Calling owners of the Canon FD 85mm 1.2L on Speedboosters
Started Apr 22, 2014 | Discussions
wilkes888
wilkes888 Forum Member • Posts: 77
Owners of the Canon FD 85mm 1.2L on a Speedbooster, any comments?
Just been performing some camera math on the Canon FD 85mm f/1.2L as I hear this lens it very sharp wide open. Is this true?
If so, mounting this on a Speedbooster should create a 60mm lens which in theory translates into a lens with a 'full frame equivalent' of a 120mm f/2.4 but with light gathering ability of an f/0.85! (Maths below)
Given the maths, the price of this lens secondhand seems be reasonable compared to the Voigtlander f/0.95 series.
PHOTOGRAPHY MATHS :
(Tell me if I've made any errors!)
Camera Math Sources: Tony Northrup / Petapixel and Metabones Speedbooster White Paper
  1. ORIGINAL LENS
    Focal Length: 85mm (Field of view 85mm)
    F-Stop: f/1.2 (Light gathering ability f/1.2)
  2. LENS MOUNTED ON SPEEDBOOSTER
    Multiply focal length and FoV by factor of x 0.71, reduce light gathering ability by 1-stop
    Focal Length: 60mm (Field of view 60mm)
    F-Stop: f/1.2 (Light gathering ability f/0.85)
  3. LENS MOUNTED ON SPEEDBOOSTER ON AN MFT SENSOR
    Multiple field of view AND f-stop by crop factor of x 2
    Focal Length: 60mm (Field of view 120mm)
    F-Stop: f/2.4 (Light gathering ability f/0.85)
Wilkes
London based Food & Drink-o-phile - Living every day as if it's his last…
(Currently focusing on new restaurants, bars and the streetfood scene)
Ww: http://wilkes888.wordpress.com
Twitter: @wilkes888
Instagram: http://instagram.com/wilkes888
Pinterest: http://www.pinterest.com/wilkes888/food/
Foursquare Lists: https://foursquare.com/wilkes888/lists/created
 wilkes888's gear list:wilkes888's gear list
Sony RX100 Olympus E-M1 Voigtlander Nokton 25mm F0.95 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus M.Zuiko Digital 17mm 1:1.8 +5 more
Anders W Forum Pro • Posts: 21,468
Re: Calling owners of the Canon FD 85mm 1.2L on Speedboosters
PHOTOGRAPHY MATHS : (Tell me if I've made any errors!)
  1. ORIGINAL LENS
Provided that the speedbooster works as it should with this ultrafast lens (which I don't know), the combo will be f/0.85 (1.2 x 0.71) with regard to exposure. With regard to light gathering ability, DoF, and diffraction, however, it will be equivalent to f/1.7 (2 x 0.85) on FF. As you have correctly calculated, the FL will be 60 mm, equivalent to 120 mm on FF.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
wilkes888
OP wilkes888 Forum Member • Posts: 77
I'm now confused... the Metabones FAQ page states the following...
Source: Metabones FAQ
What have I misunderstood? Between the white paper and the FAQ I interpreted the depth of field (and therefore the f-number) to actually remain unchanged so I multiplied the f/1.4 by 2.
Admittedly the FAQ continues with the following which clouds the issue... but seems to conclude the same.
Wilkes
Twitter: @wilkes888
MAubrey
MAubrey Senior Member • Posts: 1,600
Unfortunately, I converted my FDn 85mm f/1.2L to EF with an EdMika kit. It's reversable, but extremely difficult, complex and not worth my time, so I'm stuck waiting with my 85mm f/1.2 for the promised EF-MFT speedbooster...
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha a7 Voigtlander 35mm F1.2 Nokton Olympus M.Zuiko Digital ED 75mm F1.8 +2 more
Elemental Photography Contributing Member • Posts: 941
The field of view is approximately the same when used on a larger APS-C sensor, not on the smaller m4/3 sensor.
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic GH5 +9 more
What they forgot to mention in the FAQ is that they are talking about what happens when you put an FF lens with the Speed Booster on an APS-C camera. You want to put it on an MFT camera. In that case, the statement of mine that you quoted above applies.
brian Senior Member • Posts: 1,190
  1. ORIGINAL LENS
Wilkes
Twitter: @wilkes888
First of all, AFAIK, all photographic lenses marked as "f/1.2" are actually 1/3 stop faster than f/1.4, meaning that they are really f/(2^(1/3)) = f/1.2599.
When you attach the 0.71x Speed Booster to an 85mm f/1.2599 lens  you create a 60.4mm f/0.9 lens.  Forget all the crop factor and light gathering ability stuff.  Consider this:  if Panasonic or Olympus developed a 60.4mm f/0.9 lens for micro four thirds, do you really think they would market it as a 120mm f/1.8?
Brian Caldwell
(unknown member) Veteran Member • Posts: 9,509
  1. ORIGINAL LENS
Wilkes
Twitter: @wilkes888
Brian Caldwell
I doubt that all 1.2 lenses ARE 1.2......just as with lots of lenses (most probably) they are not exact and are often rounded up/down.
I can live with them being 1.2
Must get a speedbooster/focal reducer for my three 1.2 lenses some time.
wilkes888
Well, mathematically, if a lens was designed to be 1/2 of a stop faster than a f/1.4 it will be a f/1.1892 (i.e. 1/SQRT(0.5)^0.5). So yes it is rounded up. But I don't know if the lens designers worked to that spec.
I have a cheap focal reducer which gives a nice angle of view for my FD 50mm f/1.4 on a MFT but it seems to have degraded the quality compared to the plain adaptor with no optics. I didn't notice it at first as it's not immediately obvious so it's not terrible.
Wilkes
Twitter: @wilkes888
wilkes888
Good point... but wouldn't it would make more sense if the f/1.2 was actually 1/2 of a stop faster than a f/1.4? That would make it an f/1.1892 (i.e. 1/SQRT(0.5)^0.5). If what you say is correct that would be very misleading from Canon.
... if Panasonic or Olympus developed a 60.4mm f/0.9 lens for micro four thirds, do you really think they would market it as a 120mm f/1.8?
I agree, as Tony Northrup says in his video (at the end) the manufacturers don't market a MFT f/0.9 lens as a f/1.8 because it doesn't sound as good.
Wilkes
Twitter: @wilkes888
wilkes888
That makes a lot more sense... thanks for that... I thought something wasn't quite right!
Wilkes
Twitter: @wilkes888
wilkes888
Thanks for enlightening me... that makes a lot more sense!
Wilkes
Twitter: @wilkes888
wilkes888
Damn, not good
Do you have any shots I could look at taken with your FD 85mm f/1.2? Curious to see what the 'un-Speedboost-ed' images are like...
Wilkes
Twitter: @wilkes888
pannumon Senior Member • Posts: 1,559
A µ4/3 f/0.9 lens is not called f/1.8 because doing so would be lying. Also note that full frame lens manufacturers do not call a f/2.0 lens a f/1.0 lens, because it would be lying, too.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +13 more
wilkes888
I don't disagree, but watch the last section of the video where Tony asks manufacturers to make things clearer on lens specifications.
Wilkes
Twitter: @wilkes888
Wilkes
Twitter: @wilkes888
Focal length and f/# have clear and unambiguous meanings that have nothing to do with format size.  An f/0.9 lens should never be marketed as an f/1.8 lens because its f/0.9, not f/1.8.  The marginal ray angles are completely different, as can easily be verified on an optical bench.
Brian Caldwell
It might seemingly make more sense, but its not ever done in the industry AFAIK.
Will have to check out this video later, but to be honest it sounds like Tony is way off base here.
Wilkes
Twitter: @wilkes888
Brian Caldwell
MAubrey
Here are a few...nothing formal though.
--Mike
MOD Tom Caldwell Forum Pro • Posts: 32,741
  1. ORIGINAL LENS
I am reasonably sure that all focal reducers are limited to a maximum light gathering ability of f/0.90 no matter what lens is fitted.  No small thing nevertheless.
Tom Caldwell
Wilkes
Twitter: @wilkes888
I suggest that you stop working yourself into a lather - buy the durn thing, you will be pleased and with the FD 85/1.2 you will get cheap gym fees - it is a big lens
Oh - and remember focus peaking is your friend.
Tom Caldwell
