Partial Solar Eclipse - 300mm
Started Apr 29, 2014 | Photos
Martin.au
Martin.au Forum Pro • Posts: 14,339
6
Just spent a little bit of time this afternoon messing around with some Baader Astrosolar safety film, and the 75-300.
I'm happy, especially considering my bodged together setup. (Viewing film whacked on the end of the lens and held in place with a spare filter.)
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
kiri Senior Member • Posts: 1,656
Re: Partial Solar Eclipse - 300mm
Lumixdude Senior Member • Posts: 2,782
It's nice and sharp, pretty good for focusing at the sun.
 Lumixdude's gear list:Lumixdude's gear list
Olympus PEN E-PL5 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 12mm 1:2 Apple iPhone 4 +2 more
Martin.au
OP Martin.au Forum Pro • Posts: 14,339
Well, the focussing was pretty easy actually. If you look at the exif information you can see just how much light the film cut out.
Was funny getting this stuff sorted. The first camera shop I tried suggested using just a variable ND filter, which I thought sounded bloody dangerous. I did test it at ND400, as with an EVF I couldn't hurt myself and, as expect, it failed. The sun was still very blown, even through clouds. Pretty bad advice, imo. I'd hate to see what the results would be if someone tried it with an OVF.
Michael J Davis
Michael J Davis Veteran Member • Posts: 3,755
Excellent! (nt)
Mike Davis
Photographing the public for over 50 years
www.flickr.com/photos/watchman
 Michael J Davis's gear list:Michael J Davis's gear list
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +6 more
uRebel Rob Senior Member • Posts: 1,537
Wow. The last solar eclipse I went to say (May 2012) said that you needed at least a 14 stop filter, and ND400 is only 9 stops. The Baader Astrosolar safety film you used says it has an optical density of 5.0, which is between 16 and 17 stops, and you still shoot at 1/1600. That would put a 14 stop filter (or say a ND1000 + ND16 stack) at about 1/8000. ND400 is terrible advice.
I didn't get nearly as nice photos as you did. I used a VND with max rating of ND1000, 1/4000 SS (max for my D5100), f/22 on a 18-200mm at 200mm, and even with the clouds the sun was burnt out until it was mostly covered. I knew I was using an under-strength filter, so I never looked though the OVF. I wish I knew about the eclipse more in advanced, as the films like you used were all sold out by the time I started looking for them.
Great photo and thanks for sharing!
 uRebel Rob's gear list:uRebel Rob's gear list
Pentax K-1 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Pentax FA 28-105mm F3.5-5.6 Nikon D5100 +21 more
Martin.au
What really surprised me, in a good way was: VND = $150. Astrosolar film = $40 for an a4 sheet, which is enough for a whole bunch of lenses.
shutterspeed1000 New Member • Posts: 6
Looks like a great shot with good details on the sun.  Thanks for sharing the setup.
RichRMA Veteran Member • Posts: 4,073
Good shot, fairly large sunspot group.
AV Janus Senior Member • Posts: 1,994
Looks good and sharp.
a bit more sharper and more purple tinted than what I can get with my Minolta 200mm and similar Solar filter film.
Rick Halle wrote:
" Keep in mind that tall buildings sway back and forth so they require faster shutter speeds."
 AV Janus's gear list:AV Janus's gear list
Olympus OM-D E-M5 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Samyang 85mm F1.4 Aspherical IF +10 more
iansmith
iansmith Regular Member • Posts: 328
Nice picture, wish it would have been visible from here too.
What gave it the red tint, was it near sunset?
 iansmith's gear list:iansmith's gear list
Olympus PEN E-P5 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
Martin.au
A little bit, but it was mostly, just me playing around with the white balance.
