The wonder of the A6000 . . .
Started Apr 23, 2014 | Discussions
jack scholl
jack scholl Veteran Member • Posts: 4,341
14
The following is a 9 shot burst (we had 12 but didn't want to violate the 10 shot rule) with the A6000/SEL18200.
The osprey is coming right at us and fast.
The first 9 shots are OOC with no PP other than crop.  The last is a simple standard LR preset of the last shot.  We have shot BIF with Canon, Nikon and now Sony . . . this is a very good AF system in our opinion.
Thanks for looking . . .
Jack
 jack scholl's gear list:jack scholl's gear list
Sony RX10 IV Sony a6400 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 10-18mm F4 OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS
Sony a6000
maxuci Contributing Member • Posts: 737
Re: The wonder of the A6000 . . .
Great this is what we want to see! Are these cropped? Did you change zoom during the burst?
Digital Nigel Forum Pro • Posts: 12,212
The OP mentioned that they were cropped OOC, and you can see that all are at 200mm.
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +18 more
miro3 Veteran Member • Posts: 3,048
Good stuff!
Thanks missed that comment. On my phone, can't see exif
abdoozy
abdoozy Regular Member • Posts: 261
Outstanding!
What was your AF setup?
yr. obt. svt.,
abdoozy
WSSA Member#160
 abdoozy's gear list:abdoozy's gear list
Sony a6000 Sony a7 II Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony Vario-Tessar T* E 16-70mm F4 ZA OSS +11 more
sergerez Regular Member • Posts: 241
Jack,
This is absolutely fantastic... can't find enough words. It's on par with Danny's magic manual setup and skills. So, hopefully, more people will be able to get closer to his and yours remarkable results.
Many thanks for posting them,
Serge
Jack
soupnazi81 Regular Member • Posts: 205
Great pix. Wondering what settings you used for  focus mode/focus area/lock on tracking?
Eg. AF-C, wide area, lock tracking enabled
 soupnazi81's gear list:soupnazi81's gear list
Fujifilm XF10 Sony Alpha NEX-3N NEX-5T Sony a6000 Fujifilm X-T100
captura Forum Pro • Posts: 27,478
Well done, Jack!
Steve
 captura's gear list:captura's gear list
Sony Alpha NEX-7 Canon EOS Rebel SL1 Sony a7 Olympus OM-D E-M10 Canon EF 85mm F1.8 USM +3 more
jack scholl
OP jack scholl Veteran Member • Posts: 4,341
miro3 wrote:
Good stuff!
miro3,
Thank you.
Jack
jack scholl
abdoozy wrote:
Outstanding!
abdoozy,
Thanks!
http://www.dpreview.com/forums/post/53531598
Jack
jack scholl
sergerez wrote:
Jack,
Serge
Serge,
Those are very kind words and really high praise.  Thank you very much.
Take care,
Jack
jack scholl
soupnazi81,
We just started using the A6000, but so far these seem to be doing OK.
Enjoy . . .
Jack
davect01
davect01 Veteran Member • Posts: 9,205
Well done, you nailed it.
Novice photobug. Former 3 and F3 owner. Current proud 6 owner.
http://davesnex-3photos.blogspot.com/
 davect01's gear list:davect01's gear list
Sony a6400 Sony E 50mm F1.8 OSS Sony E 20mm F2.8 Sony E 18-135mm F3.5-5.6 OSS
jack scholl
davect01,
Thanks . . . it is fun to use for sure.  Haven't tried any lens other than the SEL18200 as yet.  It sure performs well on the A6000.
Jack
jpr2 Forum Pro • Posts: 15,554
Jack: the Lock-on AF=On ?
Jack,
what exactly is the functionality of this setting (S's naming conventions seem to be truly confusing sometimes)??
These ospreys are to be fully appreciated only at full res. (or at least seeing them "Large"), the reduced size even on a good monitor doesn't do them any justice .
And while we know that the diffs. between 200mm and the next possible one, the 300mm aren't all that crucial in terms of reach - have you tried your 70-300 yet?
best, Quercy
ryan92084
ryan92084 Contributing Member • Posts: 521
Re: Jack: the Lock-on AF=On ?
Jack,
best, Quercy
Lock on AF let's you press a button (or half shutter) to put a box around the object you are trying to track. The box will move and adjust size/shape as the object does and tries to keep it in focus. It gives a more positive indication of what is being tracked then the dancing squares. It also works for focus recompose pretty well.
 ryan92084's gear list:ryan92084's gear list
Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS +3 more
jack scholl
jpr2 wrote:
Jack,
Haven't had time to test with/without . . . can't help.
These are close to 100% crops . . .
Haven't had time to do that either.  I have been surprise how well the 200mm actually worked for the shooting we did . . . the 24MP sensor is very forgiving.
Jack
zackiedawg
zackiedawg Forum Pro • Posts: 32,983
It overrides proximity focus...
In my experience with lock-on AF with my RX10, compared to normal continuous focus, the lock-on AF function allows you to set via button press or half-shutter, then while focusing and firing, the camera attempts to maintain focus only on the subject that was originall locked, based on shape/contrast/etc.  This way it tends to hold with the subject even as it passes behind something that might pass through the frame - the standard PDAF focus system will attempt to prioritize the most contrasty/obvious subject closest to the frame, so if a bird passes behind a tree, the tree will often temporarily 'steal' the focus away, then the camera has to hunt back for the bird.  Lock-on AF should help it stay with the bird, ignore the tree, and also ignore busy backgrounds as the subject flies across them...as long as it can still recognize the shape/color/contrast of that original locked subject, it will stay with it, or if it loses it, will reacquire it again for as long as the lock-on AF stays engaged.
I played with this feature on the RX10, which of course is contrast detect only, but it definitely worked in keeping a flying cormorant under the focus square even as it passed by trees and fence posts.  You know it has acquired and locked because of the square that stays lit and 'morphs' with the subject's shape and size...interesting to watch when it's a bird in flight, because the focus 'square' will stretch to a long rectangle when wings are outstretched, and compact to the torso when wings are in...it follows the morphing shape of the subject.
I expect the A6000's version will work even better than the RX10's version, given the faster PDAF focusing.
Justin
galleries: www.pbase.com/zackiedawg
 zackiedawg's gear list:zackiedawg's gear list
Sony a6300 Sony a6600 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony DT 18-250mm F3.5-6.3 +24 more
EinsteinsGhost
Re: It overrides proximity focus...
That sounds great!
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
