OSS with a monopod - anyone actually tested it?
Started May 3, 2014 | Questions
James Sherman
James Sherman Senior Member • Posts: 2,480
I know OSS on a tripod is a no-no, but I've never seen any discussion of actual tests of a tele lens on a monopod with the OSS on vs OSS off. Has anyone actually tried this out? I'd do it myself, but I'm wobbly myself, so I don't how much I'd be proving.
 James Sherman's gear list:James Sherman's gear list
Samyang 7.5mm F3.5 UMC Fisheye MFT Olympus E-M1 Olympus E-M5 II Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro +1 more
Dustinash Contributing Member • Posts: 673
Re: OSS with a monopod - anyone actually tested it?
I have shot with it on a fluid head monopod and it turned out stellar.  I think the systems are getting better.  That said it was video and under certain circumstances it maybe no good
Ynos Regular Member • Posts: 182
Monopod will eliminate main axis of vibration (vertical one), but there still will be motion left (back and forth, left to right etc), so I think OSS should perform just fine on monopods.
James Sherman
OP James Sherman Senior Member • Posts: 2,480
Logically, I agree with you, but I've never seen real proof of that. You'd think someone would have a tested, definitive, answer (at least for one lens - grasping at straws, here). What I'd reallylike to see is someone's results with the FE 70-200, preferably on an A7r since I'm dreaming. Being somewhat crippy, I can't hand hold that for very long (sez I, whose lens is on order) and a tripod on a mobility scooter is just a major PITA.
James Sherman
Nobody?
So is this an Urban Myth, or has some rowdy soul actually tried it? Any long-ish lens with OSS will do!
maccam
maccam Contributing Member • Posts: 808
Re: Nobody?
What's to test? A tripod is steady and turn off IS. A monopod is not very steady (especially with a really long lens). My Tamron 200-500 on the A77 was rockin and rollin zoomed out to 500. There was some wind and the subjects were water fowl. The first time I tried this rig and am going back to the tripod (with IS off).
jaw
 maccam's gear list:maccam's gear list
Sony RX100 III Sony Alpha NEX-5N Sony Alpha NEX-6 Sony a6500 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +5 more
Euell Senior Member • Posts: 2,972
The image stabilization on Canon lenses works fine on a monopod, so I assume Sony OSS probably does as well.
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony a6000 Sony a6500 Canon EF-S 17-55mm f/2.8 IS USM +13 more
James Sherman
Finally, a definitive answer. So much of what's posted here is hearsay and assumption. I expected this to be how it turned out, but I've certainly found myself in error enough times to ask for experience.
baltimorecaesar Regular Member • Posts: 470
I've used OSS with the SEL35f18 and NEX-7 on a monopod and it worked great, almost looked like it was on a tripod.  Certainly looked better with OSS on then off.
 baltimorecaesar's gear list:baltimorecaesar's gear list
Sony Alpha a7R II Sony FE 55mm F1.8 Sony FE 28mm F2 Sony FE 70-200mm F2.8 GM OSS
blue_skies
blue_skies Forum Pro • Posts: 11,473
What shutter speeds were that?
Depending on FL, 1/10th on a monopod, if heald steady, should be fine without OSS...
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha a7 II Sony Alpha a7R II +36 more
James Sherman
Agreed. I was looking more for something in the 135+ range, where you could see evidence of camera shake easily. I'm getting a 70-200 and will need to support it.
EinsteinsGhost
70-200G
It is one of the tele lenses that is likely designed for use on tripod with OSS. There is a two mode selection for OSS on the lens and that may be to enable OSS with tripod/monopod in use.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
James Sherman
Re: 70-200G
I thought of that switch, but I thought it basically allowed you to switch OFF the horizontal OSS so the camera could be panned without going all herky-jerky when OSS was on.  That's a subject for investigation whenever my lens gets here.
Henry
Sorry, forgot to mention this was while shooting video
James Sherman
Henry
Which doesn't count, really. Video images are "fixed up" by your brain as you watch. A nice sharp (looking) video can be made up from a lot of awful images.
