XF 14mm vs XF 10-24 Infrared Samples
Started Apr 17, 2014 | Discussions
gidferrer
gidferrer Regular Member • Posts: 194
Hi All,
I have seen a lot of people asking about the hotspot of the 10-24, fortunately I have the 10-24 and had the 14mm but im definitely getting the 14mm again for my IR work. The hotspot of the 10-24 is very bad and un workable. Here they are. Hope this is of help to others out there.
XF 14mm
XF 10-24
Editing: Raw ACR- WB Correct and exposure / PS- Color Channel invert then saturated to about 50 to get the colors.
Best Regards,
Gid
Ollie 2 Senior Member • Posts: 1,568
Re: XF 14mm vs XF 10-24 Infrared Samples
Yikes.
That’s even worse than the 18-55mm.
Fuggedaboudit.
Thanks for sharing.
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 +20 more
Alex Guzun New Member • Posts: 8
What filter did you use?
 Alex Guzun's gear list:Alex Guzun's gear list
Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Phase One Capture One Express 7 Apple iPhone 5 +4 more
gidferrer
OP gidferrer Regular Member • Posts: 194
Hoya R72
Albert Valentino Veteran Member • Posts: 9,762
a picture is worth a thousand words. So these end any controversy including the reference to Tony Sweet who may have fixed results in post - which can be impossible to do if it occurs in the bad spot. I know, i tried to make the 18-55 work but not worth the effort.
Yet another reason for my to be happy with the Fuji 14mm!
Fuji Silver XE1 w/14, 35, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
94
94 Senior Member • Posts: 1,074
Wow, I'd heard about it but this proves it. That's unusable.
Is this sort of thing endemic with zooms, or in other words are there zoom lenses without hotspots?
 94's gear list:94's gear list
Fujifilm X100T Canon EOS-1D Mark II N Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm XF 35mm F1.4 R +14 more
The fuji 55-200 is great, i personally tested it, as is the 16-50.
TORN Senior Member • Posts: 1,607
Using a smaller, much more affordable filter system like Hitech 67mm would be another one as would be size and robustness and manual handling.
 TORN's gear list:TORN's gear list
Canon EOS 5D Fujifilm X-E1 Fujifilm X-T1
gidferrer
Im planning to get a lens for IR, so the 16-50 doesnt have any hotspot? Planning to buy the 14mm but if the 16-50 doesnt have any hotspot then i would consider it.
dark13star
dark13star Senior Member • Posts: 2,045
Good to know. I am just sending my XE1 out for an infrared conversion. I have the 14mm and am leaning against buying the 10-24 anyway. I think I'll wait for the fast wide prime to add. 14mm is wide enough for me on the wide end.
Rich
"I would be an historian as Herodotus was." -Charles Olson
http://herodot.us
 dark13star's gear list:dark13star's gear list
Fujifilm X100S Olympus Tough TG-4 Olympus TG-5 Fujifilm X-E1 Fujifilm X-T3 +14 more
Member stillman3 purchased it to use for IR. It is just about the perfect for both the range, and OIS if you have to handhold with a filter, not a problem with a converted body.
16mm Is wide enough not to purchase the 14mm just for IR
jrk
jrk Veteran Member • Posts: 3,401
Wow.  I had originally pre-ordered the 10-24, then Fuji had the great lens sale.  After reading more and more about how so many folks were thrilled with their 14, I canceled the order for the 10-24 and bought the 14 on sale.  Really glad I did!
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X100F Fujifilm X-T3 Voigtlander 35mm F1.4 Nokton Fujifilm XF 60mm F2.4 R Macro +14 more
afragisk Senior Member • Posts: 1,605
I did and feel exactly the same thing. I had also cancelled the 56, or at least I thought I did but one day it arrived at my door and hasn't left my camera bag ever since - bit off topic, I know..
http://www.flickr.com/photos/apollonas/
Fuji XE-2, Canon FD 300 4L, Fuji 55-200, Fuji 56 1.2, Fuji 27 2.8, Fuji 23 1.4, Fuji 14 2.8, Bower 8 2.8
jrk
Great minds think alike!  I also ordered the 56 and have really been enjoying it.  It has opened up a new avenue for me, I hadn't been really into portraits, etc. but am really starting to get into it the more I learn.
14mm IR sample
Here is a sample of the 14mm. Captured with a Hoya 72R filter handheld at ISO 3200. This is lower manhattan, New York City's showing the World Trade Center complex with the new skyline.
First is Faux color IR from channel swapping plus some touch up... The second is a BW version of the first.
14mm Faux Color IR
14mm same as above but used Nik Silver Efex plugin for BW version
stillman3 Contributing Member • Posts: 621
As Albert mentioned, the 16-50 works quite well for IR work. This image is handheld 1/11sec, ISO 3200, f6.5. Sorry, I don't have any landscape images at 16mm.
Cheers Eric
gidferrer
For most of my work, the 10-24 is the best UWA in this system. The way it emphasizes the FG is absolutely wonderful. The 14mm cant do that. I feel its too cramped up. Too narrow. The 14mm is excellent, and im getting one again mainly for IR and cityscape photography.
Try out the 10-24.
petrenko
petrenko New Member • Posts: 5
Sorry for upping old thread but why not create some layer mask to compensate for the hotspot?
One I attach is a bit draft and is from Lightroom.
 petrenko's gear list:petrenko's gear list
Fujifilm X-T1 Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-120mm F4G ED VR Sigma 105mm F2.8 EX DG Macro +5 more
