@Simon/Allan: GN120 UK Firmware ?
Started May 15, 2014 | Discussions
tjobbe
tjobbe Senior Member • Posts: 1,430
Hi,
did one of you got that firmware update on your Galaxy NX ?
(PDA: GN120XXUAND3 CSC: GN120OXAAND3 MODEM: GN120XXUAND3 CHANGELIST: 2647728 BUILD DATE: 16.04.2014)
This is for the UK modell and I am currently trying to find what this is about.
Cheers, Tjobbe
 tjobbe's gear list:tjobbe's gear list
Samsung NX300 Samsung NX30 Samyang 35mm F1.4 AS UMC Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +18 more
Samsung Galaxy NX
tjobbe
OP tjobbe Senior Member • Posts: 1,430
Re: @Simon/Allan: GN120 UK Firmware ?
simontramper
simontramper Senior Member • Posts: 2,405
I am home tomorrow will will turn on and see if anything comes through.
http://www.flickr.com/photos/simon-nx/
Trying to capture the images i see around me.
 simontramper's gear list:simontramper's gear list
Samsung NX200 Samsung Galaxy NX Samsung NX1 Samsung NX 20-50mm F3.5-5.6 ED Samyang 8mm F3.5 Aspherical IF MC Fisheye +10 more
MOD Taffy Veteran Member • Posts: 5,020
Hi Oliver, no mate, I haven't had a firmware update for the GNX. Busy right now, but I'll see if I can get it later.
Have a good day.
Regards, Allan.
tjobbe wrote:
Hi,
Cheers, Tjobbe
Hi Oliver, am I right in presuming that I need to download Samsung Kies to my pc, in order to update the Galaxy NX? If so, which version of Kies do I need? Cheers mate, Allan.
Have a good day.
Regards, Allan.
tjobbe
it should work OTA via WLAN as well (at least that would be my first check)
Settings-> about device-> SW update
EDIT: if you follow the above link you might understand why I made that removed TW comment ;). He had nothing better to do to follow.
I tried your suggestion, conected via WLAN and SWupdate, but all the camera tells me is that the latest updates are already installed, but the date is Sept 24th 2014, or somewthing like that.
TW is a very bitter person. He hates all things to do with Samsung, (including us, who use their products). He conducts an "anti Samsung," tirade on the other forums now, since he was banned from this forum for his continual trouble making. He thinks that Samsung should listen to what he has to say, and act on it when they design a new camera. Becuase they haven't used his suggestions, he now does all the Samsung bashing that he can on other DPR fora, and elsewhere I dare say. Cheers mate, Allan.
Have a good day.
Regards, Allan.
simontramper
I got home and connected via wifi again no updates found .
tjobbe
thx for checking !
tjobbe
simontramper
Sammobile indicates availability via KIES
http://www.sammobile.com/firmwares/1/?model=EK-GN120&pcode=0#firmware
Will try this now
simontramper
Will try this now
This looks to be a regional sim unlock unless i am in the the wrong section but i cannot find an update
Does anyone have anything definite , please don't reply with just a link.
tjobbe
simontramper wrote:
Does anyone have anything definite , please don't reply with just a link..
sorry Simon, my bad... I just added that link to indicate that they claim that KIES would be providing the update.
KIES in case you do not use it, is a piece of PC software to sync/backup mobile devices as well as an alternate approach to update firmware
simontramper
All cool I still cannot find a update.
I have D/L'd Kies. amd installed the thing and it still cannot find a F/W update.
Have a good day.
Regards, Allan.
Re: @Simon/Allan: GN120 UK Firmware ? Hi Oliver and Simon, try this....
I'm not sure how useful this is, or even if it will work, but below is a link to the download of the latest GN120 firmware. I am d/ling it at the moment, but have no idea what to do with it when I get it on my machine. Any ideas? BTW Oniver this site has the F/W with all the differnet languages available for download.
http://www.sammobile.com/firmwares/3/?download=29179
If the above link doesn't work you may like to try one of these. The country codes are with it. The code for UK is BTU, for Germany it is DLT, I think.
http://samsung-updates.com/device/?id=EK-GN120&details=Galaxy_Camera_NX
Have a good day.
Regards, Allan.
Re: @Simon/Allan: GN120 UK Firmware ? Hi Oliver and Simon, do either of you know..............
how to do a manual update of the GNX. I already have the update d/l'd on my pc, but I don't think that an ordinary manual update, (putting the file onto the SD card), would work with an Android based device, would it? I have searched the Sammobile web site, (where I got the update from), but I only found out how to do it with a mobile phone.
Have a good day.
Regards, Allan.
simontramper
Here's my thought if no one can figure out how to use it what's the point and surely any relevant update for this device will be released over the net straight to your device .
zaurus Regular Member • Posts: 266
Manual update with Windows howto [EG-GN120]
You seem to be running Windows (I don't). A quick search brings back:
http://true-android.blogspot.com/2013/12/install-xxuamj2-android-422-jb-firmware.html
http://forum.xda-developers.com/galaxy-s3/themes-apps/27-08-2013-odin-3-09-odin-1-85-versions-t2189539
tjobbe
well, there s that ODIN SW that bypasses the normal path of Firmware updates. The sammobile page explains (and this is what Simon referred to)
I tried that onc on my tablet to get it from 4.0.4 to 4.1.2 (which is avail in some regions already) but failed.
It is supposed to work with any Android device but not sure to risk that with the NX.
