Which Olympus lenses are right for me?
Started May 4, 2014 | Discussions
Dan the Newbie New Member • Posts: 1
Hi everyone:
After purchasing many cheap and simple cameras over past 10 years, I have decided to invest more money into a decent camera/lenses that will last me longer, allow me to have some freedom in my photographs and possibly use this as a way to learn more about photography. however, the primary use of the camre will be to take it with me while traveling on business and vacations. Therefore, for now, I am mostly looking at taking landscape pictures, architecture, friends and family, etc.To be quite blunt, my knowledge of photography is limited, but am certainly eager to learn a lot more about it.
After much research, I have decided to go with Olympus OM-D E-M1. Primary reasons are that it has great reviews online and is seems to be a very light camera that you can travel with.
I've tried to do my homework on what lenses are most appropriate for my use … but am struggling to come to a conclusion as this is all foreign language to me. I would appreciate if some of your could help me out here in terms of which lenses I should go with.
My research indicates that Olympus ED 12-40mm f2.8 Pro is a very good overall lens. However, it does seem to be a bulkier lens that may be inconvenient to travel with. Hence, I am not sure if I should also purchase another, smaller, prime lenses as well. It seems that Olympus 12mm f2.0 and 17mm f1.8 are suitable choices as they are much smaller/lighter and will do a good job at taking the pictures that I am after.
I think that I should get ED 12-40mm f2.8 as it seems to be a great lens that will give me more freedom … and if I really find it to be incontinent while traveling, I should get either 12mm f2.0 or 17mm f1.8 and use one of those. I will always have ED 12-40 mm f2.8 to fall back on if I am looking for that diversity.
  1. Am I correct in assuming that ED 12-40 mm f2.8 is a great lens that will be a good fit for my needs?
  2. Assuming that I find ED 12-40 f2.8 to be convenient while travelling, is there really a need to purchase one of the other 2 lenses (taking into account what I intend to use the camera for)?
  3. Which of the two is more suitable for me considering what photos I am after?
Your answers are greatly appreciated and am more than happy to hear any other comments/suggestions you may have for me.
Thanks!
Dan
Olympus 12-40mm F2.8 Pro Olympus E-M1 Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2
traveler_101 Senior Member • Posts: 2,203
Re: Which Olympus lenses are right for me?
Dan the Newbie wrote:
Hi everyone:
Thanks!
Dan
Comparing fixed focal length lenses and zooms is a bit like comparing apples and oranges. Traditionally prime lenses were used because of better picture quality, but that is no longer really the case. However a prime lens will teach you much more about photography--about how to frame shots than a zoom will. Since you wish to learn about photography and are by all appearances open minded, and because you specifically mention the portability question, I would recommend you supplement the zoom with a prime lens. Of the two you mention the 17mm will be more useful as general lens. Wide enough for landscape and some good architectural shots and narrow enough for group portraits.
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Skeeterbytes Forum Pro • Posts: 23,186
Hi Dan,
The 12-40 is a very good travel lens and perhaps all you need. Why not give it a go before getting a prime within that range.You might find a tele or ultrawide zoom is a better second lens.
Cheers
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
Lumixdude Senior Member • Posts: 2,782
If you were smart you could pick up the 12mm, 17mm and 14-42 along with a cheaper body like the E-PL5 for roughly $1500.
Is the 12-40 worth the money? The devils in the detail really...
The problem is that the 12-40 resolves about as much detail as Micro Four Thirds sensors can currently resolve. The same goes for the Olympus 12mm, the 17mm is softer but acceptable.
Primes at this stage on Micro Four Thirds only really offer you advantage in terms of aperture. The 17mm F/1.8 is a nice lens if you need a traditional 35mm viewpoint in low light conditions and if you want to learn how to shoot the way a photo journalist would.
The 12mm F/2 is one of the sharpest lenses out there and by F/2.8 it matches the mark of the 12-40 F/2.8. I wouldn't say it's too wide, but that it's on the widest side of what would traditionally be considered normal.
The 12mm F/2 is my favorite on camera lens and it can be used in most scenarios, in portrait it has a narrow enough angle of view that that you can isolate your subject well. In landscape you can get it all in the lens and play with perspective distortion.
The downside of a wide angle lens like the 12mm is that you really do have to want to print a poster if you want to capture everything you've caught with your lens in the frame and that it's not quite wide enough to be fully immersive.
For the fully immersive experience you really need the 7-14 F/4 on the wider end and perhaps for a landscape photographer this is the ultimate lens available with a 14mm to 28mm frame it covers everything... Watch this in full screen to see what I mean about 14mm on the wide end.
https://www.youtube.com/watch?v=udbwS5-KXCQ
 Lumixdude's gear list:Lumixdude's gear list
Olympus PEN E-PL5 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 12mm 1:2 Apple iPhone 4 +2 more
Liqu New Member • Posts: 6
To start off with, do you need weather sealing on your camera? (Keep in mind you would also need weather-sealed lenses) At the moment, i see no reason to buy the EM1 over the EM10 considering the difference in price. I myself prefer the layout of the dials on the newer EM10.
The 12-40 f1.8 is a great, 'standard' zoom lens. I've got the chance to try it for a few days and it felt great not having to move around that much as I'm used to shooting with primes most of the time.The reason why I didn't buy one myself is because of the price, it would make me lazy, and because of the MFT system. The lenses are so small and light, I just can't justify spending 1k for a zoom lens instead of the beautiful prime lenses MFT has to offer.
I would recommend trying out a prime lens first and see how that works for you. You have stated that you want to learn more about photography; using prime lenses will help you learn how to compose an image and position yourself better.
What I would do in your situation:
  • Buy the EM10 over the EM1 (unless you really need one of the feature from the EM1)
  • Get the cheap 'must-have' lenses, these are in my opinion: 40-150mm telezoom lens. 45mm f1.8 great for portraits.
  • A wide lens; I would go for the 17mm because of the 'classic' 35mm equivalent focal length. If you need wider get the 12mm.
  • The 'standard' prime 25mm. If I could take one lens with me to travel with, it would be this. It's the lens that has the most up-time on my camera, although some may probably disagree with me; in my opinion this lens comes close to a general 'all-purpose' lens.
  • Bonus: Sigma 3 great prime lenses at f2.8. If you do not need the speed, the sigma lenses are really sharp and for a great price! really good value. (between 120-170 euros)
To sum it up: Cheap -> 40-150mm + 45mm f1.8  | Wide lens-> 17mm | 'Standard' lens -> 25mm f1.8
MFT systems are so light and small, not using primes is a crime!
SkiHound Veteran Member • Posts: 3,939
The IQ from the 12-40 is truly excellent. Just a very strong performer across the board. IMO, for someone without a lot of experience or solid reasons to pick a prime, this, or the Panasonic 12-35, would be a very good choice on the E-M1. I have the 17 f/1.8 and the Panasonic-Leica 25. The 12-40 generally seems sharper than the 17 (I do like the 17 a lot, however), at all common f-stops. In terms of sharpness, it's very close to the really excellent PL 25. By m43 standard the E-M1 and 12-40 is quite large and heavy. It's still much smaller and lighter than comparable SLR. I have an E-M5 and use primes a lot with no grip on the camera. That gives a small, light, camera to carry around. And I like to go out and just work with 1 focal length. But for travel when you don't know what you're going to run into the versatility of a lens like the 12-40 is really hard to beat. If you were to add 1 other lens I'd add either the 17 f/1.8, the PL 25 f/1.4, or the Oly 25 f/1.8. All would offer low light advantages compared to the 12-40 and would give you a smaller package. The Oly 25 is pretty new but is getting good reviews, it's smaller than the PL 25 but a little slower. If I were buying today I'd probably go for the Oly instead of the PL 25, but the latter is a very nice lens. The 17 is small and very fast focusing. Tests find it to not be superbly sharp but most users really like it. I really enjoy it. And, FWIW, as a travel camera I'd also consider the E-M10. Considerably smaller and lighter than the E-M1 with about the same image quality. It lacks environmental sealing, won't shoot as fast as the E-M1, won't do continuous AF as well as the E-M1, isn't as customizable as the E-M1, and doesn't have as many buttons to customize. But, it offers dual control dials (very important, IMO) and very high functionality in a smaller/lighter/less expensive package. With the 1-40 I'd definitely add the optional grip. But that would give you a lighter travel package and money with which you could add a small prime lens, or two. Mostly, have fun.
sigala1 Veteran Member • Posts: 3,911
Save yourself money and buy a Panasonic LX7
Hi everyone:
Thanks!
Dan
The problem with this question here is that people on this forum treat micro-four-thirds like a religion rather than a camera. It's like asking on a Christian forum if you should convert to Christianity; the people on the forum will feel it's their mission to convert you in order to save your soul and prevent you from going to hell.
I think the camera for you is the Panasonic LX7. It's only $299. I always recommend this camera to people who aren't ready to benefit from a more advanced camera. The LX7 plus Adobe Lightroom will give you better photographs than just using the JPEGs from even the most expensive cameras.
I posted this demonstration here:
http://www.dpreview.com/forums/post/53315802
proving that no one can tell the difference between the image from a Panasonic LX7 and one from a micro-four-thirds camera with the expensive Lecia 25mm f/1.4 lens.
JeanPierre Martel Veteran Member • Posts: 3,304
While I'm travelling, a normal zoom starting at 12mm is responsible for at least 85% of my shots. So the M.Zuiko 12-40mm could also be your all-purpose lens.
Once in a while (between 5 to 10% of the cases), I would need a telezoom. That's the M.Zuiko 40-150mm. It costs next to nothing.
Rarely, you might need a lens wider than your normal zoom. The Lumix 7-14mm could fit the bill. To be honest, since my normal zoom starts at 12mm (rather than 14mm) I use the Lumix 7-14mm less than 1% of the time. But when I need it, it's invaluable.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
jf_tea Senior Member • Posts: 1,577
Priorities: flexibility, weight/size, ergonomy, image quality, cost, ...?
Unless you have tried the E-M1, and, are familiar with changing lenses frequently, there are two steps you must do first, I think.
1) Go in a store to try a E-M1 with the 12-40 (or 12-50 if the store does not have the 12-40).
2) Decide what are your priorities: flexibility, weight/size, ergonomy, image quality, cost ?
Several people gave you honest, and, enthusiastic (and long) answers.
As sigala1 wrote, a LX7 might be enough for your needs (depending on your skills and goals). I was happy with a LX3 for a long while. The LX7 is certainly better than the LX3.
One thing you will read regularly in this forum (and elsewhere) is that any ISL camera by itself is not so important compared to the lenses you can mount on it. The largest investment will (gradually) be the lenses, not, the camera(s).
If you really want to carry a camera with you very often, you might be better with a smaller one (E-PM2, E-PL5, GX1, GM1), together with an small (pancake/power) zoom (Pana 12-32 or 14-42 PZ or Oly 14-42 EZ) or standard kit zoom (14-42). Or with a prime lens.
E-M1 : 497 g (1.10 lb)
12-40: 382 g (0.84 lb)
Total: 900g (1.94 lb).
For me, that weight is too much to carry around every time I go out for (maybe) taking pictures. I prefer to carry a GX1 + 20/1.7. Not always perfect, but, very usable, and, light.
YMMV
 jf_tea's gear list:jf_tea's gear list
Panasonic Lumix DMC-GX1 Pentax K-01 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Pentax smc DA 15mm F4 ED AL Limited +6 more
Bill from Oregon
Bill from Oregon Contributing Member • Posts: 539
Dan,
I'm kind of in the same boat that you are.  My new E-M1 along with the 12,mm-40mm/F2.8 pro zoom arrived two days ago.  I figure that almost all of my shooting will fall into that range of focal length.  So the 12-40 is my starting point.  Other forum members have commented on the size and weight of the E-M1 along with the 12-40 being "a bit much."  And I agree.  But having the zoom, especially a pretty fast zoom is also very versatile.  I figure to get some experience using the camera with 12-40 aboard and then...
And then... I really do love the simplicity of fixed focal length lenses.  So after using the zoom for a time, I'll check my images' metadata and learn what focal length I'm typically shooting.  That should offer a guide to my "next lens."
Hope this helps,
Bill
 Bill from Oregon's gear list:Bill from Oregon's gear list
Fujifilm X30 Olympus E-M1 Olympus PEN-F Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +2 more
El Chubasco
El Chubasco Contributing Member • Posts: 853
Hi everyone:
Thanks!
Dan
I have a bunch of primes collecting dust since I got the 12-40. IMHO zooms are the strength of m4/3. Small and very sharp. The 12-40 along with ibis will be very decent in low light.
Try the 12-40 first. Check what you like based on your shooting style and then buy what you really need. Otherwise you might be stuck with lenses you don't use and loose money when selling.
Good luck
 El Chubasco's gear list:El Chubasco's gear list
Fujifilm XF1 Fujifilm XP120 Panasonic LX100 II Fujifilm X-Pro2 Fujifilm X-H1 +16 more
