Panasonic 14-45 used on EPM2 ??
Started May 9, 2014 | Discussions
Jere Landis Senior Member • Posts: 1,933
If I put my 14-45 on my EPM2 how should I set the Image Stabilization? How much better off will I be using it over the Oly kit lens?
 Jere Landis's gear list:Jere Landis's gear list
Canon EOS 550D Panasonic Lumix DMC-G10 Olympus PEN E-PL3 Panasonic Lumix DMC-G5 Olympus PEN E-PM2 +11 more
Olympus PEN E-PM2
(unknown member) Regular Member • Posts: 221
Re: Panasonic 14-45 used on EPM2 ??
In your EPM2 settings make sure "Lens Priority" is set to on.  This will automatically disable IBIS when Lens has stabilization that is on.  For long lenses its generally better to use lens IS as the sensor shift method is not as effective.  I generally just leave Lens priority but the only stabilized lens I have is the Panasonic 45-175 Power OIS.
OP Jere Landis Senior Member • Posts: 1,933
Thanks very much for your reply, it was so helpful.
