Micro Four Thirds keeps GAS under control (for now)
Started May 8, 2014 | Discussions
Alex Notpro
Alex Notpro Senior Member • Posts: 1,013
WARNING: this post is somewhat pointless, and contains criticism of other camera systems. If you can't stomach that, please move along.
I have an E-M1 and E-PM2.
The other day I was wondering if I had "GAS" (Gear Acquisition Syndrome) and after some Googling, found the excellent article "7 stages of Gear Acquisition Syndrome" by bloggers Rob Power and Matt Parker. These guys are into music gear but I'm convinced what they wrote applies equally to photography. The seven stages are:
  1. Dissatisfaction
  2. Desire
  3. Research
  4. Purchase
  5. Guilt
  6. Acceptance
  7. Relapse
This was very illuminating. I realized my MFT system currently has me perpetually stuck somewhere between stages 2 and 3.
I've been dissatisfied with the MFT's ability to shoot "the last 5%". MFT is adequate for about 95% of what I shoot. The "last 5%" are those photos where some shallower DOF or extra megapixels or higher ISO could have turned a Great image into an Absolutely Perfect image, or perhaps make the image a candidate for enlargement rather than being forever relegated to Facebook or small print.
So I heard about the Sony A7 / A7R and Fuji X, and Nikon D610 (I own Nikkor lenses) and that is how I got into Stage 2 and almost immediately into Stage 3 - research mode.
Here are the results of my research, and the issues that have prevented me from progressing to Stage 4:
Sony A7/A7R - full-frame mirrorless
  • Only 4 native lenses. Other lenses require an expensive and bulky adapter.
  • Only two primes: 55/1.8 and 35/2.8.
  • No pancake lens.
  • No f/2.8 zoom.
  • No IBIS and none of the full-frame primes have OIS
  • Lacks automatic eye-priority AF (requires a button press, and loss of a customizable button)
  • RAW files reportedly use lossy compression. Others may not care, I do.
  • Real-world continuous shooting speed (not the fake "speed priority mode" which drops AF and AE) is barely over 1 fps
  • System lacks a pocketable body that can use the same lenses at same FL.
Fuji X - APS-C mirrorless
  • The only pancake lens is an f/4.2 equivalent, vs. MFT f/3.4 equivalent.
  • The only UWA is not quite as wide (15mm vs 14mm) - not sure if true on horizontal AOV
  • No all-purpose daytime travel zoom (28-300 equivalent)
  • No 600mm equivalent lens
  • Lacks IBIS and none of the primes are stabilized
D610 - full-frame DSLR
  • I previously owned D600 and D700, was hoping the D610 would be a meaningful update. No such luck. AF is just as limited as the other DSLRs. Focus-and-recompose is not for me, and shoot-and-crop negates the benefits of the larger sensor.
  • The Nikon system does have a pocketable body (Nikon 1) but unfortunately it does not share lenses at the same focal lengths. The 2.7x crop means you need two full sets of lenses in order to use FF and N1 side-by-side.
  • My older Nikkor motor-driven lenses autofocus very slowly, so I don't think I'll be keeping them -- the fast focus of the E-M1 has raised my standards
  • Oh yeah, it's big and heavy, I sometimes forget that when researching cameras online
So now I'm stuck in research and keep monitoring these forums waiting for a better camera to come along
That's all I had to say. I'd be glad to hear others' stories and ideas on the topic. There isn't really a specific point to my post, it's a sort of open discussion.
 Alex Notpro's gear list:Alex Notpro's gear list
Sony FE 35mm F1.4 Sony a5100 Sony a7 II Sony E 16mm F2.8 Pancake Sony E 10-18mm F4 OSS +7 more
Nikon D600 Nikon D610 Nikon D700 Olympus E-M1 Olympus PEN E-PM2 Sony a7 Sony a7R
Sean Nelson
Sean Nelson Forum Pro • Posts: 16,120
Re: Micro Four Thirds keeps GAS under control (for now)
Alex Notpro wrote:
I've been dissatisfied with the MFT's ability to shoot "the last 5%". MFT is adequate for about 95% of what I shoot. The "last 5%" are those photos where some shallower DOF or extra megapixels or higher ISO could have turned a Great image into an Absolutely Perfect image...
You may be a candidate for one of the Voigtlander Noktons, which could fill at least some of those gaps.   It's not small, but no lens + camera with that kind of speed is going to be...
markintosh13
markintosh13 Veteran Member • Posts: 4,951
Shrug - even 35mm format cameras don't have enough shallow DoF for some styles - Ryan Brenizer's "Brenizer's Method" / Bohehrama pano stitching technique for example is a technical solution for an artistic outcome. And it also yields mucho megapixels to boot.
Is it applicable to all types of photos? Nope.
But then there's also software blurring in PP which is getting better.
lattesweden
lattesweden Veteran Member • Posts: 5,583
Maybe I can tempt you with a Sony RX1?
Best regards
/Anders
I'm from Sweden, but my pictures are in all languages: http://500px.com/anderslattermann
Alex Notpro
OP Alex Notpro Senior Member • Posts: 1,013
Yes, good point. I got the Metabones Speedbooster which makes f/1.0 lenses from my Nikon f/1.4's. You just reminded me I need to shoot with it a little more
Alex Notpro
Is there any specific software you have in mind when you say this function is getting better?
Canon has an algorithm in the S120 that derives "depth from focus plane" from two exposures at different apertures, then selectively adds Gaussian blur to the background.
I've been wondering how long we'll have to wait before this shows up in common RAW processing software.
markintosh13
I think I've seen some plug-ins discussed somewhere here that looked okay, and I played around a bit with PShop's lens blur filter.
Though I certainly wouldn't want to have to develop a style and process stacks and stacks of photos in PP.
And I think the latest Android camera software has some multi shot software blur.
Alex Notpro
Perhaps if they make a 55mm version! I find I'm not very good at using wider primes... I forget to get closer and then end up cropping a lot.
jimkohn Regular Member • Posts: 487
Watch out for that GAS
If you agree that there is no such thing as the prfect camera, then if you're really at 95% you're doing quite well aren't you? But some of us just like checking out new equipment and we tend to be somewhat easily seduced. I know I'm guilfty of that: I sold my whole E-M1 rig to move over to Fui X-T1, only to realize that I liked the E-M1 so much better. I ended up returning all the Fuji gear and buying all the Micro 4/3 stuff back. Stupid and expensive, but now I know.
 jimkohn's gear list:jimkohn's gear list
Sony a6600 Sony RX100 Sony a6500 Sony a7 III Sony E 35mm F1.8 OSS +7 more
jhoto
jhoto Regular Member • Posts: 117
Re: Watch out for that GAS
It can't be as bad as tubes and pickups. : )
It's a never ending quest for perfect tone.
Oh, maple or rosewood, which batteries for my pedals!
 jhoto's gear list:jhoto's gear list
Canon PowerShot SX50 HS Canon EOS Rebel SL1 Apple iPhone 6 +2 more
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
You're not seriously into GAS until you thirst uncontrollably for an E-M1 or a GH4 -- or both!
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Panasonic ZS100 Sony RX10 IV
jeffharris
jeffharris Forum Pro • Posts: 11,409
Why stop at just one?
Voigtländer has a nice array of excellent lenses with Leica M and L39 mounts. They're worth a serious look!
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Cimarron Regular Member • Posts: 345
My GAS is on hold right now as I wait for the release of the Oly 40-150 mm f/2.8.  I know it's going to be big and heavy (for an m43 lens) and expensive, but if it's anything like the magnificent 12-40 f/2.8, I MUST have one.  :\
 Cimarron's gear list:Cimarron's gear list
Sony a6600 Samyang 12mm F2.0 NCS CS Sigma 30mm F1.4 (E/EF-M mounts) Sony E 16-55mm F2.8 G Sony E 70-350mm F4.5-6.3 G OSS
TrapperJohn Forum Pro • Posts: 16,488
Or you could consider Diversion
Divert your interest away from new gear, by channeling it into doing more with what you have.
Last winter, in the middle of a snowstorm, I thought - I'd like to get a snowflake photograph. Out with the EM1, the 4/3 adapter, the 50Macro and EX25 extension tube, and the twin head macro flash. I laid out some black felt for contrast, let snowflakes fall on it, and then fired away. First efforts were... ah, not dazzling.
What's wrong here, I thought. A snowflake should be something special, and these shots just aren't special. Out and try again. Still not, well, not capturing the 'magic'. Go back out and look for what you're missing. I didn't need more MP, or higher ISO, or a faster lens, or a larger sensor. I needed a different perspective.
After two hours of trying, I finally stumbled onto a combination that I did like - capture the snowflake not on an artificial background, but au naturel, get them where they fell, because it's not just a record of a snowflake, it now has context - this beautiful little thing is what you step on as a nuisance. Now, for the real trick - how do you find a snowflake that is sticking up, and not flattened by other snowflakes? That took some doing, hunting all over the sides of box bushes to catch a snowflake or two where they landed, and another two hours went by.
I won't say my final result is a masterpiece, but it's a whole lot better than what I started with, and at least I went from boring to the start of something interesting. I get far greater satisfaction out of that exercise than I do researching and buying gear.
Oh, and it didn't cost me a cent, just almost four hours of repeated trips out into the freezing cold, and a refusal to give up until I got at least a hint of what I was trying to capture.
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Thank you for a very reflective and illuminating post.
You mention that you are in a continuous cycle from stage 2 to stage 3 - research then desire - that reflects my situation as well. I think that's much more reasonable than frequently repeating the entire stage 1- stage 7 cycle, thus replacing all your gear at short intervals. In addition to the substantial cost, it incurrs other hidden costs as well.
Now as long as we spend more time shooting than discussing gear, I think life is good.
Eric
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
mimritty Regular Member • Posts: 302
Re: Or you could consider Diversion
Love this story... and the result.
I feel like I finally found the camera that will last me a while.  What I don't have yet is a point of view.  I'm going to take this good advice and see what is possible for me with the equipment I have, all of which far surpasses my abilities, I'm sure.
mimritty
PC Wheeler
Not to worry: You can still accumulate lenses
Phil
I was hoping no one would call me on that little loophole.
mimritty
n3eg
n3eg Veteran Member • Posts: 3,316
For me, it was accumulating 5 adapters and then the lenses.
It ain't easy being me, but someone's gotta do it.
 n3eg's gear list:n3eg's gear list
Kodak DCS Pro 14n Olympus PEN E-PL5 Panasonic Lumix DMC-GM1 Kodak Pixpro S-1 OM System OM-5 +73 more
Impulses Forum Pro • Posts: 10,039
Almost every recent smartphone does, the stock Android cameras one of the last to add said feature; i.e. different OEM had done something similar at a hardware or software level already. HTC went hardware with their dual sensor/lenses and in practice it produces one of the most fake looking effects... At a technical level the method Google's using with the stock camera app looks pretty elegant but the results are still pretty terrible. LG's approach is more subtle but more appealing too.
I'm not a snob by any means, I like A LOT of shots that come out of my phones, even from my Nexus 5 (and it's camera gets criticized a lot)... Those fake DoF effects have a long long way to go before they're anything more than a gimmick tho. At this point the use is questionable even for FB, unless you have pretty low standards and care more about the effect than any of it's side effects. PP post processing probably still produces much better results even without any depth mapping or any of the fancy new techniques that seek to automate/improve this.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
