Next lens Purchase for NX300
Started May 17, 2014 | Questions
deadmeat30 New Member • Posts: 16
Hi everyone,
Im wanting to add a lens to my collection.... I currently have the 20-50mm kit lens, and a couple of Pentax PK mount lens that i just play about with as they were cheap.
Now, i would really like to purchase a new lens while Samsung have there offer on. With the lens im wanting to do some general photography with a small lens, photographing my miniatures in the light box i have, and some filming.
3 lens jump out at me for the practicality
20mm 2.8 lens - nice small size and light, good f value for low light, and good feedback from users.
30mm 2.0 lens - again, same as above, but better f value
45mm 1.8 lens - little more weight and size, but the best f value of the 3 lenses, and also seems the best for video?
How would they preform with taking close up shots in a small lightbox set up?
Thanks for your time!
 deadmeat30's gear list:deadmeat30's gear list
Canon EOS 450D Samsung NX300 Samsung NX 20-50mm F3.5-5.6 ED Apple iPad 3G +WiFi
Samsung NX 20mm F2.8 Pancake Samsung NX 30mm F2 Pancake Samsung NX 45mm F1.8 Samsung NX300M
arbuz Senior Member • Posts: 2,247
Re: Next lens Purchase for NX300
deadmeat30 wrote:
Hi everyone,
20 is ok, but the main difference from what youn have is faster AF.
30 vs 45 should be answered by which focal lange you prefer. IQ is very similar, f-stop advantage negligible. 45 has faster and quieter AF.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
AdamT
AdamT Forum Pro • Posts: 62,282
Not as good as the 20mm end of the 20-50 from both what I`ve seen and the report on Photozone . it`s not a bad lens at all, in fact it`s damn good but the 20-50 is stellar at 20mm even wideopen F3.5 (better than the 20mm prime at F4) and that it beats a prime is amazing ......
This is the usual next buy - can be fun to get the best from due to curvature but it`s criminally sharp and very compact
I`d make sure you`ll use it before splashing the cash - do you use the 50mm end of the 20-50 a lot (even though it`s lame compared to the wide end) but wish for more speed ?
the 16mm is another lens which would be worth considering, it`ll give you that 24mm wideness , it`s supposedly hard to get the best from too but I`ve never used one so don`t know , if I see one cheap I`ll grab it but I`d not pay the earth for one
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
OP deadmeat30 New Member • Posts: 16
Interesting to hear about the 20mm lens, ill have to have a play around with mine, havent used the 20mm much to be honest.
Well the 45mm just seems the best option for taking photos my miniatures. (well there would be better options, but they start to cost alot more!). not easy picking lenses :(.
I would be shooting some video with the camera, so the near silent AF on the 45mm would be helpful.
Giannis Ch
Giannis Ch Regular Member • Posts: 173
I don't know how big your miniatures are and how closely you want to shoot them, but keep in my mind that the 45mm focuses at something like 50cm, so you won't be able to get very close to them.
 Giannis Ch's gear list:Giannis Ch's gear list
Sony a7R III Sony FE 24-70mm F2.8 GM Sony FE 50mm F1.4 ZA Sigma 135mm F1.8 Art Samyang AF 85mm F1.4 FE +1 more
interesting point, would it be best to just splash out on the 60mm macro lens?
I dont need the miniature in the entire frame, only 1920x1080 of the pixels on the sensor.
Giannis Ch
Maybe or you can just crop a bit. Perhaps you can get closer with the Fotga extension tubes too.
Rolfens Forum Member • Posts: 97
deadmeat30 wrote:
Hi everyone,
Depends on what you want.
According to what I see on ephotozine, the 45mm has higher optical quality. Yet the 20 and 30 are much more compact. It is quite common for pancake lenses to have lower image quality
If it suits your shooting style, I'd say go for the 45mm. It is great for portraits too. You can get it in 3D too.
Sure it's a bit tele, but then there's the kit lens for regular use. You have the kit lens, don't you?
 Rolfens's gear list:Rolfens's gear list
Olympus PEN E-PM2 Sony a7 Panasonic 20mm F1.7 II Samyang 12mm F2.0 NCS CS +11 more
viking79
viking79 Forum Pro • Posts: 14,157
Search ebay, there are some cheap extension tubes with electrical contacts for focus/aperture control.  These work very well with the 45mm.
Otherwise shoot and crop, 2 MP should be no problem.  Even kit lens might be fine at low resolution (like 18-55mm).
The 60mm is of course great for macro, but it isn't cheap.  Just depends on what you have and how much you want to spend.
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
ChuckTa Senior Member • Posts: 1,492
deadmeat30 wrote:
Hi everyone,
If you shot close-up with miniatures, you'll probably use manual focusing anyways for more accurate results. And since you already have the PK mount, I recommend you get a Pentax-A 50mm f1.7 (close focus 45cm) or a m42 mount Pentacon 50/f1.8 (min focus 33cm).
 ChuckTa's gear list:ChuckTa's gear list
Sony a7 Samsung NX500 Fujifilm X-T20 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GF10 (GF90) +8 more
Petak
Petak Regular Member • Posts: 203
I suggest you take a look at the Photozone test again - at comparable apertures the prime is considerably sharper, especially in the centre, but also in the borders. That, the faster AF and most importantly the non-rotating front element enabling the use of polarising filter (very useful for a lens that is very likely to be used primarily for landscapes and architecture) make it a very worthwhile addition to 20-50. And I won't even mention the smaller size and the ridiculously low price (I just bought one for 99 EUR).
