NX300 Battery Drain when off?
Started Apr 27, 2014 | Discussions
davidp Regular Member • Posts: 203
My nx300 appears to be draining the battery when stored in the OFF position with the kit 20-50 lens mounted.  Happens both with the Samsung OEM battery and new Wasabi's I just bought and charged.  Appears to be about a week or so and the battery in the camera is completely dead, while a spare I charged at about the same time still has almost full life.
Anyone else experiencing a similar situation?
 davidp's gear list:davidp's gear list
Panasonic Lumix DMC-ZS7 Samsung NX300 Fujifilm X-T1 Nikon AF Nikkor 50mm f/1.8D Samsung NX 30mm F2 Pancake +2 more
Samsung NX300M
Bryan M
Bryan M Contributing Member • Posts: 956
Re: NX300 Battery Drain when off?
I have the NX300 and the battery drain you describe is certainly not normal. Sorry to read about the issue.
Bryan
www.bcmcue.com
www.mordtimage.com
 Bryan M's gear list:Bryan M's gear list
Nikon D750 Nikon Z6 Tamron SP 70-300mm F4-5.6 Di VC USD Tamron SP 70-200 F2.8 G2 Nikon Z 14-30mm F4 +2 more
(unknown member) Contributing Member • Posts: 947
Old wisdom with old tech batteries was to take them out when the camera wasn't in use to a) preserve the charge and b) stop them leaking their guts into the 'works'. I had a Contax G very badly damaged by leaking batteries which needed an expensive visit to camera hospital.
All batteries will lose some of their charge over time (up to 10% week) and lithium's are no exception. Lithium's life is also shortened by continuously charging and then storing at full capacity without running it down.
I have a Nikon D610 which doesn't seem to use any power at all when off compare to a Samsung NX11 which will flat it's battery in a week. Compare this to a GoPro 3 which seems to have a firmware 'bug' and will drain it's battery in under a day even when off.
Doing a quick google search shows queries on flat batteries across all brands. It is possible given the complexity of a modern camera that the battery is used in some form of 'keep alive' perhaps powering RAM or clock settings etc even when the camera is turned off?
The solutions to all these is to take the battery out when the camera is stored.
No Trolls in Norway: They all took the bus to DPR.
OP davidp Regular Member • Posts: 203
Thanks, and that's exactly what I'll do now..  I do seem to get good life out of the Wasabi's during a day of shooting, so now with 3 batteries, I'll just follow your suggestion.   When not in use, no power....
Mr.NoFlash Senior Member • Posts: 2,374
Really take the battery out ?
The big question is: Is there a camera-internal Mini-battery to support the clock and perhaps settings ?
If there is a camera-internal Mini-battery, then it is not great to take the battery out for a long time, because then the camera-internal Mini-battery gets flattened, and this is not good for the camera-internal Mini-battery.
If there is no camera-internal Mini-battery, then you can indeed simply take out the 1130 battery.
I have a tendency to think there is no camera-internal Mini-battery in the Nx300, instead a capacitor, which would not be hurt.
But I like to know it for sure.
On my old Panasonic cameras, there was the camera-internal Mini-battery problem-
 Mr.NoFlash's gear list:Mr.NoFlash's gear list
Fujifilm FinePix Real 3D W1 Leica Digilux 3 Samsung NX300 Fujifilm X-M1
tjobbe
tjobbe Senior Member • Posts: 1,430
Re: Really take the battery out ?
So far the OEM's I do have are all really good in keeping the capacity even when sitting in the camera and the switch set to ON so that the camera is in Stand-by mode
for non OEM Batteries I would not do the same as I have at least three that have a high self unloading tendency. Did you observe thatthe 3rd party battery unloads itself after a while when outside of the NX ?
If the observed behaviour (unloading within the NX) is the same for OEM and 3rd I would assume that there is a power drain within the NX as I have not seen that with any NX I have had so far.
 tjobbe's gear list:tjobbe's gear list
Samsung NX300 Samsung NX30 Samyang 35mm F1.4 AS UMC Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +18 more
NX10-11 had a capacitor. One of mine has died and loses all its clock settings when the battery is out. The other is working fine after years on the job.
Why? It's no different to running down and charging any other battery. All batteries have a 'cycle' number and life time. Keeping a battery fully charged makes no difference to overall life.
Stan Still Regular Member • Posts: 227
I know that this is an old thread but I have just been called by Samsung Customer care about battery drain when the battery is left in the camera without using it.  I contacted them because if I leave the camera for about 3 weeks, the battery will be drained within 5 photos.
He told me that it is quite normal for the batteries to self discharge in the camera  in 2 weeks if not used.  When I asked him if there is something working inside the camera to discharge the battery he said that it was beyond his technical ability to answer that.  I also asked if it would be better to remove the battery from the camera when not being used, he said "I could give it a try".
This is a very unsatisfactory state of affairs, "2 weeks" to discharge the battery in the camera? I use original and after market batteries and they all do this.  And as for the "technical competence" of the Support staff words fail me.
 Stan Still's gear list:Stan Still's gear list
Panasonic FZ1000 Panasonic LX100 Panasonic ZS100
bryguy
bryguy Regular Member • Posts: 144
Why not just remove the battery when you're storing it then, if it bothers you? Mine drains too, but I'll either pop in a freshly charged battery (I have 3 after all) or plug in the micro usb charger (I have many plugged in for cellphones, etc.). No biggie.
There are metal contacts that are conductive that the batteries are constantly pressed up against. It drains batteries. For example, that's why electronics and remotes that are shipped with batteries in them have a tab pull somtimes to remove the barrier which prevents battery drain and operation.
 bryguy's gear list:bryguy's gear list
Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS Samsung NX 45mm F1.8
I have 3 Fuji cameras and none of them discharge their batteries for months. Is their something special about Samsung's as they all have metal prongs that the battery connects to?  I agree I can take the battery out but will it lose settings like time and date etc. Why does this apply to Samsung cameras and not others ( unless you know different).
tjobbe
Stan Still wrote:
.... Why does this apply to Samsung cameras and not others ( unless you know different).
I would not say "Samsung" but NX300...
I did have one NX300 where the main board got changed and only after that exchange, the camera did show the battery drain when even originial batteries where left in the NX300.
With NX Mini, NX20, NX30 or Galaxy NX I do not have this at all.....just that one NX300 POST exchange of the board... prior to that repair (defective USB) nada, the second NX300 I did own nada... both did not show that, so it might well be some charge of motherboards only.
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
Hrm, I've not noticed any unusual discharge with my NX300M. Maybe it has newer components, but I was under the impression that NX300 and NX300M are basically the same in terms of software and hardware, minus the difference in screen tilting/additional feature for selfie mode.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
I have two original Samsung 1130 batteries. They do not self discharge in weeks, in the Nx300 or outside. But Samsung may make no promises so Samsung does not have to replace anything.
cheers
Mr.NoFlash
Sorry for typing errors - i decided to save time not to correct all typing errors
declan79
declan79 Regular Member • Posts: 366
even after upgraded to the latest firmware 1.4, feel slightly better but still battery drain
 declan79's gear list:declan79's gear list
Olympus E-3 Olympus OM-D E-M5 Samsung NX300 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Panasonic Leica D Summilux Asph 25mm F1.4 +6 more
Karroly Forum Member • Posts: 57
I know this is an old thread but you miss something about battery life. Letting a battery go flat (0 volt) shortens its life. If a battery goes flat too often it will die quickly. Li-Ion battery voltage should not go below about 2.5 volts per cell to preserve its lifespan. As you cannot change the small internal battery yourself most of the time, it is safer to avoid it to go flat by letting the big battery in the camera when the camera is off. The big battery will keep the internal clock running and the personal configuration data much longer than the small internal battery alone. But you must think about replacing the big battery with a fresh one before its voltage go below 2.5 volts per cell...
 Karroly's gear list:Karroly's gear list
Kodak EasyShare P880 Olympus XZ-2 iHS Olympus Stylus 1s Samsung NX11 Samsung NX30 +30 more
MikeSor New Member • Posts: 2
The internal battery on my Samsung NX300 won't hold a charge and thus the date / time is continually wrong. Is it a bad battery, or maybe a bad capacitor? Thanks, MikeSor
Isola Verde
Isola Verde Forum Pro • Posts: 10,630
Only a few days ago I tried my own NX300, after leaving it in a drawer for several months - and yes, the battery was flat and the date/time needed resetting... and those were then lost afresh when I removed and reinserted a charged battery.
Good news for me though was that it did settle (after leaving it with a charged battery in it for a day or so), and now works as it had done previously... although I've not left it without a battery in it for more than a few minutes.
Some time back I had a very similar experience with the NX3000 - which needed a little longer, but did eventually respond in the same way! [That one has the benefit of USB charging, so is easier to "top up" occasionally, which I now try to remember to do!]
So I'd recommend persevering, as the capacitor - or whatever it is inside - does seem capable of being revived.
Good luck,
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
Thanks Peter. Yeah that's route I'll have to take. The assistant on the Samsung support chat suggested contacting the 800 helpline to find a serve dealer near me. I do very much appreciate your insight though. Also I REALLY enjoyed checking out you architecture photos on you Flickr feed. Here's mine if you want to check it out; https://www.flickr.com/photos/40072693@N04/ . Take care and be well, Mike
