NX30 electronic shutter
Started May 19, 2014 | Questions
Nakiphoto Contributing Member • Posts: 575
Is the NX30's electronic shutter silent? I've got to really like the silent electronic shutter on the V1. It's not a deal breaker if it hasn't, just keen to know....
As an aside; does the NX1000 have a silent shutter option?  Thanks!
Nikon 1 V1 Samsung NX1000 Samsung NX30
Iznogoud
Iznogoud Regular Member • Posts: 348
Re: NX30 electronic shutter
Hello,
No, the shutter is not silent and, AFAIK the electronic shutter is only used as a "trick" to reach 1/8000s shutter speed.
NX30's shutter is pretty quiet though with a rather low pitched sound IMO.
NX1000 has no silent shutter operation either (I have both).
OP Nakiphoto Contributing Member • Posts: 575
Iznogoud wrote:
Hello,
Thanks for that!!!
giliath Regular Member • Posts: 257
No, and I've never seen a apsc or ff camera which have pure electronic shutter. Now only small sensor cameras can have silent shutter.
 giliath's gear list:giliath's gear list
Sony a7R II Tamron SP 24-70mm F2.8 Di VC USD Sony FE 70-200 F4 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS
viking79
viking79 Forum Pro • Posts: 14,157
Most large sensor cameras use a focal plane shutter, this consists of two shutter curtains, a first/leading and a second/trailing curtain. They call them curtains because they go over the top of the sensor like a curtain slides in front of a window.
The NX30 does not have a rolling (like V1) or global "electronic shutter", it has an "electronic first curtain" shutter. Meaning, the first curtain is electronic (optionally), but the trailing curtain is mechanical.
So technically, the first curtain is silent, but the second curtain makes a shutter noise. You get about half the shutter noise with this setup vs mechanical first and second curtains. You can optionally enable a synthetic noise for the first curtain, since it can be disturbing for longer exposures that the camera doesn't make a noise until it is done with the photo.
The main benefits to the electronic first curtain are that it has much shorter shutter lag then a mechanical first curtain and the leading/first curtain doesn't introduce vibration into the image so you get less "shutter blur" (See Olympus and Sony issues with this).
Less shutter lag means the camera starts exposing the image quicker after you press the shutter release (good for capturing action shots in focus, first shot off is always in focus and subject hasn't moved much once the shutter starts opening). Only the NX20 and NX30 have electronic first curtains, but how Samsung implements the shutter, the others are still very quiet and don't have much lag.
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
viking79
Hello,
It isn't a trick, it has real world benefits of reduced shutter lag and vibrations from not using a first curtain.  When the first curtain opens it can introduce vibrations into the image as blur.  It can still use mechanical first as well, but as you say, you lose 1/8000.
Eric
Thanks everyone for your comments. Looks like a Samsung (maybe 2) is on my horizon.....
mcosmas New Member • Posts: 4
Bringing up an old thread here, but just curious. Is there any benefit of having the mechanical first curtain?
Kinger
Kinger Contributing Member • Posts: 549
E shutter can cause rolling shutter effect under certain situations and can be very ugly.
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
