Cross platform equivalency
Started Apr 25, 2014 | Discussions
qianp2k Forum Pro • Posts: 10,350
Re: Joe, in the studio, I find larger format has less benefit for me.
Silverback1988 wrote:
qianp2k wrote:
I own 70-200L II and 5D2 and used to own 60D. 5D2 is clearly sharper than 60D with the same EF lenses (any EF lenses) including 70-200L II if both fill the subjects into the same AOV.
Dang, I should upgrade my eyes
My eyes consider the sharpness are about the same. The DOF is my main worry there.
Outside the DOF, the blur take the sharpness heavily.
No problem with the sharpness within the DOF, even if it is done with 7D.
APS-C sensors enlarge pixels 1.6x more to project on the output at the same size on so-called crop penalty.
Maybe the lens sharpness is still up to it, Peter ?
Depends on what you shoot. In studio portrait, usually you applied some smoothness so skin will look better and smoother where you might not see much difference. But if you shoot two cameras outside in landscape with lots of fine details, you will see noticeable difference when you fit them into the same AOV.
http://www.dxomark.com/Lenses/Compare/Side-by-side/Canon-EF70-200mm-f28L-IS-II-USM-on-Canon-EOS-5D-Mark-II-versus-Canon-EF70-200mm-f28L-IS-II-USM-on-Canon-EOS-7D-versus-Canon-EF70-200mm-f28L-IS-II-USM-on-Canon-EOS-5D-Mark-III___408_483_408_619_408_795
You can see with this zoom, 5D2 has peak 18mpx (will be 21mpx on 5D3) while 7D has peak 12mpix, that is not a small difference.
Here is 5D2 with kit zoom 24-105L at 5000-pixel wide. Don't believe 7D/60D with comparable zoom EF-S 17-55/2.8 IS or EF-S 15-85/3.5-5.6 IS or the same 24-105L could deliver similar sharpness at this size.
24-105L on 5D2, 5000-pixel wide
70-200L II on 5D3 hand-held, 2500-pixel wide
This 70-200L II zoom is very sharp and will resolve noticeable more if Canon releases a mega-pixel camera.  Even its little brother 70-200L/4.0 IS is pretty sharp.  Here is a sample with 36mp A7R thru adapter hand-held.
70-200L/4.0 IS on A7R hand-held, 5000-pixel wide
Just another Canon shooter
Just another Canon shooter Veteran Member • Posts: 4,691
Re: Yes.
Yes, I could understand if it is wide open.
In my case it is already stopped down enough... f/5.6 & f/9 on f/2.8 lens.
But your link in your post below shocked me.
http://www.dpreview.com/forums/post/53566424
The difference is obvious indeed.
As I remember, there is no significant difference between the two (in those setting).
I just look my work recently in the studio with 7D. It's fine with the sharpness.
The difference is there but the 7D may still be good enough, or even excellent for portraits in your studio.
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +4 more
Silverback1988 Contributing Member • Posts: 706
Thanks Dave, but ...
Your eyes are likely fine. In a landscape scene, say with a 16x24 print, you would be hard pressed to see a difference. That is why I stopped worrying about it a long time ago.
That's my experience as well. I often make 40x60 cm and 60x90 cm prints.
I decided to keep my 5DII for shots that significantly different than my 7D,
shallow DOF pictures that can not be done with 7D setup or need wider FOV (ie. 5DII with 24 L II).
For studio shots, I see no significant difference between 5DII and 7D setup (see in my other post above).
But however, just another Canon send me this link and shocked me :
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=687&Camera=453&Sample=0&FLI=2&API=4&LensComp=687&CameraComp=736&SampleComp=0&FLIComp=1&APIComp=3
I could I understand if wide open (f/2.8) vs stopped down (f/4) make a difference,
but f/5.6 vs f/8 ??
I wonder if some mistakes had been made to the 60D's chart shot.
It look so soft.
But again, a professional who knows what they are doing did the chart shot, thus I begin to questioning my own eyes
But I am quite happy with the 7D's result, that's all that matter isn't it ?
Brian
samples?
Brian
Can you post a few samples in large sizes such as at least 2500-pixel wide or 5000-pixel wide as I did?  But as long as you're happy that is perfectly fine as nobody could question your subjective satisfaction level.
Thanks, just another Canon.
I think you are right ...
The difference is there but my eyes could not detect it
And I agree that the 7D still good enough in the studio.
But I will give my 5DII a try someday.
Thank you for the link.
Brian
The Davinator
The Davinator Forum Pro • Posts: 20,695
Re: Thanks Dave, but ...
but f/5.6 vs f/8 ??
It look so soft.
Yes, it is. Some people rely too much on DxO, etc, instead of using their own eyes on their own subject matter.
Brian
 The Davinator's gear list:The Davinator's gear list
Canon PowerShot G3 Canon PowerShot SX150 IS Canon EOS D30 Canon EOS 10D Nikon D2X +16 more
Here the samples ...
Brian
Peter, here some samples, at f/5.6 & at f/8,
but you get the idea the sharpness I am looking for.
https://dl-web.dropbox.com/get/BRIAN_photo%20sharing/IMG_3423.JPG?_subject_uid=125164610&w=AAC5MP9xmogzRK8YjOikEnYH6oC1z4MsNbCtGaFkb0It0g
https://dl-web.dropbox.com/get/BRIAN_photo%20sharing/IMG_1839.jpg?_subject_uid=125164610&w=AADeNp6oJAIErgCI_jqaNaQNkFOpEvUkkGUtbus6CSfjwA
Yes,
IMHO, as our knowledge is growing, I found it's harder to be happy, because the satisfaction level is changing
Brian
The Davinator
Re: Here the samples ...
Brian
Yes,
Brian
True.  That said, people wanting to capture images to tell a story, or convey emotion, don't worry about per pixel sharpness, DxO rankings, FF vs APS-C, etc.  A lot of these differences never manifest themselves in print....only to measurebators staring at 100% screen views.
Brian
Not able to open above links that require login.
Yes,
Happy is relative and respective during specific time period. People happy on B&W TV during that time, people happy on color TV later, people happy on CRT TV then and happy on LED HD TV now. When 4K monitor get popular and cheap and eventually 8K monitor another 5-10 yrs later, you'd be happier with 36mp or more resolution.
BTW, I see your another thread. In thumb of rule, larger sensor better IQ, better sharpness and resolution. 50mp MF > 50mp FF > 50mp APS-C > 50mp mFT > 50mp 1" provided sensors have the same QE (quantum efficiency)
Why?  Simple because larger sensor, less enlargement in pixels when project to output at the same size, so-called crop factor or crop penalty.
Brian
I am sorry, Peter
I am sorry Peter, try this link :
https://www.dropbox.com/s/kppr1f7pnab4r5v/IMG_3423.JPG
It should work. If not, just consider I have low threshold on sharpness
You are right, that means now we are difficult (or can not) to be happy just CRT TV.
Honesty, I remember that I was happier when I got my first digital camera (Kodak 2 MP) rather than when I got my first FF (5DII). I don't know if I will happy at all if I got my first MF
Yes, I could understand that logic.
Assuming the lens is not outresolved by the sensor, do you think the smaller one still can keep up with the larger one (for the resolution or sharpness) ?
For example, imagine a lens is designed that could record 6000 dot in 35mm linear and both can be used on any sensor.
With 35 FF sensor area, it will record 6000 x 4000 dot (or 24 MP worth of data)
With mFT sensor area, the sensor will use 25% of the lens, so it will record 3000 x 2000 dot (or 6 MP worth of data)
WHAT IF ... both sensors (FF & mFT) have only 6 MP sensor ???
Both ended up with only 3000 x 2000 dot recorded, thus has the same resolution, no ?
Brian
Brian
Rick Knepper
OP Rick Knepper Forum Pro • Posts: 16,055
Re: Cross platform equivalency
stratobill wrote:
Rick Knepper wrote:
You know, this made me think of something I just read of Galen Rowell a couple days ago. I think it was advice in a magazine article given in a top ten list format. He said don't take record shots. Shoot every shot like its going into National Geographic. I'd probably want the best IQ for National Geographic. :)--
Rick Knepper, photographer, shooting for pleasure. It is better to have It and not need It than need It and not have It. Various RAW comparisons at Link below. Includes 5D3 vs D800E (new uploads), 5D3 vs. 6D, Zeiss lenses etc. https://app.box.com/s/71w40ita6hrcfghojaie
Maybe, but I went to a presentation by two guys from National Geographic who went into the jungle in New Guinea to shoot a very rare type of bird, videos and still. They brought all Canon 5D's, and the shots were pretty awesome!
Well that was a little bit of hyperbole on my part for the sake of emphasis.
The images I make that go into my personal galleries are vastly more important to me than any image taken by another person for any other purpose (unless someone gets a shot of God maybe) and it may have been a lapse in logic to use that comparison compositionally the way I did.
So, the 5D's survived the rainforests of New Guinea with little or no weather-sealing.
I owned a 5D from month one of its release and it was a wonderful introduction to FF, but the 5D2 produced better and more versatile images for PPing with more tools to help get the capture done for the type of photography I am into. The 5D3 maintained the IQ if not enhanced IQ a bit but it's various additional tools make capture exponentially easier for a much, much broader array of photography styles. The D800E produces better and more versatile images for PPing than the 5D3 but does not beat the 5D3 in the tools that help make capture easier. The 645Z has the potential to eclipse the D800E in raw IQ if not devolve a bit with handy tools.
Some of the answers to be determined concerning the 645Z: lenses (oem and adapted - AF vs MF, stabilized), bracketing, Live View implementation, high ISO performance, will Markins make a camera plate for it..
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW Pentax DA645 28-45mm F4.5 +8 more
Re: I am sorry, Peter
Nice photo! I said earlier studio portrait is not the best place to judge sharpness but landscape with lots of fine details.  I have many similar photos from 1" cameras and mFT.  You'd apply NR and smoothness anyway on portrait photos.  The difference will be oblivious in landscape photos.
You are happy at respective time and may happy less with higher diminishing return
No. 50mp FF and 50mp APS-C only the same on MP quantity before glass. Never the same after glass.
No. Let me use two old DXOmark's test that show MTF data not MPIX with 85/1.8 and 100L/2.8 macro between 12.8mp 5D and 18mp 7D.
On paper, 18mp 7D should have a higher resolution than 12.8mp 5D. Yes on sensor's MP but different story after glass where crop factor kicks in.
Please read these two articles that will help you to understand better.
http://www.normankoren.com/Tutorials/MTF.html
http://www.imatest.com/docs/sharpness/
You see 5D with either lens clearly has higher MTF 50 resolution that matters to human eyes most, even higher on MTF 20 resolution. What 7D higher is on MTF 15 and below resolution (that 7D's curve extends). However if you read above articles, you will know human eyes virtually cannot detect MTF 20 or below details that buried in low contrast noise/grain.
That's reason why DXO claims a 12mp FF could be sharper than a 18mp APS-C here
Otherwise if 18mp crop = 18mp FF, then those PJs should use 18mp 2.0x crop instead of 18mp 1DX with much smaller/lighter lenses, 12-35/2.8 and 35-100/2.8 zoom instead of bulky 24-70L/2.8 II and 70-200L/2.8 IS II, 300mm prime instead of big/heavy 600mm prime. The reality is that they never the same, not even close. They'd have to design and optimize 12-35/1.4 and 35-100/1.4 zoom, not only likely still inferior but much bigger/heavier and even impossible to design such zoom. Check old Olympus 35-100/2.0 zoom (without IS) for its FT DSLRs such as E-3 and E-5, that is even heavier/bigger than Canon 70-200L/2.8 IS II but only FF eq F4.0 zoom.  How many still use E-3/E-5 with that zoom at side of sport fields?
Otherwise Nokia 41mp should have higher resolution than 36mp D800 and A7R or 22mp 5D3. The reality is that it even never can generate sharp photos as from my old 12mp 5D (I have too many samples can show).
Great Bustard Forum Pro • Posts: 41,327
I am Spartacus!
Say, do you happen to have her email? There's a question I need to ask her...
The other extremely important variable that people rarely mention are:
  • Display Size
  • Viewing Distance
  • Visual Acuity
These three variables go a long way to answering the question, "How much resolution is enough?"
And also provided that the lenses for the smaller formats are not sharper by a factor of the equivalence ration and/or have less pixels.
For example, 24 MP mFT will resolve just as well as 24 MP FF if the lens is twice as sharp.
Yes, depending on the particular lenses being compared.
Actually, it doesn't work like that. Putting more pixels behind *any* lens increases resolution. How much more resolution depends, of course, on the sources of blur which include:
  • The sharpness of the lens
  • Motion
  • Shake
  • DOF
  • Diffraction
Let's say we had an infinitely sharp lens. Then it would resolve the same detail at the same DOF on any format that had the same number of pixels and AA filter.
However, if we are using lenses with the around the same sharpness on different formats, then the larger formats will almost invariably resolve more detail due to the enlargement factor, although, at times, the greater pixel count of a smaller sensor over the larger sensor (e.g. 24 MP APS-C over 12 MP FF) can narrow, or reverse, the gap.
By the way, these two places in the frame from DPR's comparison tool:
http://www.dpreview.com/reviews/image-comparison?attr18=daylight&attr13_0=canon_eos6d&attr13_1=canon_eos70d&attr13_2=oly_em1&attr13_3=nikon_df&attr15_0=raw&attr15_1=raw&attr15_2=raw&attr15_3=raw&attr16_0=100&attr16_1=100&attr16_2=100&attr16_3=100&normalization=full&widget=1&x=-0.10321931589537224&y=0.3274263187535198
http://www.dpreview.com/reviews/image-comparison?attr18=daylight&attr13_0=canon_eos6d&attr13_1=canon_eos70d&attr13_2=oly_em1&attr13_3=nikon_df&attr15_0=raw&attr15_1=raw&attr15_2=raw&attr15_3=raw&attr16_0=100&attr16_1=100&attr16_2=100&attr16_3=100&normalization=full&widget=1&x=0.3483651911468813&y=-0.07062136286840623
give, in my opinion, a good visual reference for the max differences in detail you may find as a function of format and pixel count.
The 6D and 70D have almost the same pixel count, so you can see the effect of the enlargement factor at work.  The Nikon Df has a lower pixel count on a larger format, so you can see how the enlargement factor and pixel count relate compared to a smaller format.
Also, if you switch one of the cameras between the D800 and D800E, you can see the resolution advantage of more pixels on a larger format, as well as the effect the AA filter can have.
Of course, the DPR studio scene shows the differences in resolution under idea conditions.  In peoples' everyday shooting, one might expect to see much smaller differences.
Re: I am Spartacus!
As always...
qianp2k wrote:
I'd say in real world environment, the difference is bigger than DPR well-lit lab environment especially in low light between FF and crop cameras. In true low light, FF shows more advantages than DPR simulated low light.
http://www.dpreview.com/reviews/image-comparison?attr18=daylight&attr13_0=canon_eos6d&attr13_1=canon_eos70d&attr13_2=oly_em1&attr13_3=nikon_df&attr15_0=raw&attr15_1=raw&attr15_2=raw&attr15_3=raw&attr16_0=100&attr16_1=100&attr16_2=100&attr16_3=100&normalization=full&widget=1&x=-1.0064605445316106&y=1.120078046677673
http://www.dpreview.com/reviews/image-comparison?attr18=daylight&attr13_0=canon_eos6d&attr13_1=canon_eos70d&attr13_2=oly_em1&attr13_3=nikon_df&attr15_0=raw&attr15_1=raw&attr15_2=raw&attr15_3=raw&attr16_0=12800&attr16_1=12800&attr16_2=12800&attr16_3=12800&normalization=full&widget=1&x=-1.0064605445316106&y=1.1207350769010633
...we have to weight the considerations of DOF and noise for low light photography for any given shutter speed.  If noise matters more than DOF, then, for sure, larger formats will hold the advantage.  However, at the same DOF and shutter speed, the noise will be the same for equally efficient sensors.
In my opinion, when it comes to noise and DOF, most opt for less noise over greater DOF, even given that greater DOF is more desirable than less DOF, which, of course, is why many prefer larger formats for lower light photography.
Re: As always...
It depends on subject and background. If subject and background relatively all far away, then DOF is largely not a factor even you take at large aperture on FF cameras.
That's my choice as well. Blur in out of focus plate is not the same as softness and many times make your subject more popup that is more attractive than all appear in focus but flat & dull look and nosier/grainer photo from smaller sensor. The reasons you use big aperture (low F number) are in low light where much darker edges that outside focus plate usually are not important or purposely in portrait where your subject is more popping up while the background nicely in blur rendering that something a smaller sensor is harder to achieve.
Thank you, Peter.
Thanks, you are correct. The NR on landscape photo will be less than portrait.
I like your landscape photos even when you were using your 60D (was it 60D ?).
I could imagine how better the result is when now you are using 5DIII (or other FF) and stitch. wow.
Larger format would make the stitch easier.
Brian
Re: I am Spartacus!
Of course, or the better ... her phone number
voice over text, that would like 10 fps vs 3 fps
  • Display Size
  • Viewing Distance
  • Visual Acuity
Yes, you are right.
I think we are just greedy
Seriously, I want my photo has 300 ppi, so I could watch it closer if I want to, about 25-30 cm viewing distance.
My 5DII could give me 45 x 30 cm, which is fine.
But often I print larger than that, and ... here we are ... searching new tool
I am afraid that was the case. The lenses about the same sharpness ...
Yes.
Thanks, Joe.
Brian
