Cactus RF60 HSS
Started Apr 23, 2014 | Discussions
Brian Hursey Junior Member • Posts: 27
Re: Cactus v6 review out
Perfect companion to the Rf60 the V6 review is out and they were released today also. http://brianhurseyphotography.com/blog/?p=586
OP ktownbill Senior Member • Posts: 2,191
Looks like a very well thought out flash system.  New and better flash systems are coming out in droves!  Makes selecting one over the other difficult. Looks like Cactus has the edge for HSS with respect to economics though.
Thank you for the update Brian. I look forward to more videos from you.
Bill
I did some hss testing per your idea of delay and multiple flashes http://brianhurseyphotography.com/blog/?p=700
adfhg Regular Member • Posts: 144
I am selling 3 of that i bought and could not get to work with my yn-565ex here
http://www.ebay.com/itm/251556782617?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
vic.
Stop bombarding me with your facts and sciences!
You try the yn568ex profile?
Also did you email cactus the may be able to add it via fw update..... I would not sell them tell you ask. YN uses digital protocols so the learning program wont work.
ranalli
ranalli Senior Member • Posts: 1,020
Your write-up has some excellent analysis and examples....thank you for sharing.
It more or less confirms what I was reading on FlashHavoc about V6 system with regards to HSS.  It can do HSS over radio but it must have some mechanism to fire off the pre-flash signals.  Now whether that is an actual TTL based flash work on pass-thru SB-700/SB-910(for Nikon folks) or one of those $50 YN-622 TTL triggers on top of it that doesn't seem to matter.  They're calling this "HSS Sympathy Mode" apparently since the V6 system can do it...but it relies on something else to do so in a way.
I would probably spend the extra $50 and go with the later option as you have shown because I really don't want any extra weight on my camera not to mention a "wasted" flash just for triggering others.
 ranalli's gear list:ranalli's gear list
Nikon D800 Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR
ranalli
They don't work with the YNs??  Strange..thought they were brand agnostic.
