Panasonic GM1 - A Sweet Kit! Pics and Size Comparisons
Started Apr 15, 2014 | Discussions
MOD Tom Caldwell Forum Pro • Posts: 46,360
Re: GM1 v RX100, 12-32 v 14-42EZ
Le Frog wrote:
That was quick! Thanks (and pity that we will still have to wait for some informed opinion on the relative strengths and weaknesses of the two pancakes). Did you find that the low speed flash sync was too much of a limitation for low light/indoors or fill in flash/portait photography? Did you miss the longer reach of the RX100 zoom, or were you happy to carry the 45 with you and switch lenses?
(I have almost decided to get a GM1 myself, as a carry-everywhere camera, but I just found an excellent deal on an RX100II. And I am still debating with myself on the 9-18 and the Panasonic 14-140 II; I have never tried ultra-wides and I am still unsure about their usefulness/versatility and the 14-140 seems to negate the advantages of the GM1 diminutive dimensions).
Think of it as a small format camera and not as a pocketable one and you have your head thinking correctly. Too much emphasis on trying to formulate it into a compact camera replacement and you have put yourself into a self imposed camera use straitjacket. This is a proper very versatile camera that can be used in full function with the usual variety of lenses that just happens to be very small. Smaller than the RX100 until you fit a lens on to it.
Tom Caldwell
LH Regular Member • Posts: 315
Re: Panasonic GM1 - A Sweet Kit! Pics and Size Comparisons
Ben O Connor wrote:
apart from jokes, seriously nice set of gears. Its sad to that no IS on GM1, but as sad there is no possibility mounting it on a tripod while the grip is attached. That would be a benefit, truly.
Lack of tripod mounting while grip is attached is just a Panasonic grip limitation. Some of the 3rd party grips give you a tripod socket on the grip.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Re: Panasonic GM1 - good fun, burny, but…
…even with the excellent LCD, I am often defeated for composition. I just cannot see the LCD well enough what with my glasses, the generally bright light around here, and whatnot.
Also, I find the Panny 45-150 (slightly smaller than the excellent Oly 40-150) a bit unhandy on the GM1, just a bit too big.
Great little handful with the 12-32, of course.
Cheers, geoff
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://pngtimetraveller.blogspot.com/2011/10/return-to-karai-komana_31.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
SUBY Senior Member • Posts: 1,796
burnymeister wrote:
Having owned both cameras, I can very confidently say that you're very wrong on this point! I can carry the GM1+12-32mm in a small padded Lowe Pro case on my backpack's shoulder strap - the same one my Sony RX100II fit into. The E-M5 wouldn't even fit thelens in that small case!
Calgary, Alberta Canada
http://www.explor8ion.com
http://verndewit.com/
Lowepro Dashpoint 20?
Cheers Suby
Melbourne, Australia.
burnymeister
OP burnymeister Senior Member • Posts: 1,591
Amen Tom!
Vern Dewit
 burnymeister's gear list:burnymeister's gear list
Sony a7C Zeiss Batis 25mm F2 Zeiss Loxia 21mm F2.8 Sony FE 200-600 F5.6-6.3 Sony E 70-350mm F4.5-6.3 G OSS +4 more
burnymeister
I never ever use flash... Couldn't be bothered and with today's fast primes and high ISO I just never need it. I either carry the 45 or the 60 along with the kit zoom if I'm going very light, or take the 40-150 for tele shots.
The 14-140 isn't small. If you're looking at that zoom range try the Oly 14-150 but it's not OIS.
Vern Dewit
burnymeister
Yep! http://store.lowepro.com/dashpoint-20?color_lowepro_bags=207
Vern Dewit
burnymeister
Ben O Connor wrote:
Sir,
I must admit, you are the most hated person on the forum right now!!!
Do you have all these ? Man, my wife simply would throw me off from the balcony
apart from you, I'd go for gray/black body and silver Olympus lenses... And maybe, instead of owning 20m Panasonic and 12mm Olympus I'd go for 15mm latest leica lens. But well, if you have enough resources, why would you compromise !
lovely set. Enjoy your photography.
Ben
ps': please use this lovely cam by a custom made leather hand strap.
LOL - thanks Ben! Would you hate me even more if I told you that I have the 15mm on pre-order? I considered not getting the 12mm but I love that FL and it works good for astrophotography. There is still a large difference between 24 and 30mm. The 15 will be a perfect walk-around prime with the 12 and the 60 on the pack belt or in the pack for wides, macro and medium tele.
Lots of options with this kit!
Vern Dewit
burnymeister
Cheers, geoff
I hear ya Geoff. I thought I'd really not like the LCD but considering the E-M10 will take care of the 'viewfinder issue', the GM1's lack of VF is a compromise I can live with. And like I said, it actually assists in a lot of situations because the AF is so fast. But in bright, snow it can be hard to see from some angles.
Vern Dewit
berni29 Veteran Member • Posts: 3,119
Hi
I use the GM1 with a clearviewer and find the combo works very will in bright light and with longer lenses.
Berni
Berni29
EM-5, GM1 + Pana 12-32mm, 35-100mm f2.8, 20mm, 14-45mm Oly 45mm, 50mm F2 macro, (prev GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
Cheers, geoff
You guys need the lens on a stalk that turns the lcd into a viewfinder. I am getting a lot of favourable comments on my home made one and it really does work well. It is a variation on the commercial product "Clearviewer".
Tom Caldwell
Cane Veteran Member • Posts: 6,900
FrankS009 wrote:
We don't all wear skinny jeans! A genuine take anywhere camera. The best camera you have with you is a darn good one in this case.
F.
If you can fit that camera and ANY lens in a pants pocket, you seriously need a fashion style update, but then again, this place is all old people, so you've probably thrown in the towel by this point, and you are going to have to explain to people why you look so 'excited' to see them.
Ben O Connor
Ben O Connor Contributing Member • Posts: 995
this just in !
DxO reviews Leica 15mm. Its just between my two next FL decision (12mm oly & 17mm oly) and also financially in between as well...
lets see...
Ben
 Ben O Connor's gear list:Ben O Connor's gear list
Sony Cyber-shot DSC-W300 Olympus XZ-1 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +5 more
Impulses Forum Pro • Posts: 10,039
Panasonic's newer 14-140 is actually shorter than either Oly 45-150 (and only like 5mm wider). It's heavier for sure tho, which probably contributes more to balance (or lack thereof), it's certainly not larger tho.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
Oops, for some reason I read that wrong, the new Panasonic 14-140 is still the smaller/lighter superzoom tho.
F.
Even tho I agree with you to an extent, that was pretty rude and uncalled for... He didn't even say anything about actually fitting it into his pants. I'm 31 and we don't really have a winter season in Puerto Rico, so the difference between carrying a GM1 and an E-PL5 or GF6 is next to none, at least as a guy who's gonna have to grab a dedicated bag for it (unless I leave the house with it on my shoulder and the 20mm in my pocket)... I can see how it would make a difference for a woman carrying it in her purse tho, a very big difference if it's a small purse, and there's definitely a difference vs a an OMD.
burnymeister
Re: this just in !
lets see...
Ben
Hey Ben, I agree with you. I love the 17mm FL too, but having a 12, 15 and 17 just seems like overkill doesn't it?!
To me the 15 replaces the 17 and 20 as a walk around prime since I prefer slightly wider. It doesn't replace the 12mm because there's a pretty big difference in the FOV between 24 and 30mm - YMMV of course.
I also think the 15 will look very sexy on either the GM1 or the E-M10 and since I'm an 'aperture' shooter, I love that option too.
Vern Dewit
Cameras and their essential purpose
Impulses wrote:
F.
I agree with the concept that this camera is not the type to stuff in any pocket, even if it was a practical thing to do, as even at best it is far too limiting. Body cap lens anyone?
I live in a subtropical part of Australia and clothing worn is certainly not of the huge pocket type.
The concept of always having a camera handy is a good one and something I subscribe to. However the discussion sort of strays off into "lightweight" tones as if a camera that can be stuffed into a pocket, used as a backup, or even "pursed" by some dear lady who might barely be able to find the shutter button seems to imply a much lower technical device than this camera really is.
What the camera actually represents is a full functional M4/3 camera body stripped of many user conveniences to get its tiny size but nevertheless filled with the essential parts of the technology to compete with all other M4/3 cameras in imaging capability. In other words - an enthusiasts sub-miniature powerhouse capable of handling any lens that physically can be attached (with handling compromises of course - that comes with the territory). Those that need more user conveniences will need a larger body too wrap the fist around, those that need something lighter (pocketable, backup, parsable, ....) will surely be better off with a collapsing lens compact which I am sure will better suit their purpose.
Tom Caldwell
Kirkdi Regular Member • Posts: 496
Do you own this grip?
If so does it provide a good hand position, most reviews of the Panasonic grip feel it's too close to the camera body edge for the best grip?
Kirk
 Kirkdi's gear list:Kirkdi's gear list
Panasonic LX100 II Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Cheers, geoff
For those of you that own the GM1 the one issue commented on the most in reviews is the rear control dial and how hard it is to turn without also pressing it down which causes an adjustment to a different setting.
What is your experience with the rear dial?
Thanks,
Kirk
