Sigma 35mm f/1.4 - Fourth Times a Charm? Also Sigma Q&A
Started May 16, 2014 | Discussions
The Photo Ninja Senior Member • Posts: 2,242
Al Downie Senior Member • Posts: 1,407
Re: Sigma 35mm f/1.4 - Fourth Times a Charm? Also Sigma Q&A
I can't guess if you're either a *very* patient man, to continuously experiment until you find 'the good copy', or if you're the world's *least* patient man, jettisoning equipment every week in favour of something else!
I also found the 'USB dock firmware loop' issue. Problem with the software I think. Yet another confidence reducer.
 Al Downie's gear list:Al Downie's gear list
Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R APD +1 more
Searching Veteran Member • Posts: 3,964
I had the exact same problem at infinity, I gave up.
 Searching's gear list:Searching's gear list
Olympus E-M1 II Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +4 more
Hombre de Maiz Regular Member • Posts: 273
Many here are in Sad denial also. They think it wholly normal that it is Incumbent on the user to get the lens to focus well. They will point to the inclusion of focus adjustment ON Some Canon bodies as proof that it is a.problem inherent to the EOS mount. When I tell them that every single One otthe 15-odd Canon EOS lenses I have Owned have focused accurately out of-the box I am told that it must be a stroke of luck. Denial, and more denial...
I agree, and am also a bit bewildered by the tolerance of some people who still rave about the lens, despite acknowledging its focusing 'idiosyncrasies'. It's supposed to be one of the best 35mm lenses ever made - supposed to 'blow the competition out of the water' - supposed to be a 'Canikon killer', and it costs the best part of a thousand pounds, but apparently you can only use it for EITHER landscapes OR for portrait/documentary work; not both at the same time.
Others seem to be simply blinded, or hypnotised by the hype. I've seen several images which contributors have offered as demonstrations of how amazing the lens is, and most of them seem to be front-focused!
arty H Senior Member • Posts: 1,546
I have also been amazed at how many "superior" Sigma 35 shots that have been posted seem to be unsatisfactory and out of focus.
I have lots of lenses, mostly Canon, but a few by Tokina (35 macro, 12-24F4) and Sigma (50 F2.8 macro). The only lens that I had any AF difficulty with was the Canon 85 85F1.8. It front focused, but a replacement was satisfactory.
My cameras do not have microadjustment, but that has not been a problem for my 8 other Canon lenses, or the Tokinas and Sigma macro lens. The idea for the dock is potentially a good one...if it worked.
(unknown member) Veteran Member • Posts: 5,018
Nonsense
Most people shoot landscapes at between F8 and F13 where critical focus on 'a subject' is not the goal, but rather as much DOF as possible. Often they (or at least I) focus about 1/3 into the scene and very often use MF/live view when doing landscapes. There is a totally different focus accuracy requirement and DOF issue when shooting at F1.4-2 at 1 to 3 meters as compared to 10 to 50 plus meters at F8-13.
In any case, I and many have not had any issues with using this lens for both close up and distant subjects using it's AF.
Sorry you had a bad experience with this lens, but you are way off base to draw such blanket conclusions and suggest others are simply blinded or hypnotized by the hype.
Yes there are a MINORITY of users that report issues like you are reporting, but they are far less than say the reports of focus issues the 50L has suffered over the years (a lens which I believe we both love).
Re: Nonsense
You see? I rest my case.
Re: Nonsense
Rather than rest your case, perhaps you should look and see what Lens Rentals says about this lens (see http://www.lensrentals.com/rent/canon/lenses/wide-angle/sigma-35mm-f1.4-dg-hsm-a1-for-canon and every other review I have seen).
You know Lens Rentals right???  After all, you indicated you rely upon them just recently right here http://www.dpreview.com/forums/post/53686625 Or maybe you just value their opinion only when it fits yours?
Dan_168 Forum Pro • Posts: 11,055
I am one of those blind people replaced my 35L with this horrible Sigma 35 and have been pretty happy with it. I didn't even do any micro lens adjustment/focus fine tuning on all my camera bodies because I am so blind and can't see the need for it yet, but I am not going to post anything to demonstrate how horrible that lens is since you and many knows how useless that lens is already, LOL.
OP The Photo Ninja Senior Member • Posts: 2,242
I expect perfection. That is, to work as advertised.
I just updated my blog... I'm returning it today.
My own stupid fault.
It's going back!
I REALLY want to like this lens, but with such AF wonkiness it's got to go!
Invertalon Forum Member • Posts: 57
Sigma's technical response made perfect sense. And Canon's also require microadjustment (or adjustment of that nodal point they speak of).
For example, my 300 f/2.8 II requires +6. My 24-70 II is -2W and +1T... I have had other prime lenses require 4-6 MA in either direction. It is normal.
However, Sigma's have trouble at infinity or close to it. No matter what you do, inconsistency is poor. Closer, they seem to be fine.
I have tried (3) Sigma 35's as well, the first two had some terrible focus shift in artificial light and my most recent attempt was infinity focus issues. I am done with them as well.
jayboo Senior Member • Posts: 2,366
Have to agree with you Dan.   Proof is in the pudding for me, my biggest selling images on Getty have been taken with 5D2/5DIII and the Sigma 35mm 1.4 - no complaints from me, no MA on either body - occasionally have noticed problem when focussing at distance but easily remedied with a couple of extra frames.
I love my 50mm 1.2L, but have more trouble getting it right, (very probably user not equipment), as when I focus test, tripod/test chart, its usually spot on.
Jayboo
 jayboo's gear list:jayboo's gear list
Leica CL Canon EOS R6 Leica M10-R Canon EOS R7 Leica Elmar-M 24mm f/3.8 ASPH +11 more
jayboo wrote: "occasionally have noticed problem when focussing at distance but easily remedied with a couple of extra frames."
So if you're a landscape photographer and are aware of the problem, you can check and adjust as required - a perfectly good workaround. But if you're interested in capturing unique family moments, it's not acceptable.
Strangely Al, this is what I use the lens for most  - I am not a landscape person.  Never had a single problem with focus on indoor family shots which is where this lens shines for me.   I am not saying that if I was in the habit of 100% pixel peeping every shot would be spot on, but no more misses than I had with my previous 35L and I prefer results.
Just for the record I don't consider myself a Sigma "fanboy" just my opinion and experience.  I will not be rushing to get the new 50mm Sigma, because what I have does the job for me, but as with the 35L, I traded my 85 L for the Sigma 85 1.4,  because the Canon didn't.
Jayboo
That's a great shot!!
The family moment I had in mind was very similar, taken at similar range. I shot about 20 frames, without checking, because I was confident of my exposure, steady hand and focus. Boy was I wrong - every single frame was out of focus. And not just a wee bit soft when viewed at 100% - they were all completely unusable: front-focused by about 5-10cm at a range of about 80cm. ZERO% keepers! And a unique moment lost.
As I said before, I did experiment with the USB dock (took +20 at the three close ranges to achieve a sharp image, but then when I repeated the experiments later I had to drop that down to +5. That was weird, so I started shooting LOADS of images at 0.6m, defocusing before each shot (sometimes to a distance in front of the subject, sometimes behind), and found that the results were completely inconsistent. So no amount of fiddling with the dock would be of any use. That's when I sent it to Sigma, who returned it a week later after servicing/testing, and it behaved exactly the same way when I tested it.
qianp2k Forum Pro • Posts: 10,350
This is one of reasons I didn't buy Sigma 35/1.4 A.  I have heard both claims, many love this lens and also bunch of such reports.  In comparison we never heard 35/2.0 IS focus issue, the one I picked up.  For me a 35mm lens is mainly for street and indoor photos so shallower DOF is not critical as it's not an ideal portrait lens on FF body per my perspective and I benefit more from 4-stop 'IS'.  For 50mm or 85mm or 135mm prime, option of shallower DOF is much more important for portrait.
Enshong Regular Member • Posts: 170
In Denial
Oh man.. I didn't know I was in denial. Just checked my Lightroom library again and my recently shot wedding. Oh my god.. So many front-focused shots wasting a lot of precious moments for my client. I feel horrible! I was blind!! Why Sigma?! WHY?!
Anyway, of course the Canon 35L can get these too but I made it with a few bucks saved. Maybe some people are just HAPPY with the lens instead of being in denial?
I was using Nikon at the start of my photographic journey up until I had a D800 and then I got this Sigma 35mm Art. Guess what? This lens caused me to switch to Canon. This Sigma was too sharp at 1.4 that it made me really really notice the left AF problem of the D800 which I didn't see using other Nikkor 1.4 (50mm, 85mm) lenses, then the subsequent horrible Nikon disservice. When I switched to Canon, the first lenses I got was this Sigma 35mm Art and a Canon 135mm f/2L (love this boner lens).
I am not denying that there might be some people having focus problems with this lens too. It's almost impossible not to happen as Sigma only reverse-engineers the AF algorithm. That's the risk for third-party gear. It's up the person to decide if the risk is worth it for him. Personally, I had to micro-adjust my lens too with the Sigma Dock. Am I unhappy it didn't work out of the box? Not really as the end result was great for me.
mevbo Senior Member • Posts: 1,221
Re: In Denial
This tread made me get mine out and shoot several shoots at various focal lenghts.  All sharp and focus perfectly.  Darn, I wanted to join in the roast.
 mevbo's gear list:mevbo's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Canon EF 24-70mm F2.8L II USM +3 more
