Anyone with the new Samsung 16-50mm f2-2.8
Started Apr 29, 2014 | Discussions
Samsunguser Regular Member • Posts: 420
Hi,
anyone with the new Samsung 16-50mm f2-2.8mm can share his opinion.
Is the  quality of image better on 16mm, 20mm and 30mm than the prime lens with the same focal (wide open)?
is there any tested review? (No pre-review)
Samsung 16-50mm F3.5-5.6 power zoom
Kaziklu Senior Member • Posts: 1,301
Re: Anyone with the new Samsung 16-50mm f2-2.8
It's not a matter of is it better then the Primes.... the primes should and will almost always be better.
The question is how much better is it compared to the 20-50 and the 18-55. Remember is designed to be a more high quality kit lens for those time where you don't want to be changing lens' all the time and don't mind the extra size
The other side is I'd like to see it compared to other 16-50 and 24-70 lens'
I know based on my experiences with the people on this board people will say...
"well the chromatic aberration of the 16-50 is higher then that of the 30mm f2 prime so I'd rather carry the 16,20,30,45,and 60 around with me because if covers the same range."
others will say "it's too big for a mirrorless camera system.. you might as well get a DSLR."
And they can... but the reality is for people that either can't, or don't want to carry 5 lens' and need more then the 18-55 can provide.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
Glush Junior Member • Posts: 40
Could not agree more!
Changing lens in a boggy field if a real faff.
If this lens offers fewer compromises over carrying the prime lens equivalents, compares well with similar zoom offerings from sigma canon and the like then why not.
 Glush's gear list:Glush's gear list
Konica Minolta DiMAGE A200 Panasonic Lumix DMC-TS5 Sony Alpha DSLR-A700 Samsung NX300 Samsung NX 20-50mm F3.5-5.6 ED +1 more
OP Samsunguser Regular Member • Posts: 420
I really expect this zoom has AT LEAST THE SAME quality of the primes lens with same focal, other way (with its high price) is a nonsense
jennyrae Senior Member • Posts: 2,690
point of such lens is provide fast zoom than kitlens. it is known that fast zoom quality is between kitlens and prime lens. you buy lens because of speed gain of 1.7 to 2 stops which is crucial for shooting in lowlight. also help with field depth isolation of subject.
kitlens quality is already very good. a bit of improvement put it to excellent level. judging from pictures, quality appear somewhere close to 45mm prime.
in agreement with others that 16-50 f2-f2.8 lens is one lens solution for people needing speed and getting quality pictures as close as primes with no need to change lenses.
laugh. if that was true, no one will be buying primes anymore. pricing of fast zooms is based on manufacturer discretion but comparing with other equivalent zooms, price is just right considering it is f2-f2.8. not too cheap and not too expensive. my opinion if lens is priced at $900, it will sell a lot faster.
The price for this kinda of tele lens is always in this range... this is in fact at the low end of the range I expected it to be in.
It is not cheap to get a lens to be f2-2.8 through out the range. That is why 35mm 24-70 and 70-200 f2.8 lens' are always very expensive.
What you are paying for is the zoom. Right now B&H has fairly low prices for the 4 (16,20,30,45) Primes and they come out to be 100 cheaper then the 16-50 but what you pay for is the convenience and the ability to use the whole range in one lens' at a good quality.
I don't shoot events, or weddings, and I don't do travel photography, so I may not go after this, as I really only need the 30 and 16 lens. and I would usually use them at different times.
But I want to know the quality because I want to see a 50-135/150 that I would use.
(unknown member) Contributing Member • Posts: 947
In that case I suspect you are doomed to disappointment. As previously posted the primes are very good. The 30mm especially, is as good as any of the main makers own brand offerings.
It's very rare for any maker to produce a zoom that beats their primes, simple physics of simpler prime lenses vs. multiple element complex zooms and manufacturing cost / quality control. You might find a 'sweet spot' in the zoom which is as good as a prime but not across the entire range: The 50-200 comes to mind as it's a popular topic on the forum right now. The 50mm end is very good (prime quality) the 100mm end is ok and the 200mm end is poor).
Hell, Kyocera Corporation produced some of the finest 35mm film lenses ever made under the Zeiss Contax label (apologies to Leica) for the Contax G series. Prices to match the quality but the 35-70 zoom for the Contax G2 was a dud in a manner of speaking.. The lens was no budget wonder and beautifully made and outclassed many other prime label lenses on its own merits but was nowhere near the primes in optical quality for the Zeiss range.
No Trolls in Norway: They all took the bus to DPR.
trac63 Contributing Member • Posts: 814
I suspect that the lens is being introduced to allow Samsung's NX series to compete with similar products from Olympus, Panasonic and Fujifilm.
I do wonder how many people will be willing to plonk down $2,300 for the NX30 + 16-50mm combination though. That's dangerously close to what you'd pay for a D610 with the 24-85 kit lens, or the Canon 6D with the 24-105 kit lens.
So here is the thing people forget. If you get a D7100 with a 24-70 (which gives you less wide range because it's designed for a full frame camera) it's the same cost.
Samsung is producing the lens because it wants to be a full featured system.
The only reason I might not get this one is because I don't shoot events and weddings. the NX system can do it.. but I'm not interested in that, I don't enjoy it and I'm not great at it. When I'm with other photographers, the question with "professional" grade lens comes up. This shows commitment from Samsung.
Like I said the companion lens (the 50-135/150) that hasn't been announced yet (but I hope it exists) is the one I want for the stuff I do.
Mirrorless is a system that combines the benefits of a DSLR and the compact size options of Compact Camera.
The NX system has the wonderful Pancakes and the big lens. The Small Bodies and the Big Bodies...
this means I can grab my NX20 go shoot a Landscapes, or even a model, and then when I'm on a photowalk, or just traveling get a NX2000 body and use a pancake and a zoom.. or even get the 16-50 power zoom.
that is where the NX system shines.. it is a one stop shop for APS-C and it does a fairly good job at it.
Mr.NoFlash Senior Member • Posts: 2,374
I do not have those primes but
... look at my new thread.
thanks
Mr.NoFlash
 Mr.NoFlash's gear list:Mr.NoFlash's gear list
Fujifilm FinePix Real 3D W1 Leica Digilux 3 Samsung NX300 Fujifilm X-M1
