The Panasonic 20mm f/1.7 has horrific flare characteristics
Started May 4, 2014 | Discussions
iamaelephant New Member • Posts: 6
I thought I'd mention this because I read several reviews before picking this lens up and none of them mentioned the flare on this lens. This is kind of a big deal because this is an ideal lens for night time shooting in cities or indoors where you'll find a lot of high contrast scenes with point light sources (fairy lights, neons, bright bulbs in dark areas etc).
Overall I'm happy with the lens but you need to be very careful when using it around bright light sources. Here's a couple of examples from my first night using the lens.
Note the flared halos around each light.
This picture was overexposed so it's my fault but note the big green flare on the customer's back.
Because of the simple construction you don't tend to get flares that move across the frame when pointed at high-contrast lights, but those halos can be a bit of a deal breaker in some pictures.
Like I said I'm happy with the lens but I was surprised no one mentioned this flaring in the reviews I read.
robonrome
robonrome Senior Member • Posts: 2,334
Re: The Panasonic 20mm f/1.7 has horrific flare characteristics
Horrific? Really? How about some mature language.
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
jhinkey
jhinkey Senior Member • Posts: 2,817
I've taken a number of nigh shots with tiny lights in them and have not seen anything like this.  Do you have a filter on it?  Are the front and rear elements clean?  Is you sensor clean?
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic LX100 Nikon D800 Sony a7R II Panasonic G85 +27 more
s_grins
s_grins Forum Pro • Posts: 14,011
I think this lens just not for you. Get rid of it.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
OP iamaelephant New Member • Posts: 6
Yes. The lens was less than an hour old and the camera is practically new (3 or 4 weeks) and treated as such.
HornOUBet
HornOUBet Senior Member • Posts: 2,231
Agreed
 HornOUBet's gear list:HornOUBet's gear list
Panasonic Lumix DMC-ZS50 Canon G3 X Olympus OM-D E-M10 II Panasonic G95 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +12 more
HornOUBet
Also, no exif data doesn't help matters any....
drusus Contributing Member • Posts: 917
As someone ese already asked: do you have a filter on your 20 mm? I get the same green flare you showed when I have a protective UV filter on my 20 mm. I get very little, if any, flare without a filter. Do other lenses really do much better in handling point light sources indoors? I am very happy with my 20 mm, but my standards may be lower than yours.
Drusus
 drusus's gear list:drusus's gear list
Nikon Z fc Nikon AF-S Nikkor 50mm F1.8G Nikon Z 16-50mm F3.5-6.3 VR +3 more
krugman Contributing Member • Posts: 957
11
And it is slow to focus, and it searches in low light, and it's fat and ugly and mean as a snake.
Please send me yours,
Krugman
(unknown member) Veteran Member • Posts: 9,549
I don't see flare so much as haze with bright indoor backlight. It's not a huge deal and the lens is otherwise very good.
John Krumm
Juneau, AK
Ollie 2 Senior Member • Posts: 1,568
I agree.
It used to be a pretty good lens. Now it's just rubbish.
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 +20 more
Nemo0815 Contributing Member • Posts: 866
Krugman
And it strongly depends in which camera it is used...
 Nemo0815's gear list:Nemo0815's gear list
Panasonic Lumix DC-S5 Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 85mm F1.8 Sigma 35mm F2 DG DN Panasonic Lumix S 50mm F1.8 +1 more
eques Veteran Member • Posts: 4,115
Horrific flare characteristics - yes.
The 1,7/20mm is my favorite lens, but yes, it does flare. I never saw anything like in your first picture, but a lot like in the second.
After spoiling some very promising pictures by not keeping the sinking sun out of the frame, I bought a shade for the lens. It looks great, and I hope it has at least some use. Most of the time it helps to just change the perspective a little.
And it is noisy and AF is not very fast - but it is sharp and fast (F1,7) and focuses down to 0,2m and bokeh is ok and has a nice FL (a little wider would be better, but I would lose most of it's other endearing characteristics with the current MFT lens line up.)
Peter.
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Re: The Panasonic 20mm f/1.7 whom do you trust?
5
Evaluating this lens may depend on whom you trust.
I trust Roger Cicala of Lens Rentals. His review of a number of wide angle m4/3 lenses shows the Panasonic 20mm to be absolutely outstanding in sharpness, measured quantitatively with great expertise and great equipment..
I also trust SLRGear. Their review of the Pana 20mm by 17 people produced the following: (We don't know who the 17 were but I have found the SLRGears reviews to be very thorugh and knowledgeable):
94% recommended this lens.
Quality of construction: 8.94 out of 10
Image Quality: 9.47 out of 10.
Reviewers' overall rating: 9.41 out of 10.
Mu-4/3 is a highly respected forum, no trolls and lots og good photographers. Amin Sabet, well respected, chaired a review of the Pana 20mm. There were some complaints about speed of focusing, or noise, but the general tenor of the review was highly enthusiastic. People said it was the lens that attracted them to m4/3. Others said they have trouble taking it off the camera, it is that good.
Here are the urls:
http://www.lensrentals.com/blog/2012/05/wide-angle-micro-43-imatest-results
http://slrgear.com/reviews/showproduct.php/product/1295/cat/68
http://www.mu-43.com/reviews/showproduct.php?product=11&title=panasonic-lumix-g-20mm-f17-asph&cat=6
I have trouble seeing why we can always find something to be unhappy about in our lenses and in our cameras, and talk about it in long long treads like this one. I don't hear much of the joy and delight one might expect from these fine cameras and lenses, I hear what sounds like  perfectionism, and obsessional doubting, and maybe buyer's remorse.
Krugman
Ontario Gone
Ontario Gone Veteran Member • Posts: 4,183
HornOUBet wrote:
Agreed
Agreed
"Run to the light, Carol Anne. Run as fast as you can!"
 Ontario Gone's gear list:Ontario Gone's gear list
Nikon D7000 Canon EOS 70D Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 50mm F1.8G Canon EF 40mm f/2.8 STM
GeorgianBay1939
GeorgianBay1939 Veteran Member • Posts: 4,044
Here are the urls:
Krugman
Thank for posting that good information.
For a while here,  I thought that my standards were dismally low as I've always been very pleased with my 20/1.7 pancakes.  I got my first one with a GF1, when I decided to "get serious" with photography.
I loved that lens, and the camera.  One of my granddaughters now has that combo which she uses a lot.  I got another 20/1.7 when I got a GH2 which I still have. Yeah, it is a bit slow to AF until good technique is developed and it is a bit noisy (audible noise).  Now I put it on the GX7 and take it to indoor events ... where a lot of good "record" shots are made, shared and appreciated.
While I read some anecdotal "evaluations" of gear here I wouldn't make serious decisions informed  by them since most are very subjective and not particularly reproducible.   But there are several contributors to this forum who are not only very knowledgeable but carry the authority of rigor in their tests and experiments.  I admire them for their knowledge and patience in coping with some folks who have made judgements based on a paucity of data, and who have fragile egos (or something) which prevents them from learning from good data.  Fortunately, most of the time, the provision of authoritative data sorts out and clarifies the issue for the rest of us.
So thank you for your very helpful contributions.
Tom
 GeorgianBay1939's gear list:GeorgianBay1939's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 7-14mm F4 ASPH +9 more
s_grins
Re: Horrific flare characteristics - yes.
Peter.
I wasn't afraid to keep sinking sun in the frame, even in the middle of the frame. I like flare
Henry Richardson Forum Pro • Posts: 21,959
I like, or would like, this lens a lot too if it didn't cause banding with my E-M5 (also on several other m4/3 bodies).  Did all those reviews mention that?  If not then I suppose one must take *everyone's* review with a bit of salt since all reviews miss some things or choose not to mention them.
Henry Richardson
http://www.bakubo.com
s_grins
I trust professional reviews, and I'm very critical to all these "findings" and "apparent issues" here, on the forum.
Banding of 1.7/20 is a .. well... myth, non-existing issue. Sure, you have all your rights to think differently, but. please, use your own experience.
jim stirling
jim stirling Veteran Member • Posts: 7,356
The 20mm mounted on the GF1 was mu first step into mFT and to me it sums up mFT , very small, very light yet capable of great results.
 jim stirling's gear list:jim stirling's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Nikon D810 +12 more
