Fast short Tele on NX - Adapted 100mm f/2.5
Started Apr 19, 2014 | Discussions
sixfootzero
sixfootzero Contributing Member • Posts: 674
I've been using Minolta MC/MD manual focus lenses on my NX (And on my Minolta too, of course) for a while now, but my lineup had a broad gap in focal lengths between 58mm and 135mm. While an 85mm would be nice, they run several hundred dollars depending on the model. Then I stumbled on the Minolta MD 100mm f/2.5. They show up on ebay for around $100, and after a few missed auctions I won one for $75. It's in perfect condition, and included the box!
My first Minolta lens was a large/heavy 58mm f/1.4. It helps me make some beautiful images, but has lots of old lens character. As I added to my Minolta collection, I started getting a few MD lenses. Minolta went to great lengths to reduce the size/weight of these lenses. (The standard filter size, for example, went from 55 to 49mm. Everything was scaled down...) Their optical performance is great too! The 58mm, for example, has strong spherical aberration wide open, with an accompanying loss of contrast. It's also prone to flare. By contrast, all of my MD lenses are sharp from wide open, and behave much more like modern glass.
So I open the box and am amazed at how compact/light the 100mm is. It's no larger than the NX 20-50mm kit lens and includes a brilliant two-stage retracting lens hood. The build quality is nice, and focus/aperture adjustments are nice and smooth.
It's nice and sharp wide open and is really crisp stopped down to f/4. It can show purple fringe around really brilliant highlights, but this too is totally absent at f/4. It shoots like a 150mm on the NX, which is an interesting focal length. You need a little distance from other people to get a good shot, which helps you capture folks in a relaxed I'm-not-posing-for-a-picture state. I just got back from the zoo, and while you won't be counting nose hairs on the giraffe, it's really nice when you want to include some surroundings in the frame.
Here are some shots of the lens, including some alongside familiar NX zoom lenses, and some examples. On the NX100, it makes for a nice compact little little package with some reach. DoF is narrow enough that it would be easier to use on something with a viewfinder, like the NX10/20/30... Think about this one if you're longing for a cheap, fast short tele lens.
You can see that, without the adapter, it's about the same length at the 20-50 kit lens.
And that it's way more compact, no surprise, than the 50-200mm.
While it won't bokeh-obliterate your backgrounds, it can strongly isolate your subject.
Check out my reflection in his glasses...
 sixfootzero's gear list:sixfootzero's gear list
Samsung NX100 Fujifilm X-E1 Fujifilm X-H1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED +4 more
Samsung NX100
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
Re: Fast short Tele on NX - Adapted 100mm f/2.5
Very nice shots; you've used very expertly. And thanks for the info.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
mathOS Regular Member • Posts: 232
Another nice Rokkor in very good hands !
 mathOS's gear list:mathOS's gear list
Samsung NX30 Samsung NX 85mm F1.4 ED SSA Samyang 12mm F2.0 NCS CS +5 more
sixfootzero
OP sixfootzero Contributing Member • Posts: 674
Thanks guys!
simontramper
simontramper Senior Member • Posts: 2,405
Superb images great work .
http://www.flickr.com/photos/simon-nx/
Trying to capture the images i see around me.
 simontramper's gear list:simontramper's gear list
Samsung NX200 Samsung Galaxy NX Samsung NX1 Samsung NX 20-50mm F3.5-5.6 ED Samyang 8mm F3.5 Aspherical IF MC Fisheye +10 more
Leon Obers Senior Member • Posts: 2,788
Nice to see these images in combination with older nanuel lenses.
I just ordered an NX30, specially also for using in combination with manual lenses that I have already for years, in my case with a Nikon mount.
Leon
sixfootzero
Very kind of you to say, Simon.
sixfootzero
Leon,
I think you will be pleased with your choice, I played with one recently and it's a nice camera. The EVF and focus peaking should be helpful if you have many fast/long lenses. Your biggest adjustment will be with the crop sensor, all your lenses will be 50% longer... Have fun!
Thank you for your nice words and interest.
I am familiar too with APS-C crop sensor on a Nikon (I have both full frame as well crop sensor). But as I want to do more video, my choice is to the Samsung, as Nikon doesn't offer a good mirror-less option. The way Nikon implement video in their DSLR is "clumsy" in comparison to most other vendors.
After some first experience when the NX30 shall arrive, I think I will order a 20mm and 30mm Samsung lens as for easy "street-live" imaging using AF. But when getting a Nikon/NX mount adapter after, I think I have nice options to combine my existing list of lenses to use on the NX30.
Small and light manual Cosina / Voigtländer SL (II) lenses:
- 40mm/2.0 Ultron (Pancake)
- 58mm/1.4 Nokton (shall be a nice "85mm" full frame comparable angle of view)
- 90mm/3.5 APO Lanthar
- 180mm/4.0 APO Lanthar
The nice things to these lenses is that they have a long throw turning to the manual focus ring. (Specially the 90 + 180mm). For movie I want to put a "handle" on it < like this > or < this > and using the focus peaking on screen for focus reference.
Also small and light.
- Nikkor AIS 24mm/2.8
- Nikkor AIS 85mm/2.0 (although not that sharp used wide open)
- Nikkor AIS 105mm/2.5
And I have to figure out if using the Nikon/NX adapter with a special ring to set aperture for "G"-lenses, I can still make use of my Sigma 10-20mm/4-5.6 (using manual focus mode).
I have some zoomlenses too, but  most I think are not that nice in using them. (Maybe a relative small Nikkor E 75-150/3.5 as an exception).
Leon
sixfootzero
That's quite a selection of lenses, and you have ambitious plans! Good luck!
