jalywol
Re: GH3 or GX7: Telephoto setup with Panasonic 100-300mm
mfahim27753 wrote:
Hello everyone,
Hope you are well.
I want to have a small setup that I can take with me when I am shooting with my D800E. I do not want to keep changing lenses, and a 600mm equivalent lens is going to be really heavy, really expensive and really big. Also the time and inconvenience of changing lenses.
So anyway, I was thinking how this lens would go with either GH3 or GX7? Both bodies have their strengths and weaknesses, and I was wondering if anyone using this cameras with the lens in question (Panasonic 100-300mm) can shed some light in regards to performance of the lens and the body too? Also there's the weight balancing issue.
Also is this the best super telephoto zoom for m4/3 or are there any other alternatives?
My last m4/3 camera was a GH2 and it seems that m4/3 have come a long way from then so would love to hear your advise.
Many thanks everyone.
The 100-300mm works great on either the GH3 or GX7. I have used it on both and really like it.
In terms of balance on the camera...it does balance better on the GH3, but it's not bad on the GX7. With both cameras, with this lens, you would want to shoot with the electronic shutter when possible, as it helps reduce blur. You do also have to be careful with technique, as even small movements get amplified at the longest end. The OIS is very good, but a good steady hand (or tripod) and keeping the shutter speed up will give you the best results. This is not to say you can't get good shots at 1/250 (and sometimes even less!), but if you stay above 1/500 (and better over 1/1000) you will definitely get more keepers.
It's one of the lenses I use most frequently, and I enjoy it a lot. I'd love a 300mm prime, but for size, cost, and performance, this is a very good deal.
-J
