Help needed.
Started May 5, 2014 | Questions
Kevinfennell New Member • Posts: 14
Help needed.
Hoping someone can shed some light as to what's happened with my camera. It's an a77 and I was using a tamron 70-300 sp  at 10fps. It didn't happen on single shot. Any help will be much appreciated.
 Kevinfennell's gear list:Kevinfennell's gear list
Sony SLT-A77
Sony SLT-A77
sybersitizen Veteran Member • Posts: 8,837
Re: Help needed.
Was EFCS (electronic front curtain shutter) on during this shot? It is known to sometimes do weird things at high shutter speeds.
Either that or a more general problem with the shutter mechansim.
OP Kevinfennell New Member • Posts: 14
Re: Help needed.
Yes the efc was on at the time.
Sony SLT-A77
ChefAlex
ChefAlex Contributing Member • Posts: 683
Re: Help needed.
Yes, I've heard people having issues when SS is faster than 1/2000 sec I thnk
 ChefAlex's gear list:ChefAlex's gear list
Sony SLT-A77 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) Tokina AT-X Pro 11-16mm f/2.8 DX II
Ed at Ridersite Forum Pro • Posts: 18,251
Re: Help needed.
Can you post with the EXIF attached?  Lots of information is missing.
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
 Ed at Ridersite's gear list:Ed at Ridersite's gear list
Sony RX100 II Sony DT 16-50mm F2.8 SSM Sony 70-400mm F4-5.6 G SSM II
JusLookN Veteran Member • Posts: 4,263
Re: Help needed.
I'm with Syber on this one EFCS!  Seen too many posts of the same type.
Glenn
I'm kinda partial to video, but I'm hangin!
 JusLookN's gear list:JusLookN's gear list
Sony Alpha DSLR-A900 Nikon D3S Sony Alpha DSLR-A100 Sony a77 II Nikon D500 +1 more
VirtualMirage
VirtualMirage Veteran Member • Posts: 3,946
Re: Help needed.
I'd be curious as to what your EXIF info says.  But it looks like the shutter curtain got captured in the image.
I use EFCS all the time and I have never had any issues with high shutter speeds, even as high as 1/8000s.
 VirtualMirage's gear list:VirtualMirage's gear list
Sony RX100 Sony a77 II Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-200mm F/2.8 Di VC USD +18 more
+1
Me neither.  I've seen some unusual fringing at extreme shutter speeds with EFCS, but nothing like in the OP.  No idea if the fringing is related to EFCS.
AEH
Nordstjernen
Nordstjernen Veteran Member • Posts: 6,876
A lens issue
Depends on the lens.
With most lenses I don't have problems, but with some lenses I get this dark upper part of the frame from 1/2000 sec when cusing first electronic shutter curtain, even with astronomical telescopes without any diaphragm mechanism.
 Nordstjernen's gear list:Nordstjernen's gear list
Sony Alpha a7 Sony Alpha a99
Calico Jack Senior Member • Posts: 2,306
Re: Help needed.
Do you mean apart from not having a better longer lens to get the subject to fill the frame?
Mark (aka Pirate!)
 Calico Jack's gear list:Calico Jack's gear list
Sony Alpha DSLR-A850 Sony Alpha DSLR-A100 Konica Minolta Maxxum 7D Tamron SP 70-300mm F/4-5.6 Di USD Tamron SP AF 90mm F/2.8 Di Macro +26 more
