don't you have a card-slot or a card-reader?
Live view on a computer screen is pretty nice.
Don L.
DoC_Kildare New Member • Posts: 4
I have tried unchecking "Import with PlayMemories Home when a device is connected", but it still fires up when I connect my Sony a6500.  It looks to me like this is a bug with the software.
I have a twin battery handgrip attached to my Sony a6500 - so taking the media card out every time I needed to transfer images would be a royal pain in backside.  I used to do this with my Nikon 1 V3, but even with the handgrip that had it wasn't such a pain as the battery grip with my Sony.
Plus it is possible to connect to the computer with my Sony a6500 wirelessly to transfer images.
Yes it is.  Plus remote controlling the camera isn't bad either.  Even the mobile phone app is one of the best I've used for remote control too.
Rluizsm Forum Member • Posts: 82
You might try the following:
  • Open the Apple menu;
  • Go to "System Preferences" and then "System & Preferences";
  • Click on the "Login Items" tab;
  • Select the Sony PlayMemories Home (it should be there); and
  • Click on the "-" (minus sign) to remove it.
 Rluizsm's gear list:Rluizsm's gear list
Sony RX100 VI Sony RX100 IV Panasonic Lumix DMC-ZS40 (TZ60) Apple iPhone X
Sorry, I made a mistake. The correct is:
  • Go to "Users & Groups;
