Best front element cleaning techniques?
Started Apr 21, 2014 | Questions
Touchstone Steve New Member • Posts: 4
I have a 24-70L that I got a few specks of salt water spray on it. Not so bad it will affect images so much but never the less if there is a good way of cleaning the lens with out damaging the coating this would be a big plus.
PLEASE, this is not a filter conversation. There are thousands of filter conversations and they don't help those trying to understand the +/- issues and challenges in cleaning front or back elements.
What is the best technique for cleaning a front element?
 Touchstone Steve's gear list:Touchstone Steve's gear list
Fujifilm X-E2 Fujifilm XF 60mm F2.4 R Macro +2 more
OP Touchstone Steve New Member • Posts: 4
Re: Best front element cleaning techniques?
I guess I should of asked about filters.... Or look I mounted a fossil to my Canon and now I can shoot dinosaurs.
Sports Shooter
Sports Shooter Senior Member • Posts: 1,648
Here you are:
http://cpn.canon-europe.com/content/education/masterclass/lens_cleaning.do
 Sports Shooter's gear list:Sports Shooter's gear list
Canon EOS-1D Mark IV Canon EOS-1D X Mark II Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF 70-200mm F2.8L IS II USM +14 more
crashpc Veteran Member • Posts: 7,237
I clean all my lenses this way:
1) blow some compressed air to it, but not very close. Just to blow the easiest mess off.
2) very gently use ear cleaning sticks with cotton on sides, wetted with IzopropylAlcohol. It must not wet the glass totally. Just the sticker must be wet a bit. And I gently clean and clean (I usually use up to 30 sticks) until it´s clean. Never damaged anything, the lens is superclean. Did it on small to medium front lens elements. It would be torture to do on 400 f/2.8.
Why does he do it?
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
tonyjr
tonyjr Veteran Member • Posts: 5,295
I use a copper hill cleaning kit .
I don't breeth on lens [ who knows what is on your breath ] I don't use alcohol
[ can leave streaks ] Q-tips  , tee shirts , canned air [ it CAN blow stuff into lens and / or blow something across lens to scratch it  . Just micro cloths and lens cleaning paper .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
brightcolours Forum Pro • Posts: 15,885
Nothing complex about cleaning lens elements
Take a soft lens brush and brush dust/whatever else gently off.
Then take a microfiber lens cleaning cloth and spray a little bit of lens cleaning fluid on it. Gently clean the lens in  rotating motion. If you like, you can wipe the lens after that with a dry part of the lens cleaning cloth. Done.
You have to really try hard to damage lens coatings, they are metals vaporized onto the glass under high temperatures, and they are pretty tough.
Thanks! I looked on the Canon site but the US one :P. I used blower for dust, a microfiber cloth for the stuff that does not blow off but stayed way from liquid cleaners. I see from the Canon video a cleaner recommendation I can use.
R2D2 Forum Pro • Posts: 26,550
This works perfectly...
http://www.dpreview.com/forums/post/38622172
R2
Sports Shooter
If you have salt deposits on the lens I wouldn't use a cloth in case that the blower did not blow them off completely. Salt usualy sticks. Imagine that a small tiny granule is still there and while you are moving the microfiber cloth around the glass the granule gently scratches the sufrace!!
I would use a liquid cleaner with a lint free wipe like a peckcap and very gently wipe of the surface. This should remove any small granules of salt remaining on the lens optic.
Great Bustard Forum Pro • Posts: 45,641
Blower, brush, lenspen, brush, blow.
Blow off the front element, brush the lens with the brush end of a lenspen, polish with the polish end of a lenspen, brush, and blow.
You cant scratch the lens with salt.
richro Regular Member • Posts: 244
 richro's gear list:richro's gear list
Canon EOS 6D Canon EOS M5 Tamron SP 24-70mm F2.8 Di VC USD Canon EOS M Canon EF 85mm F1.8 USM +11 more
Bert_vargas
Bert_vargas Senior Member • Posts: 1,577
120grit sand paper and a bit of emery cloth.
and if that doesn't clean it, then i grab some steel wool.
Beauty is in the eye of the photographer
 Bert_vargas's gear list:Bert_vargas's gear list
Canon EOS 40D Canon EOS 5D Mark III Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +5 more
tonyjr
Forgot to say and no one else has -
Don't reuse micro cloth - I cut in to 2 X 3 inch squares .
I also use lens pen - but the felt thing on end - I don't - and the brush part ,
I cut off about 1/8 inch each time I use .
I also use the brush on lens and camera body - especially in high pollen areas .
Works great for sensors, too! (nt)
Bert_vargas wrote:
120 grit sand paper and a bit of emery cloth. and if that doesn't clean it, then i grab some steel wool.
bronxbombers4 Veteran Member • Posts: 3,387
squeeze blower then formulamc (or such) and chamois or micro fiber cloth
first hold the lens facing down and use a squeeze blower on it to try to get rid of any potential sand grains, then possibly a fine soft brush and some more blowing
then use some FormulaMC or such on a chamois or micro fiber cloth
Re: 120grit sand paper and a bit of emery cloth.
Clearly this would be going for that art effect.
There is NO problem in reusing microfiber lens cloths. There is also no problem in washing it after prolonged se and continue using it.
Sports Shooter
Why don't you try it on your lens and let us know the result?
I already have used my camera with sea spray. And yes, no "protective filter". And yes, just clean my lenses as always: brush, then a bit of lens cleaning fluid on a lens cleaning cloth. No scratches on any of my lenses. People seem to think lens elements are made of putty.
