lifting shadows in jpeg
Started Apr 15, 2014 | Discussions
shademaster Contributing Member • Posts: 803
I was shooting with my dad's T1i this past weekend.  I didn't immediately figure out how to put it into RAW mode, so I shot jpeg.  It seems like the jpegs lend themselves to much easier lifting of shadows compared to Samsung jpegs (on my NX200).  Anyone know why?  (I didn't do any controlled test).  Simply the choice of tone curves?  i.e. the default Samsung tone curve has less DR on the left compared to Canon?
 shademaster's gear list:shademaster's gear list
Canon PowerShot S95 Samsung EX2F Panasonic LX100 Samsung NX300 Samsung NX 30mm F2 Pancake +3 more
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3) Samsung NX200
OP shademaster Contributing Member • Posts: 803
Re: lifting shadows in jpeg
And I guess this comment applies to "smart range=off" on the samsung.
Leon Obers Senior Member • Posts: 2,788
I am not a Samsung camera user yet, only a "lurker" to this part of the forum because I am interested in Samsung Gear.
In general (in favour to all camera brands) a JPG picture is a processed image at top to the RAW-data with the settings applied within the camera. To have more detail within shadows, choose a Picture Wizard style that exhibit already much detail in shadows. I suppose (as not a user, but reading from the manual) "Standard" or "Portrait" is a good start. Maybe individually tweaked for contrast. (Is it possible using a NX200 ?). The other option could be "Smart Range" or "HDR" where in the last option at least two pictures with different exposures are combined. From what I read from the manual, HDR is not an option for the NX200 camera.
But likely you can do a lot afterwards on a PC using an image editor.
Leon
Ian Leach Senior Member • Posts: 1,475
I agree with Leon. If you want jpeg to behave more like RAW use picture wizard to reduce sharpness and contrast settings, then use an editor to bring them back.
(unknown member) Contributing Member • Posts: 947
If you want a quick and simple way of pulling back shadow detail then look at PhotoScape and its 'Backlight' feature. All the settings are adjustable and it's a very useful and FREE program.
I'm Irish with red hair and grey eyes. I have both the gift of the gob and a very short fuse. The first is great the second is a curse but I have to live with both...
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
+1
I will use this same picture wizard setup, even though I shoot raw. In conjunction with the histogram, this helps in exposing to the right without fear of clipping, while maximizing information in the shadows for easy processing. Helps with jpg info too; just requires post processing. For me, if I'm going to do pp work (which I enjoy), I would just as soon do it with the raw file.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
Re: +1
Makes sense.  I'll try it!
I would imagine, but I haven't played much with Picture Wizard since I usually shoot RAW.
There is standard exposure bracketing, but no in-camera HDR matrixing on NX200.
Leon
Thanks for the tips!
Re: +1
And the default JPEGs from the Canon certainly did have pretty low contrast (but they looked pretty sharpened to me).
I tried, and it is a handy little tool if you have no other photo editing programs to do a quick correction. However by the simple set-up and not very sophisticated used algorithms, under certain circumstances it can give strange density and looking false color at other areas. So use it with care and be aware of such behaviour.
Mostly all general more sophisticated photo editing software (but not free programs) do have better algorithms to tweak in a better way. Many RAW-converters also can be used for editing JPG and TIF files and images can be tweaked in the same way.
Photoshop Menu -----> Image ----> Adjustments ----> Shadows / Highlights
Nikon Capture NX2 (Nikon RAW converter plus Photo tweaking program for JPG + TIF)
- Under "Fast editing" ----> lifting shadows
- Under menu ----> D-lighting
- Using a "Color control Point" (comparable as Nik Viveza plugin for Photoshop)
Photo Ninja (general RAW converter plus Photo tweaking program)
- Shadows
Beware. If an image do have nearly real black within the shadow area, the correction can have posterization at the darkest regions. If you have some spare, the tones are rich and have a fine micro contrast.
Capture One Pro 7  (general RAW converter plus Photo tweaking program)
- several sliders to lift or tweak shadow
Each editing software do have their advantages and disadvantages. For best perceptual image quality, often you have to use other tools too. E.g. to lift micro-contrast (clarity) or colour saturation within shadow areas.
Leon
ttbek Veteran Member • Posts: 4,869
It seems to me that you are neglecting GIMP and Darktable here.  They certainly have some fairly sophisticated options available if one wishes to make use of them.  Granted they may not be quite at the same level as the more expensive paid programs (they blow the cheap ones out of the water) but they can certainly do things like shadows and highlights and much more besides.
- Shadows
Leon
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
I think --know for sure-- that I am neglecting much more editing programs with comparable functions. But it is not my intention to sum up all the possible known software packages in the market, just to mention some that have good options for it.
Other packages that could be of interesting too are e.g. Adobe Elements, Paint Shop Pro, Ulead PhotoImpact.
More to find on a list < SEE HERE >
Leon
Well, I guess you did qualify your sentence with "mostly" but I guess it just felt a bit like you were dismissing all free software, so I wanted to point out a few pieces of free (and in this case open source) software in particular that are very capable.  I think I was feeling bit prickly at the time, lol.
