EPM2 image quality
Started May 6, 2014 | Discussions
sigala1 Veteran Member • Posts: 3,911
Re: LX7 demo here
Jere Landis wrote:
Please, give up, the EPM2 image with kit lens is far superior to and LX7 image or any 1.7 sensor image.
This is simply not true.
Even in circumstance most favorable to the E-PM2+kit lens, the LX7 is a lot closer to the E-PM2 than people on this forum care to admit.
There are many situations in which the LX7 will produce better photos.
The LX7 is a better low-light camera because the lens is f/1.4 and has good sharpenss even wide open.
The LX7 never suffers from shutter shock. You can leave the IS on all the time and not worry about it.
The LX7 has less purple fringing than the E-PM2 with the kit lens.
Anders W
Anders W Forum Pro • Posts: 22,144
Re: LX7 demo here
sigala1 wrote:
Anders W wrote:
sigala1 wrote:
Lumixdude wrote:
sigala1 wrote:
I previously demonstrated that no one can tell the difference between an LX7 and an m43 camera with the Lecia 25mm lens:
http://www.dpreview.com/forums/thread/3641208
Your test is flawed straight away the moment you scaled both of those images down for the web... first of all give us the actual RAW files and ask the question again, or at the very least, hand over the metadata you removed. Strike three is where you've shot in conditions that you know the LX7 can handle.
Your thread has no relevance to this discussion or any other.
I posted good-sized 1280x960 images, not tiny Instagram-sized images.
So you are effectively saying that we can't tell them apart in a 1 MP image. Those who want better resolution than a 1 MP image can provide, however, have no difficulty telling an LX7 image from an MFT image, as readily exemplified here:
http://www.dpreview.com/reviews/image-comparison?attr18=lowlight&attr13_0=panasonic_dmclx7&attr13_1=oly_em1&attr13_2=panasonic_dmcgm1&attr13_3=oly_epl5&attr15_0=raw&attr15_1=raw&attr15_2=raw&attr15_3=raw&attr16_0=80&attr16_1=100&attr16_2=200&attr16_3=200&normalization=full&widget=1&x=0.6055639097744361&y=-0.18103755263187557
That was the point of the comparison, and not to pixel people at the RAW files. If you can't tell the difference at that size, you likely won't be able to tell the difference looking at an 8 x 10 print or on an iPad.
1. You are seeing that the LX7 has a much stronger anti-aliasing filter than the new Olympus cameras.
Please provide links to the evidence you have in support of that contention.
2. The comparison photo is using the 50mm Macro lens, which is the sharpest m43 lens and does not represent what results you will get using the kit lens, which is a lot more comparable to the LX7.
A. All the MFT cameras in the comparison I linked to (there were three of them) were equipped with the Oly 45/1.8, not the FT 50/2 macro.
B. The 50/2 macro is an FT lens, not an MFT lens. As to your claim that it is sharper than any other AF-capable lens you can put on an MFT camera, please provide links to the evidence on which that claim is based.
And do remember that the poster I was responding to was asking about the KIT lens and not the 50mm macro lens.
Why should I remember that? I responded to the claims you made on the basis of your useless comparison between the 25/1.4 and the LX7.
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
yangz Regular Member • Posts: 151
Re: EPM2 image quality
For some reason, the pictures taken with my PM2 + 17/1.8 cannot match sample pictures taken by E-M5 at higher ISOs. I feel the difference is pretty obvious. Maybe I did not apply the right settings? - I have turn off the NR filter or lower the NR, and set sharpness -1 etc.
 yangz's gear list:yangz's gear list
Sony a7 III Sony FE 24-105mm F4
Nobody here can help unless you post a photo that allegedly looks bad, and a sample photo that looks better.
rmxa Junior Member • Posts: 44
Do you actually have both cameras and are comparing output? Or do you mean your results with the E-PM2 don't match online examples of the E-M5/17 1.8 combo?
The camera settings mainly affect the in-camera JPEG conversion. It applies some form of noise reduction even with Noise Filter = OFF. To see how the settings affect your output, you can shoot RAW and play around with the settings in the RAW developer in Olympus Viewer which came with the camera.
But to completely disable NR will require the use of an alternative RAW processor.
If you're experiencing shutter shock, try enabling "Anti-Shock" and set it to 1/8. You can easily toggle it on and off in SCP once it's enabled.
And lastly, the E-M5 has a more sophisticated 5-axis stabilisation system which the simpler one on the E-PM2 simply might not match in your shooting scenario.
