Suitable SLR Body for EF 500MM
Started May 14, 2014 | Discussions
Billy2128 New Member • Posts: 1
Currently I have chosen to make use of Canon EOS 7D along with CANON EF 500MM F/4L IS II USM LENS . But not sure if this is the best body that suits with this . This is the retailers specification ( http://www.smifu.com/canon-ef-500mm-f4-usm-ii.html ) given about this lens. Can anyone suggest regards the SLR Body to be used along with this lens, also a advice or suggestion regards to photography using this lens are welcome.
Canon EF 500mm f/4.0L IS II USM Canon EOS 7D
NancyP Veteran Member • Posts: 6,608
Depends on your use
What are you shooting? Do you need the extra "reach" given by the crop factor of APS-C or APS-H? Will you be using the series III teleconverters?  If you are a birder, I might suggest a good used copy of the 1D4 (which has more volts to power the lens AF), or a good used copy of the 7D. Then when the 7D2 comes out late this year (supposedly), you might buy it for the expected better image quality in comparison to 7D original.
If you can get enough subject magnification using a FF camera, the 1DX is the best action camera out there for Canon. 12 FPS! Focus on the 5D3 is said to be equally good, although the frame rate is slower.
Are you hand-holding it? Does the weight of the camera body matter?
I am a birder and I am awaiting the 7D2 to match with my "toy lens" 400mm f/5.6L, currently paired with the 60D. The toy lens and APS-C camera are capable of excellent hand-held image quality, and I barely notice that I have the camera when I am hiking - combo is 2kg.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
Cambell Forum Member • Posts: 83
Re: Suitable SLR Body for EF 500MM
The 7D is highly recommended by many birders, who also highly recommend the 500mm f/4. The combination gives some really stunning images that I have seen. Hopefully a 7D II will come out at some point in the near future (though nobody has heard a peep about this from Canon!) and that would be basically the ideal camera for birding, given that the image quality is bound to improve while retaining the crop factor.
Both the 7D and 1D IV will perform admirably, and neither will let you down. It's a matter of weighing up the other factors that come with the cameras.
 Cambell's gear list:Cambell's gear list
Fujifilm X-T1 Samyang 85mm F1.4 Aspherical IF Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 56mm F1.2 R
Philippe R Contributing Member • Posts: 951
Regardless which body you mount on the EF 500mm f/4 L IS mkI or mmii, you will be greatly satisfied with the images as these lens have a magic to them in the wildlife territory. They have the ability to suck in light that will blow you away. Of course you should consider how you will use it, and for that i strongly recommend a good gimbal head on a stable tripod. May i suggest the acclaimed Wimberley II. You'll find that setup on nearly all heavy lens regardless of the brand of the camera. If you intent to use that setup handheld, you should work on your technique a bit as it can be heavy at times and require some learning, and some muscle workout... The IS is great but will not compensate every user shake.
As for cameras, I personally use 1Dx or 5DIII but used to use a 1D4 with great satisfaction.
If you need extra reach, the TC 1.4 III or TC 2.0 are meant to be the perfect match for the 500mm. You could use that setup with EOS 7D or 70D if you need stellar function and fast image rate. But that lens is not only all about speed, it is about bokeh too. You can use it wide open and still get some incredible shots.
I have covered mine with lens coat to protect it from scratches in the wild. You may also look out for aquatech lens cover for the front optic.
It is a very addictive lens
Enjoy and show some images once you've got it running !!!
Phil (Nice, FR)
www.pbase.com/webman06
www.eosdslr.com
 Philippe R's gear list:Philippe R's gear list
Canon PowerShot G10 Fujifilm X100S Canon EOS 5D Canon EOS 350D Canon EOS-1D X +48 more
Mark B.
Mark B. Forum Pro • Posts: 29,756
If you're shooting birds & wildlife, the 7D is ideal.  I use the MkI version of this lens with my 7D, I've gotten terrific shots with it.
Mark
Tapeman Contributing Member • Posts: 672
A 1 series body balances well on a 500 and most have very good autofocus. I have been very pleased with the perfomance of my 1D MKIV & the 500.
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,870
I would not purchase a 7D at this time.
it's old and a 7D II will probably appear the second your return period expires. I would probably match this lens to no less than a 5D3. Are you buying the 7D used?
Rick Knepper, photographer, shooting for pleasure. It is better to have It and not need It than need It and not have It. Various RAW comparisons at Link below. Includes 5D3 vs D800E (new uploads), 5D3 vs. 6D, Zeiss lenses etc. https://app.box.com/s/71w40ita6hrcfghojaie
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Sony a7R IV Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +11 more
Mark B.
Re: I would not purchase a 7D at this time.
The 5DIII is a terrific camera, but that doesn't make the 7D obsolete.  I get great shots with the 7D and first version of the 500 and the 7D.
Mark
