Looking for example MRW files to add support to open-source software
Started May 18, 2014 | Discussions
PedroCR Regular Member • Posts: 155
Hi everyone,
I was the happy owner of a 5D as my first digital camera and have been recently improving the support for those files in Darktable, an open source photo workflow application that handles raw. To do that I've added support for MRW to the rawspeed library:
https://github.com/pedrocr/darktable/compare/rawspeed-mrw-support
That code is complete and so the next version of Darktable should have full support for the 5D, 7D, A1, A2, 7, 7i and 7hi. Those were the models I had a test file for. Ideally I'd like to add support for all MRW producing cameras. To be able to do that I'd need at least one example file per camera. From a little research I know there are at least 3 cameras missing:
- DiMAGE 5
- DiMAGE 7u (or is it UG?)
- DiMAGE A200
From the wikipedia list of cameras with RAW there appears to be undocumented RAW support in these cameras as well:
- DiMAGE G400
- DiMAGE G500
- DiMAGE G530
- DiMAGE G600
Apparently in these cameras there's a way to turn on MRW format, even though the files get named .JPG anyway. Apparently for the Z2 there's also a hack to enable raw but oddly enough in Nikon NEF format, so that one is out of scope.
If anyone has MRW files (or MRW format JPG named files) from any of these cameras I would appreciate it if you could send them to pedro@pedrocr.net. If you could also explicitly license the files as some form of Creative Commons license it would be great as I could then include the files in software test suites to make sure the cameras stay supported over time.
Thanks and happy shooting,
Pedro
Canon EOS 5D Canon EOS 7D Panasonic Lumix DMC-G5 Ricoh G600 Sony Alpha DSLR-A200
AnthonyL Senior Member • Posts: 2,864
Re: Looking for example MRW files to add support to open-source software
PedroCR wrote:
Hi everyone,
- DiMAGE 5
https://www.dropbox.com/s/9pkkhxfnxd51tch/PICT0002.MRW
- DiMAGE A200
- DiMAGE G400
- DiMAGE G500
- DiMAGE G530
- DiMAGE G600
I presume you mean in the second list as RAW is a specific quality setting on the Dimage 5.
I grant full use of PICT002.MRW file for use in developing open source or free software for the benefit of photographers.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
