OP
iansmith
Regular Member
Re: International Space Station crossing the Sun as seen by Micro Four Thirds.
Skeeterbytes wrote:
iansmith wrote:
My plan is to try to do burst next time. For my first attempt I wanted the best chances of getting something so used video. The E-P5 only can do about 1.5 seconds of RAW burst though, which is pretty tricky timing.
Since the pass is only about half a second long, running out of buffer could pause it long enough to totally miss it.
I'm going to get one of the 95MB/s Sandisk cards to see if I can get the 5fps continious shooting in L mode that the review here says. My current 45MB/s card can't do it.
Am curious about the time window and how you determine when to begin shooting (I'm presuming you're not counting on seeing it cross the solar disc itself). With video and a fairly accurate timepiece you can just start and stop it with a comfortable margin, but with burst you'd need very precise timing to not bang into the buffer too soon. Would a cellphone be accurate enough, would a GPS be better, or...?
p.s. Even at 10fps I don't seem to have a frame limit on the E-M1 set to LB. RAW is a different matter.
Yeah, the E-P5 has too small of a buffer I am finding. You can take 50 shots at 10fps before it fills, the E-P5 can only take 15. Once my buffer fills I can only get about 1.5fps. Hopefully I can get 5fps sustained with the SanDisk.
Timing is tricky, aside from needing an accurate clock that shows seconds, the ISS is variable in it's orbit. Data for it's exact position is only updated a few times a week by NASA and every few hours by 3rd party tracking systems, so even with the most up to date numbers if you are unlucky it could show up a second or two earlier or later.
DP's review said the E-P5 can do 5fps until the card fills, so I am going to just start taking pictures 10 seconds before the event and hope at least one of the 2-3 pictures I get is nice and free of atmospheric distortions.
Just picked up a 95Mb/s rated SanDisk.. only getting about half the speed I should. Will have to post in another thread about it.
