Watermill - portrait - E-M5 + 75mm
Started Apr 21, 2014 | Photos
dustpuppy Regular Member • Posts: 172
Comment & critique:
Jim Salvas
Jim Salvas Veteran Member • Posts: 5,671
Re: Watermill - portrait - E-M5 + 75mm
The 75 is w great lens for portraits and viewing this at 100% shows how sharp it can be. However, there are just too many things wrong to make this a good portrait.
First, the watermill, which occupies about 75% of the frame, is out of focus. If it's important enough to be such a major feature, it should be in focus. Truth is, the actual subject is the man, but is relegated to the corner and his face, which is the most important area, is tiny in comparison to the whole.
Second, he is looking away from both the watermill and the viewer. It is difficult to shoot a good portrait of someone not looking at the camera, because it can look so staged. This just looks stiff, when such an angle should look candid and casual. To top it off, he seems to be uncomfortably squinting in the  harsh light.
A much tighter shot, with the subject directly engaging the viewer would be much better. Think of the eyes first, because  that's what people will see first.
I hope this helps a little.
Jim Salvas
 Jim Salvas's gear list:Jim Salvas's gear list
Olympus PEN E-PM2 Olympus E-M1 Olympus PEN-F Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +11 more
Verbatimium Forum Member • Posts: 60
Honestly, take advice from someone who tells you "there are just too many things wrong to make this a good portrait" with a grain of salt.
If everyone thought like him, photos in this world would be very boring to look at. Photography is an art and if you are happy with your end result, that is all the matters (unless you are professionally doing a shoot). I personally like the photo and I don't see anything "wrong" with it.
That being said, there are lots of things you could have done to make the portrait look different and interesting in other ways. Just realize that that each person has their own preferences.
lambert4
lambert4 Senior Member • Posts: 2,335
Was this a staged portrait or a casual catch?  I like it as a casual shot with nice composition and interesting background.  As a portrait though the mill is overwhelming to the gentleman, and the two balance too much.  I love the idea and it is one worth revisiting maybe have the subject occupy more frame and look into the camera?
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Nikon D500 Sigma 10-20mm F3.5 EX DC HSM Nikon AF-S Nikkor 70-200mm F4G ED VR Tamron SP 150-600mm F5-6.3 Di VC USD Nikon 35mm F1.8G ED +3 more
Abrak Veteran Member • Posts: 4,211
Well I am not wild about this shot. My question would be why did you take it? What is the relationship between the guy and the water wheel?
Assuming there is none you are sort of left with a photo of two competing objects or essentially you have a bad portrait of a guy (I mean one arm is missing) and a bad picture of a water wheel (well it aint even in focus).
Of course if you like it that is all that really matters. And it is quite possible that I am missing a link between the circularity of the water wheel and the dismembered portrait.
daddyo Forum Pro • Posts: 12,670
Every art discipline has established guidelines...
Clearly, art is a subjective thing -- but there are conventional guidelines and principles that, in general, distinguish 'good' art from 'bad' art. That is exactly why people spend four years in college to obtain art degrees -- if it weren't so, no one would waste the time or money.
Jim's comments are on target, and clearly sincere -- he did not seem to be demeaning to the OP, but was suggesting legitimate improvements. Having entered and judged portrait print competitions many times in my career, I can assure you that Jim's comments are retrained.
The OP did ask for any critical comments, and hopefully he will objectively weigh those comments -- that is one of the best ways to improve as a photographer.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
Skeeterbytes Forum Pro • Posts: 23,186
dustpuppy wrote:
Like the overall concept and would modify a few elements to suit my eye (YMMV).
His face is exposed a bit hot and he seems to be squinting, perhaps looking at a brightly lit area. If that was the case, I'd have had him look in another direction or keep his eyes closed unitl the shot.
I'd open the lens to blur the waterwheel more. He'd pop more against a pretty busy background while I suspect it would still be identifiable. This is, of course, a 75 strong suit.
Would change his shirt color so something not earth-tonish, maybe a soft blue or green.
Would have him move to his right to not chop off his arm at the shoulder. better to not do this at a joint.
In sum, as a vacation snapshot it's just fine but as a formal portrait or fashion shot, it calls out for more control of several elements.
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
Ulfric M Douglas Veteran Member • Posts: 4,828
dustpuppy wrote:
I would go back and do that again,
To my eyes
neither the waterwheel or the portrait are sufficiently good.
He looks like a guy who needs a burst of frames to pick one with a better expression, and the exposure on his skin is too bright and vague.
His right arm is in an awkward position, did you crop? Is he holding something?
Cheksa wrote:
You're evil Ulfric.
pdelux Senior Member • Posts: 1,113
There is probably too much "compression" going on here with a busy background. It makes the Mill overbearing in this photo. My suggestion is to use a wider focal lenght, even if you lose some BG blur. A 25mm or 17mm would have been better, just my opinion.
 pdelux's gear list:pdelux's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +6 more
