Canon 17-40mm L, sharpness ok?
Started May 1, 2014 | Discussions
DrShouter New Member • Posts: 3
Hey everybody,
A few days ago i bought a new 17-40mm L UW Lens, but I´m very dissapointed about the sharpness.
Is the blurriness at the edge and the corners normal for this lens?
Sorry for the silly question but this is my firs UW, 90% of my pictures were taken with the 70-200 f2.8 and this thing is razorsharp (Yes i know its a Tele).
Orginal Raws, out of the cam!
https://www.dropbox.com/sh/9r2ka4n8pn63hhb/g15WdQb8VX
Thanks!
rebel99 Veteran Member • Posts: 4,025
Re: Canon 17-40mm L, sharpness ok?
DrShouter wrote:
Hey everybody,
Thanks!
17-40 f4 on a FF may cause some blurriness on the edges or some vignetting but it works great on a crop camera, here is a gallery that was taken entirely with 17-40:
http://azbaha.zenfolio.com/p572883877
cheerz.
Timbukto Veteran Member • Posts: 4,988
DrShouter wrote:
Hey everybody,
Thanks!
Your copy looks very good, it makes me want to buy the lens. DxOMark rated this lens as very good for the size/money. Wonderful when stopped down as you did in these RAWs.
There is nothing wrong with the corners, you are likely confused about wide angle distortion and used to telephoto distortion. Extension vs Compression.
Some of the blurriness is likely due to shutter speed and moving carriage. You may think the shutter speed is enough to freeze anything at such a wide focal length but again consider the properties of the UWA...subjects that move around in the center of the frame will shift pixels at a far slower rate compared to those that move near the edge or corners of your frame (at a rather high rate of movement across the pixels of your sensor).  You can prove this by just taking video at 17mm and examining movement across the frame...I bet movement at borders/corners will shift faster than center...
Although it is the f11 shots that look good...your impromptu paper chart is meaningless with the UWA as 99% chance your test is wrong just looking at your taped up scissor cut test chart...
I would be more interested in seeing real photo UWA's taken at say f8 to really see if your copy is good, or even f5.6
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
billythek Veteran Member • Posts: 5,260
The 17-40 is not the sharpest lens, but it is cheaper than the 16-35 which is not stellar, either (compared to say the 17 TSE or the Zeiss 21). Primes are the way to go for serious landscape. Well, panos taken with the 24-70II look pretty good, too. I have a few of those in my gallery.
I've heard that the DLO feature of DPP does a good job of improving pictures taken with the 17-40. You might try that out.
I know what you mean by the sharpness of the 70-200. It is a spoiler, and what led me to dump the 24-105 for the 24-70II.
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM
OP DrShouter New Member • Posts: 3
Thank you all for your assessment.
Yes, I know that my Testchart is not ideal, in the Dropbox there are 2 other "real life" pictures,  both with f11 and 17mm (taken in Vienna).
Lions Contributing Member • Posts: 558
DrShouter wrote:
Hey everybody,
Thanks!
Return it ASAP if possible, on FX very pronounced distortion and soft corners.
Ken
 Lions's gear list:Lions's gear list
Canon EOS 5D Mark IV Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 1.4x III Canon Extender EF 2x III +4 more
polizonte
polizonte Senior Member • Posts: 1,131
Even when I had a 40D, XTi, this was my impression also...EFS 60mm f2.8, much better, the 135mm f2 I would buy it again but the 17-40mm, maybe my copy was just "okay" but "nothing to write home about"..
Es mejor pescar que ser pescado.
 polizonte's gear list:polizonte's gear list
Nikon D810 Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon 85mm F1.8G Sigma 135mm F1.8 Art Sigma 40mm F1.4 DG HSM +5 more
Jon Tr
Jon Tr Regular Member • Posts: 254
Never been really happy with my 17-40 (on FF), soft outside the center, gets better when stopped down but never sharp in the corners.
 Jon Tr's gear list:Jon Tr's gear list
Canon EOS 5D Mark II Olympus OM-D E-M5 Canon EOS 5D Mark III Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM +8 more
polizonte
You nailed it.
Abu Mahendra Veteran Member • Posts: 5,312
Return the 17-40L. Wait till Canon comes out with a great UW zoom...
...in the meantime, pick up an EF-M 11-22 IS STM (on an M), and make that your UW shooter.
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
lighthunter80
lighthunter80 Contributing Member • Posts: 990
DrShouter wrote:
Hey everybody,
10 Minutes of research would have told you that this is not the sharpest L lens and especially corner sharpness is not its strength. Even at f8 and beyond it never gets really sharp. The 16-35L II is better but also this one is not the sharpest in the corners but a bit better.
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
gipper51 Veteran Member • Posts: 5,904
The 17-40 is often blurry in the corners if you use autofocus for objects further away.  The lens focuses correctly, but that's often too far for the near corners to be sharp.  Try experimenting with manually focusing and I bet you'll find they get better.
I've found the lens is best at f11, where if focused properly it's quite sharp into the extreme corners (a good copy anyway).
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
stratobill Senior Member • Posts: 2,081
polizonte wrote:
You nailed it.
Returned mine, got the 16-35 F2.8L, not perfect but a lot better.
Nikon is stronger in the wide end lenses I think, but the 16-35 has better corners, color and contrast than the 17-40 for me. YMMV.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
jcochran Senior Member • Posts: 1,386
Here is a site that shows images taken with the Canon 17-40 f/4 L USM lens. Browse through them and you may get an idea of its capabilities. Most show the exif data.
https://www.flickr.com/groups/_canon_17-40_f4l_usm/
 jcochran's gear list:jcochran's gear list
Fujifilm X100V Canon EOS M Canon EOS M5 Fujifilm X-T3 Canon EOS RP +22 more
ktownbill Senior Member • Posts: 2,196
DrShouter wrote:
Hey everybody,
Thanks!
If you want sharper edges and corners you need to shoot at f/8 and narrower. Or use a prime lens. The 17-40L shoots on-par with the 16-35L once you close it down to f/8. If you don't need a wider aperture than f/8, such as for landscape for example, your lens is fine. Ck for yourself in the link. Mouse over the image to switch between the 2 lenses. Enter your own choice of lens for comparison such as one of the many primes.
The 17-40L is a bargain for only $800 compared to $1600 for the 16-35L. (for f/8 and narrower aperture that is) The center sharpness is still good at f/4.
The 16-35L edges out the 17-40L in color and contrast but PP levels that playing field pretty much.
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=100&Camera=453&Sample=0&FLI=2&API=3&LensComp=114&CameraComp=9&SampleComp=0&FLIComp=2&APIComp=4
Bill
epozar
epozar Senior Member • Posts: 1,969
Same with me.
Next came Sigma 12-24, and finally Nikkor 14-24. Sharp at last.
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
