Moon - since all the cool kids are shooting it!
Started May 15, 2014 | Photos
(unknown member) Regular Member • Posts: 221
I am a novice to photography just wanted to see if I could shoot the moon using the only telephoto lens I have the Panasonic 45-175mm - not long enough to get a close up but result is not bad. Shot hand held but high shutter speed.
Straight out of camera JPG - ok this lens isn't long enough!
100% crop from paint.net no processing
Its not the sharpest but for 100% crop I have to say I am quite happy with how well my first try turned out.
Comment & critique:
Olyroo
Olyroo Regular Member • Posts: 333
Nice shot
I decided to make mine a blue moon tonight
 Olyroo's gear list:Olyroo's gear list
Olympus C-8080 Wide Zoom Olympus PEN E-PL1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH +8 more
Wayne Lee Regular Member • Posts: 164
Re: Moon - since all the cool kids are shooting it!
I have a question on how you shot this? There is a beautiful moon out tonight, so I thought I would try some shots. Using the EM10 and 40-150mm lens, I can see the moon, and even better, using the 10X zoom to get in real close, I can see all the details on the moon. Then, I decide to take a picture - and my picture comes out as one big white/yellow spot... zooming in for cropping, I see no details of the moon.
What am I doing wrong? Is it shutter speed? Exposure? everything?
Thanks for the help.
 Wayne Lee's gear list:Wayne Lee's gear list
Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Fujifilm FinePix F30 Zoom Sony Cyber-shot DSC-TX5 +5 more
kwunyin Regular Member • Posts: 152
From my limited experience, you have to treat the moon like the sun. So you need to shoot at either higher shutter speed or smaller aperture.
If it's a big yellow dot, you are probably getting too much light.
offtheback
offtheback Senior Member • Posts: 1,100
Ii've used spot metering with some success.Basically a full moon with no cloud or fog interference is F/16 at the ISO for shutter speed or equivalent exposure..Suggest a 1/500 mini for moon and camera movement at ISO 200 and bracket from there.
daddyo Forum Pro • Posts: 12,670
It's very simple actually...
The luminance of the moon, above the horizon on a clear night calls for a basic exposure @ ISO 100 of 1/250 Sec @ f/8. It is easiest to shoot the moon in Manual Exposure Mode, as you don't have to dial in a ton of exposure compensation for over-exposure caused by auto metering.
I would recommend keeping the shutter speed at least 1/125 or faster to freeze the movement of the moon in the frame. Simply adjust aperture to get the correct exposure. Use of a tripod and cable release is also helpful.
Here is an example shot with my E-M5 and EC-14/Sigma 50-500mm combo. I also used the DTC (Digital Teleconverter) on this shot -- so this is framed exactly as it came out of my camera.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
A suggestion....
This is a nice moon shot, but is several stops under-exposed. Your shutter speed was much faster than needed -- next time try shooting this using the same ISO and Aperture, only slow the shutter speed down to about 1/250 Sec. -- be sure to use a tripod.
God Bless,
Greg
OP (unknown member) Regular Member • Posts: 221
Re: A suggestion....
Thanks.  Yeah I will try that, just that I had no tripod.  I tried several shots at 80-1250 shutter speeds and f/22 to f/8 but too much camera shake / cloud interruptions meant that some of them were ruined.
Yea the experts have already replied and mine is underexposed but essentially, you have overexposed it.   The same thing that you faced happened to me and then I just played around with all the parameters till I got something that looked like those moon shots others do.
This is what I followed:- Use M mode
- Use minimum ISO your camera can handle
- Choose an F stop where your lens will be sharp but also not let in too much light
- Adjust shutter speed enough to not have too much shake and but not under-expose like I did (I went wrong here)
I tried to use manual focusing at first but failed - mostly cause i have an LCD and no EVF and I couldn't see it properly with 6x zoom, should have turned that off.  Surprisingly AF locked on pretty quickly though with exposure dialed down.
Thanks for all the help. I will try these suggestions tonight and see how it goes. Hopefully will end up with something reasonable.
beomagi Senior Member • Posts: 1,372
There's an exposure rule called "loony 11" F11 and shutter = 1/ISO
So if you're shooting F11 and ISO 400, set shutter to 1/400.
If you're using a fixed mirror lens at F8 for example, it's twice as bright. Raise shutter speed to 1/800. Do note of course f8 mirror lenses are darker than normal anyway.
I'd recommend at least 300mm. Even at 500mm, it's pretty small. Manually focus and lens for accuracy. Disable display auto brightness, or zoom magnification so that you can make out moon details. Use a remote trigger (generic ones are cheap and work great).
This moon was shot with a cheap old $60 500mm F8 lens. I've applied a little sharpening.
Full moon pics will appear devoid of the nice details you make out in half moon or similar pics. The reason is simple - anything other than full moon is getting side lighting which is the kind of lighting you want to bring out details in anything. Full moon gets direct lighting.
Moon at 500mm, F11. View in full to avoid what looks like cellulite at the bottom. Thanks dpreview scaling...
 beomagi's gear list:beomagi's gear list
Canon EOS 5D Olympus PEN E-P3 Olympus OM-D E-M10 Canon EF 50mm F1.8 II Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +5 more
