Olympus 14-42II R lens help - please
Started May 3, 2014 | Discussions
raiden78
raiden78 Junior Member • Posts: 31
Re: Olympus 14-42II R lens help - please
 raiden78's gear list:raiden78's gear list
Panasonic LX100 Canon EOS 7D Olympus PEN E-P3 Fujifilm X-E2 Sony a5100 +8 more
jlehet Regular Member • Posts: 131
Only in infrared.
dpalugyay wrote:
...right. Moving on.
Let's give you a poor grade in reading comprehension. ON THE INFRARED CAMERA it does. Otherwise, no, it doesn't. The 12-40 is fantastic in visible light, and not too bad in infrared either.
edstk New Member • Posts: 1
Hi!
I like to carry this lens when I travel because it is small and light. I think that's a good lens. Some close ups taken with this lens:
Edson T.Y.
 edstk's gear list:edstk's gear list
Olympus PEN E-PL5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Rokinon 7.5mm F3.5 UMC Fisheye CS
OP (unknown member) Contributing Member • Posts: 853
edstk wrote:
Hi!
Just  what I wanted to see!
Thanks so much,
Joel
Glen Barrington
Glen Barrington Forum Pro • Posts: 22,535
DON'T rely on DPR posted photos.
DPR softens photos mercilessly. And the kit lens is, at best, adequately sharp enough. But DPR can make it look worse than it does. Try to view your samples on Flickr or one of the other photo sharing sites.
Here is a link to a kit lens photo I took that resides on Flickr:
https://www.flickr.com/photos/7267302@N03/13698328064/
As regards the kit lens, I'm lucky enough to have come from a 4/3s DSLR and a sizable investment in DSLR lenses, so with the right adapter, I can use them without compromise.  I still use the kit lens, but only when speed and unobtrusiveness is as important as IQ.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 II Olympus E-M5 III Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +11 more
Re: DON'T rely on DPR posted photos.
Glen,
Thanks for your comments and your photo.
Joel
Sharper stopped down a bit
One thing you can see from the review on slrgear.com
http://slrgear.com/reviews/showcat.php/cat/15
is that this lens gets sharper stopped down a bit. This can have an impact on your close-ups in that you can't really control depth of field as much as you normally would, at least not without giving up sharpness.
In the test I mentioned above (where I mainly did the test with the IR body to test infrared, but then also on the non IR camera just to see), I tested at f 5.6 on all the lenses. This is probably a weak point for this lens at longer focal lengths, where it really needs to be stopped down.
I don't mean to be obnoxious by suggesting an expensinve lens, but the Olympus 60 f2.8 is the nicest macro lens ever. I've done a lot of macro photography, in the past with some classic and well regarded Nikkor macro lens. This Olympus 60 macro lens is just stupendously fantastic.
gsergei Contributing Member • Posts: 869
I can send you a few files from my em1
from my outing to Banff, Alberta. If you want, just let me know by PM.
Sergei,
Calgary.
www.alberta-photo.com
 gsergei's gear list:gsergei's gear list
Olympus E-1 Olympus E-3 Olympus E-330 Olympus PEN E-P2 Olympus E-M1 +12 more
thomasw333
thomasw333 Contributing Member • Posts: 512
Lets promote calm rational arguments.
 thomasw333's gear list:thomasw333's gear list
Olympus PEN E-PM2 Canon EOS Rebel SL1 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 17mm F1.8
thomasw333 wrote:
Beautiful images, thanks so much.
Joel
