EPM2 touch screen?
Started May 4, 2014 | Discussions
Jere Landis Senior Member • Posts: 1,933
EPM2 touch screen?
What can you actually do with the touch screen on the EPM2? Can you change settings etc.?
 Jere Landis's gear list:Jere Landis's gear list
Canon EOS 550D Panasonic Lumix DMC-G10 Olympus PEN E-PL3 Panasonic Lumix DMC-G5 Olympus PEN E-PM2 +11 more
Olympus PEN E-PM2
mimritty Regular Member • Posts: 302
Re: EPM2 touch screen?
You can select settings (from Super Control Panel, Live Guide, whatever you are using) and then change them with the dial.  You can set the focus point, or set the focus point and shoot at the same time.  In review, you can scroll through your images and zoom in or out.
Probably other things as well, but those are the ones that come to mind.
mimritty
OP Jere Landis Senior Member • Posts: 1,933
Thanks for your reply!
Anyone with anything else?
Not much interest if you don't have the latest.
HornOUBet
HornOUBet Senior Member • Posts: 2,230
I just ordered one for the $199.99 sale price, it should arrive tomorrow. I have been looking over the user manual that I downloaded from Olympus, but am hesitant to say anything until I hold it in my hands and can verify I understand what I read....check back next weekend and I'll report my findings....
 HornOUBet's gear list:HornOUBet's gear list
Panasonic Lumix DMC-ZS50 Canon G3 X Olympus OM-D E-M10 II Panasonic G95 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +12 more
(unknown member) Veteran Member • Posts: 3,010
that pretty much covers it.
Its a big improvement over the EPM1.
http://www.flickr.comthat pretty /photos/90891174@N04/
Erick L Senior Member • Posts: 1,288
You can change mode (PSAM and others).
Erick - www.borealphoto.com
Barry Stewart
Barry Stewart Veteran Member • Posts: 9,147
Crazy price
That's bound to attract a lot of buyers, who want to test the µ4/3 waters.
I started with the E-PL5, for its added functionality (tilt screen and more dials and buttons) — but if that price had been around at the time, I would have gone for the PM2 instead.
Be sure to get the Super Control Panel going. It's a convoluted process to get it on, but the SCP is SO valuable to operating the camera via the touch screen.
Guy Parsons has gone through a ton of work to step-by-step the process. It's a LOT clearer than the Oly instructions.
Once turned on, the SCP stays available via the OK button.
Specific to the SCP: http://homepages.ihug.com.au/~parsog/olyepl1/53-epl5-scp.html
Barry
 Barry Stewart's gear list:Barry Stewart's gear list
Olympus E-1 Olympus E-M1 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +6 more
Re: Crazy price
Thanks for the replies.
Jere
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
You can select and change some settings but it is not as good as Panny's implementation.
Another problem is the screen is always facing out so it is very easy to change settings while carrying the camera. My Panny G5 allows me to turn the screen facing in.
When the screen is "ON" there is an icon that allows you to select OFF, ON or Touch Shutter. Problem is that it is still easily changed and, therefore, other things as well.
On my EPL5, I have the touch screen turned OFF. In normal daily use, it is not worth the hassle.
Allan
